jacklockamy(at)verizon.ne Guest
Posted: Sun Sep 17, 2006 6:52 am Post subject: Lycoming IO-540 300-HP engines? |
Hope this doesn't start an 'engine war', but I'm curious if anyone has installed (or plans to install) a 300-HP Lycoming that has the same physical characteristics (dimensions, inlet design, and weight) as the 260-HP version Van's recommends?
I know the Glasair-III guys use the IO-540-K1A5/K1A5Ds with lots of success. Just wondering if the RV-10 would be a suitable candidate for a 300-HP injected Lycoming. And yes, I am aware of the manufactuer's opinion on engine recommendations.... . I'm just doing my research before I take the plunge and start an RV-10 project.
If you don't care to possibly be flammed or publically share your info, please email me direct.
TIA,
Jack Lockamy
Camarillo, CA
RV-7A N174JL 225 hrs
'Thinking RV-10 kit in the near future'
www.jacklockamy.com
AV8ORJWC
Posted: Sun Sep 17, 2006 8:03 am Post subject: Lycoming IO-540 300-HP engines? |
Jack, this question will be best answered by Rhonda and the group from Barrett. The cowl design was specifically directed and design to be made so narrow that the wide deck Lycoming and Continentals could not fit. You added weight and inlet design into your criteria which would eliminate use of a forward facing (rather than updraft) injection unit. I believe that only allows compression ratio increase and tuned headers as the means to your end. The same weight requirement eliminates a turbo. Hopefully Rhonda will restate how much hp can be squeezed with a clear trade off from “the same physical characteristics (dimensions, inlet design, and weight) as the 260-HP”. I think I remember 290 (dynode) but with significant fuel type restrictions, consumption rate and oil temp issues. The James Wholly Cowl may change some of this. Again ask Ed Hayden. You can always use Hollywood Horsepower and tell everyone 325.
Modify your parameters and then ask Vic Syracuse and Ed about the output of their fire breathing red powerplants.
John Cox – always willing to expand the thought process of SAFE RV-10s. Nomex III Suit ON.
Do not Archive
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JACK LOCKAMY
Sent: Sunday, September 17, 2006 7:52 AM
Subject: Lycoming IO-540 300-HP engines?
TIA,
Jack Lockamy
Camarillo, CA
www.jacklockamy.com
[quote] [b]
Deems Davis
Posted: Sun Sep 17, 2006 9:45 am Post subject: Lycoming IO-540 300-HP engines? |
I know of one -10 builder who had BPE build his engine, with a bigger
fuel injection pump. 9:1 pistons, Cold Air induction, and Forsling
exhaust. It dyno'd at or above 290 hp. That's the same config that I'm
also in line for from BPE, I'm hoping for similar results (depending on
the weather/temp the day they run the engine). Bigger pistons would
easily push the engine to or above 300 hp. I believe that Vic Syracuse
has 300 ponies on a Lycoming based engine in his plane.
Deems Davis # 406
Panel/wiring/finishing
http://deemsrv10.com/
John W. Cox wrote:
Quote: | Jack, this question will be best answered by Rhonda and the group from
Do not Archive
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *JACK LOCKAMY
*Sent:* Sunday, September 17, 2006 7:52 AM
*To:* rv10-list(at)matronics.com
*Subject:* Lycoming IO-540 300-HP engines?
TIA,
Jack Lockamy
Camarillo, CA
www.jacklockamy.com <http://www.jacklockamy.com>
dav1111(at)cox.net Guest
Posted: Sun Sep 17, 2006 10:28 am Post subject: Lycoming IO-540 300-HP engines? |
Contact me direct (dav1111 at cox.net) and I will give you some info on the IO-540 300 HP engine.
Best regards,
Russ Daves
N710RV - Flying RV-10
pascalreid(at)verizon.net Guest
Posted: Sun Sep 17, 2006 11:23 am Post subject: Lycoming IO-540 300-HP engines? |
Vic Syracuse has a 310hp engine. From what I understand has been no problem in the RV-10.
bcondrey
Posted: Sun Sep 17, 2006 4:47 pm Post subject: Re: Lycoming IO-540 300-HP engines? |
The mount & cowl supplied with the RV-10 will accept parallel valve Lycomings (either narrow or wide deck). What won't work is an angle valve engine like the IO-540-K series mentioned. The engines mentioned that are in RV-10s and achieving greater than 260 HP are all parallel valve models with various mods - higher compression pistons, cold air induction, etc.
Bob
rvbuilder(at)sausen.net Guest
Posted: Mon Sep 18, 2006 7:28 am Post subject: Lycoming IO-540 300-HP engines? |
Is that me? Sounds like me but I dyno'd at 272 I believe. I am also
running dual LSE III ignitions so you could probably expect to see a
little more HP off of mags. It was also over 100 degrees when they ran
the dyno test which I'm sure ate up several HP.
Michael
Deems Davis
Posted: Mon Sep 18, 2006 8:23 am Post subject: Lycoming IO-540 300-HP engines? |
I was Gary Foster's engine.
Deems Davis # 406
Panel/wiring
Michael
