occom
Posted: Tue Sep 12, 2006 5:04 am Post subject: Leaky fuel tanks. |
I have one tank that is weeping through the glass. I see Skystar had this problem and offered replacement at one time. Is there any way to repair this? from the outside? Inside? Sloshing seems to be out, I had as good a look inside the tank as possible with a small webcam on a dowel and they seem in good shape other than the small spots shown as dark on the masking tape.
29.7 KB |
354 Time(s) |
dosmythe(at)cox.net Guest
Posted: Tue Sep 12, 2006 6:25 am Post subject: Leaky fuel tanks. |
Dave,
It looks like these tanks are new and never been installed. What year were they manufactured? What type fuel did you use that showed the weeps? With the rapid use of Ethanol, it makes the tank questions much harder. I for one do not think an outside patch is the way to go. I also don't feel comfortable with sloshes (Just my opinion). However, short of cutting the tanks open I might consider a large outside patch of glass and epoxy resin. I would always be suspicious of the rest of the tank area and future leaks.
Don Smythe (opinion only)
Fox5flyer Guest
Posted: Tue Sep 12, 2006 6:41 am Post subject: Leaky fuel tanks. |
small web cam on a dowel? Cool!
Why is sloshing out?
Deke
pwmac(at)sisna.com Guest
Posted: Tue Sep 12, 2006 6:51 am Post subject: Leaky fuel tanks. |
Very small pinholes which is why Skystar used the internal sloshing
stuff. Clean it and and epoxy on the outside? The pinholes are very common.
Paul
At 07:04 AM 9/12/2006, you wrote:
| Quote: | I have one tank that is weeping through the glass. I see Skystar had
Posted: Tue Sep 12, 2006 7:12 am Post subject: Leaky fuel tanks. |
I might add one more suggestion if those are new/never installed tanks.
Clean the outsides very good. Mix up some good epoxy resin and coat the
entire outside of the tanks. Use a plastic scraper and put the epoxy on as
thin as you can. Epoxy (especially when lightly warmed with a hairdryer)
will wick into the smallest of pin holes. This might just add a little
extra assurance.
Don Smythe
occom
Posted: Tue Sep 12, 2006 7:24 am Post subject: Leaky fuel tanks. |
Hi Don, these tanks have been used for ~500 flying hours. with avgas and CDN auto gas, so likely no ethanol. The show the laks I just tossed a gallon of gas into them and let them sit for a few days. I knew where it was leaking and wanted to see how bad it was. Is regular epoxy resin gasproof, I have some really nice tight weave fiberglass cloth.
Dave,
occom
Posted: Tue Sep 12, 2006 7:31 am Post subject: Leaky fuel tanks. |
Sloshing compound was found to be coming off on some aircraft and I think currently you are not supposed to use it. I could be wrong.
Posted: Tue Sep 12, 2006 7:45 am Post subject: Leaky fuel tanks. |
I'm far from being an Epoxy expert. I used West Systems after talking with the manufacture a couple times. They insured me that West Systems was gasoline safe. HOWEVER, I talked with them again not too long ago and they are concerned about their product and Ethanol. They are not willing to give the same assurance when using Ethanol??? I would recommend you do some research to find the best epoxy resin.
Don Smythe
smokey_bear_40220(at)yaho Guest
Lynn Matteson
Posted: Tue Sep 12, 2006 9:43 am Post subject: Leaky fuel tanks. |
How about one more suggestion, Don....apply a SLIGHT vacuum to the
filler cap area via the vent tube and maybe it will help draw the epoxy
into those small pin holes...just a thought. A vacuum cleaner might do
the trick, or running your car's engine might do it...NOT AT FULL
vacuum, though...don't want anybody sucking those expensive tanks into
junk!
Personally, I did the slosh method, and have over 150 hrs on the plane
without (knock on wood) a problem yet. My tanks were 12 yrs old with no
fuel ever in them when Frank Miller suggested that I clean and slosh
them. I use only avgas...when you burn only 3.3 gals/hour, it's
affordable, I feel.
Lynn
tanks. Clean the outsides very good. Mix up some good epoxy resin and
coat the entire outside of the tanks. Use a plastic scraper and put
the epoxy on as thin as you can. Epoxy (especially when lightly
warmed with a hairdryer) will wick into the smallest of pin holes.
This might just add a little extra assurance.
Don Smythe
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Fox5flyer Guest
Posted: Tue Sep 12, 2006 11:25 am Post subject: Leaky fuel tanks. |
This is news to me Dave. As far as I know, the Kreem is still fine. The only reason it was a problem with Skystar supplied tanks is that the mold release wasn't cleaned out of the inside of the tanks prior to applying the Kreem which caused it to eventually peel off of the inside surface. Cleaning the tanks with MEK or Acetone then reapplying Kreem 50/50 was a good fix. Some were able to get away with using no slosh at all.
Deke
Posted: Tue Sep 12, 2006 12:18 pm Post subject: Leaky fuel tanks. |
Kurt,
You mean you didn't do that. I remember telling you 7 years ago to be
sure and coat the outsides. Also, the one post that mentioned putting on a
vacuum might work even better.
Don Smythe
janderson412(at)hotmail.c Guest
Posted: Tue Sep 12, 2006 8:38 pm Post subject: Leaky fuel tanks. |
Sloshing the tanks works ok so long as theey are flushed out well to get rid
of the waxy coat left from the mold. Detergent is no good, MEK or the likes
is needed.
Subject: Re: Leaky fuel tanks.
Date: Tue, 12 Sep 2006 13:45:14 -0400
How about one more suggestion, Don....apply a SLIGHT vacuum to the filler
cap area via the vent tube and maybe it will help draw the epoxy into those
small pin holes...just a thought. A vacuum cleaner might do the trick, or
running your car's engine might do it...NOT AT FULL vacuum, though...don't
want anybody sucking those expensive tanks into junk!
without (knock on wood) a problem yet. My tanks were 12 yrs old with no fuel
ever in them when Frank Miller suggested that I clean and slosh them. I use
only avgas...when you burn only 3.3 gals/hour, it's affordable, I feel.
Lynn
extra assurance.
Don Smythe
Posted: Wed Sep 13, 2006 5:54 pm Post subject: Leaky fuel tanks. |
I could just see me sucking my tanks flat...
A little vacuum is a good idea though.
Naw. I wasn't on the list 7 years ago and did the
tanks before learning all this. Worried a little
about them now. I sloshed them with alcohol, nothing
stronger. Bought a slosh coating listed for alcohol
and used that. Waiting for the pealing to start...
Kurt S.
--- Don Smythe <dosmythe(at)cox.net> wrote:
| Quote: | Kurt,
Don Smythe
occom
Posted: Thu Sep 14, 2006 8:58 am Post subject: Leaky fuel tanks. |
I think it is better to slosh the whole thing and not
allow an edge for the fuel to get under. The slosh is
fluid enough to slowly go around the baffels. Then
you can rotate it every few minutes and get a good
layer built up. Then pour out the excess, no problem.
Of course, apply the epoxy on the outside first,
especially if you put "a little" vacuum on the tank.
Kurt S.
--- "Dave G." <occom(at)ns.sympatico.ca> wrote:
| Quote: | >
> <smokey_bear_40220(at)yahoo.com>
I've decided to go with epoxy on the outside and
possibly a sloshing
compound as well. Do you have to coat the whole tank
inside or can you
simply roll the compound around the area of concern?
My tank has two
internal baffles that will complicate things a
little.
For the outside epoxy, I've decided to go with the
Hysol that I already
have. The website lists it as being impervious to
almost everything this
side of Kryptonite, so it should perform this small
task well.
Lynn Matteson
Posted: Thu Sep 14, 2006 1:48 pm Post subject: Leaky fuel tanks. |
And the fact that you're sloshing it BEFORE you put it in the wing
makes it a whole lot easier. Unlucky me learned about the need to clean
and slosh only after installing the tanks into the wings. Not fun
sloshing a 12-foot wing inside an 11-foot 10-inch building.
Lynn
On Thursday, September 14, 2006, at 12:58 PM, kurt schrader wrote:
Kurt S.
N369LM |
