n100rh(at)sbcglobal.net Guest
Posted: Tue Sep 12, 2006 11:35 am Post subject: prop bolts |
Maybe I can help. Take a look at this website, it may assist you with
the use of a crows foot.
http://www.norbar.com/torquewrenchextensioncalculator.php
Ralph
DuaneFamly(at)aol.com wrote:
| Quote: | Svein and Others,
I'm not sure I agree with this method. I don't think the torque wrench
knows how long a handle is exerting the force. I think that it will
still "click" at the setting you set it at. If the proper setting is
50 inch lbs (EU's have to do the conversion) and you set it the torque
wrench for 25 inch lbs, then the wrench is going to click when you
have 25 inch lbs exerted on it. And your bolt is only torqued to 25
inch lbs, not 50. Making the handle longer only allows you to have to
exert 1/2 the pressure to get that 50 inch lbs to the torque wrench.
Am I missing something here?
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300
Sensenich R64Z N
Ground Adjustable Prop
sidsel.svein(at)oslo.onli Guest
Posted: Wed Sep 13, 2006 10:47 am Post subject: prop bolts |
Mike,
Indeed - that is the difference! This thread started with a question on what to do if one could not get the wrench directly onto the bolt because of tight space. That was the concept I had in my head when I replied to you.
Best regards
Svein
LN-SKJ
europa(at)pstewart.f2s.co Guest
Posted: Wed Sep 13, 2006 1:41 pm Post subject: prop bolts |
I seem to have started a very learned discussion on this topic. As the person who asked what to do when you can't get the wrench directly on the bolt all I can say is Svein's solution works what ever the theory. Using the spanner/wrench combination, the torque wrench 'clicks' at exactly the same point as torque wrench alone on my simple bench comparison.
Many congratulations on your first flight Svein - perhaps one day we will follow suit.
Paul
G-GIDY
On 13 Sep 2006, at 19:46, Sidsel & Svein Johnsen wrote:
[quote]Mike,
Best regards
Svein
LN-SKJ
[quote]---
