C Type Pneumatic Rivet Squeezer
callsign(at)bellsouth.net
PostPosted: Wed Sep 13, 2006 2:09 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
Anybody using one of these? Best size, type of yokes? Tool vendor source?
Link McGarity
RV6/N42GF
RV10/N41GF(rsvd)/#40622
Wellington, FL (FD38)
DAVELEIKAM(at)wi.rr.com
PostPosted: Wed Sep 13, 2006 4:10 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
A pneumatic squeezer is a must to have even at the high price. I have three
different yokes, and I use all of them. I got mine from "Plane Tools." I
wouldn't be without it. They dimple very well also.
Dave Leikam
Muskego, WI
#40496
N89DA
Elevators
effectus(at)rogers.com
PostPosted: Wed Sep 13, 2006 4:16 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
Link,
I highly recommend that you purchase one of these tools. I purchased
mine from Avery and it has performed beautifully. I purchased a 3" yoke, a
4" yoke that has a narrow tip for tight spots and the longeron yoke. The 3"
yoke stays on the tool most of the time and the longeron yoke comes in
second when it comes to usage. The narrow tip 4" yoke isn't used as much as
the other two but is definitely worth purchasing. I use it for everything. I
even designed an adapter plate that converts it into a large C-frame
dimpler.
Personally, I couldn't imagine building a metal airplane without this
tool.
Dave Hertner
RV-10 C-GVMH #40164
London, Ontario
Canada CYXU
jjessen
PostPosted: Wed Sep 13, 2006 5:45 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
I would be interested in taking a look, should you have pictures or a
schematic, at your adapter plate for the C-frame.
John J
40328
Rick S.
PostPosted: Wed Sep 13, 2006 6:05 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
You betcha!!
It's worth every penny. I have a 4" no-hole, a 3" regular C and a 2.5" Longeron. If I did it again I would have gone with a 3" no-hole instead of the 4. The reason being is you can use the adjustable rivet set with the three but not the 4. Oh yeah, get the adjustable ram/rivet set too. Worth it's weight in shims. Can't say enough about the value of this tool. I used it to complete all my aluminum work on the RV-10. I don't have a hand squeezer in my collection of tools. Buyer beware off E-bay only because of the few stories I have heard about getting bad ones, but they did manage to get the bad ones rebuilt for some savings over a new one if your into taking that risk.
I picked mine up at http://www.rivettools.com along with their 20 piece "RV" rivet sets. These are the BEST made sets I ever used and it has all the screw dimple dies you will need as well. My dimple dies are still intact (heard of nubs breaking off some) and I found they make cleaner dimples than many of the cheaper versions if you can call $28-30 cheap! The set is $150.
No affiliation with them just great service and the tool is still going strong.
Rick S.
40185
Rick S.
RV-10
40185
Tim(at)MyRV10.com
PostPosted: Wed Sep 13, 2006 6:17 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
John, you should go see Ed out by you. He's got a good
setup for his hand squeezer.
John J
40328
Tim(at)MyRV10.com
PostPosted: Wed Sep 13, 2006 6:29 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
Rick wrote:
You betcha!!
Hey Rick, I used my adjustable set exclusively throughout the
build, and never even tried the primitive washer way. It's
funny that you say that about the 4" no hole, because I
used it a ton. Is it me, or is one of us smokin' somethin'?
Vern(at)teclabsinc.com
PostPosted: Wed Sep 13, 2006 6:32 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
Hi Link,
I purchased a reconditioned one from the Yardstore at www.yardstore.com.
Have two yokes a standard 3" deep one and a 4" thin nose (has no hole in
the yoke just a flat surface for forming the shop head.) From time to
time I wish I had a longeron yoke. Also an adjustable set holder (it
threads in and out to adjust for working thickness) is a nice touch,
compared to the fixed set holders that you add washers under the set for
adjustment. Both will work though. One thing to keep in mind if you look
into the Yardstore is most of their squeezers come with the fixed set
holder. However the adjustable sets holders are available separately
from Cleveland tools as are new squeezers.
Vern (40324 wings)
bcondrey
PostPosted: Wed Sep 13, 2006 6:38 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
I started out the primitive way with a hand squeezer and as soon as I
tried out a friend's pneumatic unit I bought one. I have the same yokes
as others have mentioned - 3" C, Longeron and a 4" no hole. I keep the
4" no hole yoke in my hand squeezer. Over 95% of what I need to do uses
either the C or Longeron yokes.
As others have said, I can't imagine doing this project (especially the
slow build) without a pneumatic squeezer.
Bob #40105
Rick S.
PostPosted: Wed Sep 13, 2006 6:39 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
My 4" no hole hardly ever got used mainly because you had to use washers/shims. When it was needed it was NEEDED I'll say that! My adjustable set worked great on the 2 & 3" yokes.
For me it's Marlboros, (no flames I'll quit) What you smoking Smile
Rick
Rick S.
RV-10
40185
jjessen
PostPosted: Wed Sep 13, 2006 6:41 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
I did not know that. All I've seen in Ed's shop is the world's largest
C-frame, an industrial behemoth that must weigh 6 tons and can put a dainty
dimple six feet inside a sheet of 1/4" steel. I exaggerate of course, but
it is big. I'll get a picture of it this weekend, should Ed be around.
John J
mike(at)cleavelandtool.co
PostPosted: Wed Sep 13, 2006 6:46 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
Cleaveland (that's me) sells them at the following link.
https://www.cleavelandtoolstore.com/products.asp?dept=52
In the order of most used yokes there is the 3", 2.5" Flange (longeron), and
4" thin nose. People like the 4" thin because you can reach in a little
further with it and still have the thin nose for other tight areas.
Our adjustable set holder will work with all of the yokes where others only
work with the 1" thick base yokes. Ours also has a 32 pitch thread in the
ram so if you switch from a -3.5 to a -4 rivet it is just a half turn. No
measuring needed.
We will match the competitions price as long as it is the exact same item &
quality.
Mike Lauritsen
Cleaveland Aircraft Tool
2225 First St.
Boone, Iowa 50036
515-432-6794
mike(at)cleavelandtool.com
jjessen
I also use the 4" with the adjustable set. Works okay for me.
John J
LessDragProd(at)aol.com
PostPosted: Wed Sep 13, 2006 6:59 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
It's good to hear that someone else needed the large economy size pneumatic squeezer.
We just finished squeezing the 3/16" rivets in an RV-4 spar. No problem.
With the large squeezer, I oversqueezed a dimple on a test piece of aluminum, once. The dimple came out fine. However, the material around the dimple was thinner.
I seem to recall that the transition from dimple to countersinking in aluminum is 0.040 material. Anyone have different data?
Jim Ayers
In a message dated 09/13/2006 7:44:18 AM Pacific Daylight Time, jjessen(at)rcn.com writes:
--> RV10-List message posted by: "John Jessen" <jjessen(at)rcn.com>
John J
LloydDR(at)wernerco.com
PostPosted: Wed Sep 13, 2006 7:02 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
I had a hand squeezer from Avery, and loved it, and had great results.
Unfortunately for my check book, a close friend went on vacation and
loaned me his pneumatic squeezer from Avery, and I feel in love with it.
He had to pry it out of my hands when he got back. My wife ordered me
one for a present and included several yokes with it, the 4" no hole, a
standard 3", and the longeron yoke. The two I use most are the 4"
no-hole, and the longeron. I have the adjustable set and have used it
with all of the yokes and it works great. I highly recommend Avery, both
for the quality and for their customer service. I bent the adjustable
set, because of something I did, and they replaced it for no charge.
They are also competitive on their pricing, if you find it elsewhere
cheaper, just call them on the phone and they will work with you.
Dan Lloyd
40269
RV10E N289DT (Reserved)
Tim(at)MyRV10.com
PostPosted: Wed Sep 13, 2006 7:09 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
Weird...I wonder if there's something different about your
yoke or squeezer. Oh well.
As for me, I only smoke when I'm on fire...which seems
to happen with a strange regularity when I'm around
bonfires. Wink
capsteve
PostPosted: Wed Sep 13, 2006 5:08 pm    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
Absolutely a must have, IMO. Nothing can give a consistently driven rivet
like a pneumatic squeezer with an adjustable set. I use it on every rivet I
can reach. 90% of the time I leave the longeron head in. I also use it for
dimpling of ribs and stingers and anything I can get at. I have a double ram
squeezer that’s capable of up to -6 rivets. It’s a bit heavy and I wished I
had bought the single ram lighter version. I don’t think I've used it on
anything larger than a -4.
Steve
40205
jwt(at)roadmapscoaching.c
PostPosted: Thu Sep 14, 2006 5:13 am    Post subject: C Type Pneumatic Rivet Squeezer Reply with quote
I also highly recommend getting a foot pedal control for it. It is real
handy to clamp the squeezer to a bench and use two hands to move a larger
part of skin through it. Go mine from Cleveland and am very happy with it.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Finish kit - wheel fairings, cowl prep
