spaghettiohead(at)hotmail Guest
Posted: Fri Sep 15, 2006 3:26 pm Post subject: Annual on Kitfox III - Repairman Experimental Aircraft Buil |
Thanks for clearing this "Repairman's Certificate" confusion up!
Andrew
KF3
[quote]From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com>
Subject: RE: Re: Annual on Kitfox III - Repairman Experimental
Aircraft Builder
Date: Fri, 15 Sep 2006 16:59:08 -0600
Marco is right. If you don't get a certificate for "Repairman Experimental
Aircraft Builder" you can't do the condition inspection.
You don't get them automatically. You have to apply for the certificate.
If you have a good DAR, he will help you get when your plane is inspected.
But you need one to put with your signature when you do the annual
condition
inspection.
Randy
