rdewees(at)mindspring.com Guest
Posted: Mon Sep 11, 2006 6:10 pm Post subject: Tri gear vs tailwheel test flight |
>>> Listers-- I hope this won't be too boring to you veteran Zenith
>>> pilots out there but I got a chance to fly a friend's brand new
>>> 601HDS registered as N201MS. It's powered by a Continental A 75-8
>>> (75 hp) motor and is a tri gear model. I thought it might be
>>> interesting to those who have flown one, but not both wheel
>>> configurations of Zenith 601s if I shared my reactions. I wrote
>>> this review after flying N201MS for two hours. I think my hours
>>> were number 10 and 11, so it's a brand new bird! Mike Stewart was
>>> kind enough to ask me to help fly off the Phase One hours since he
>>> has watched me tweak my HDS/Jab 3300 taildragger for over 150
>>> hours. He has also owned or built over 60 airplanes and did the
>>> first flight on my 601HDS so he knows his stuff! The original
>>> post was to our Yahoo group called: 601_HD-HDS. There are more
>>> pictures and information posted there. The group was set up for
>>> Georgia area Zenith drivers to communicate but it is open to
>>> everyone. I am sure my experience will not be the same as everybody
>>> else's but I just call them the way I see them-- One additional
>>> note-- the aileron stiffness I noticed is now completely gone.
>>> Mike found a binding bearing and fixed it so it's effortless to use
>>> ailerons now. He says that when I get out of his plane next time I
>>> will head for mine and pick up the shears to put hinges on my
>>> ailerons. We will see-
>>> Zenair N601TD wrote:
>>>> Hi fellow Zenith drivers and builders-- I did take Mike Stewart up on
>>>> his offer to help fly off phase I hours on N201MS and yesterday I put
>>>> almost 2 hours flight in the perky red bird. Mike missed his career
>>>> as a test pilot as he had nailed all the critical flight numbers
>>>> right
>>>> on the button, which made the flight a lot less "experimental" for me
>>>> than it could have been.
>>>> First of all it's tempting to think that a Zenith 601 HDS is a
>>>> 601HDS, etc. NOT SO! I'm sure there is a lot of variation within
>>>> identically configured planes of any model but there was a lot more
>>>> difference than I expected between Mike's HDS tri gear and my HDS
>>>> taildragger. I was to see for myself as the flight progressed.
>>>> To recap Mike's configuration it's a VERY light 601HDS (speed wing)
>>>> that actually came out lighter than Chris Heintz' prototype at 569
>>>> pounds. It's powered by a Continental A 75-8 non- electric motor
>>>> swinging a 60X58 pitch Tennessee prop. That's 8 inches more pitch
>>>> than my Jabiru 3300 120 hp motor is pulling! Mike and Tennessee
>>>> Propellers came up with that configuration after looking at
>>>> performance charts and projected cruse speeds for the A 65(at)2300 rpm.
>>>> Tennessee actually sent a 58 inch pitch rather than the 57 that was
>>>> agreed upon. In spite of this optomistic task for the little A75, A
>>>> digital tachometer confirmed 2260 static rpm with the prop. It easily
>>>> cruses at 2300 at altitude and gives a bit more, but not much at full
>>>> throttle.
>>>> Back to the flight-- Mike told me that the right brake was very easy
>>>> to depress when using right rudder because of the toe brake setup of
>>>> the Heintz's flyers and he was right. The A75 is a torquey little
>>>> engine that requires noticable right rudder to offset the "P" factor
>>>> on taxiing for takeoff. The mechanical brakes are similar to mine but
>>>> seem more effective. Mike told me to accelerate to 65/70 mph, apply a
>>>> little back pressure and let it rotate. Best climb speed seems to be
>>>> between 85 and 90. This gives about 650 to 800 fpm climb rate out of
>>>> our turf strip. This is certainly adequate but not terribly
>>>> thrilling, altho it sure got up to altitude in a dependable and
>>>> reassuring manner. The A75 sounds throaty and powerful both on the
>>>> ground and in the plane. Mike used larger exhaust pipes on the
>>>> manifolds and we think it may be the reason for the nice exhaust
>>>> note. Several on the ground thought it was an 0320 rather than a
>>>> "cub" motor. Mike liked that!
>>>> Flying is rather different from my taildragger. The first thing I
>>>> noticed was ground handling. It drives like a go-cart because of the
>>>> direct and positive linkage to the nosewheel. There isn't any need to
>>>> goose the throttle to throw the tail around like the taildragger
>>>> requires for tight turns. OTOH, the nice ground handling gives way to
>>>> sort of clunky rudder corrections in the air since the nosewheel is
>>>> resting on a rather stiff bearing on the firewall. There has been a
>>>> lot of discussion from Zenith drivers about changing this setup, but
>>>> it's simple, and seems to live on from model to model.
>>>> The ailerons were the next thing I wanted to compare, since Mike
>>>> installed hinges on his ailerons, rather than the "skin flex"
>>>> ailerons
>>>> on my HDS. Well, there is good news and bad news-- The ailerons are,
>>>> indeed easier to deflect on the ground and there is no self-centering
>>>> tendency as in the skin flex aileron. Since the plane is so new
>>>> (about 11 hours now) there is some friction in the linkage and minor
>>>> aileron corrections sometimes just remain deflected until the pilot
>>>> centers the stick again. I think this will improve with usage and
>>>> probably not be noticed as quickly by pilots who have not flown with
>>>> skin flexed ailerons.
>>>> The flight characteristics are very nice and reminiscent of my
>>>> taildragger. It's solid and feels like a heavier plane than it is.
>>>> OTOH when you lean it over for a mild turn it seems more in its
>>>> element. It cheerfully banks over and stays there unless you correct
>>>> the angle. The A75 is a little strained to maintain lift at steep
>>>> bank angles so the rpm drops a little bit but it returns immediately
>>>> when the wing starts suppling full lift again. You feel like Walter
>>>> Mitty chasing the Red Barron as you yank and bank it a bit. It's a
>>>> really nice combination of a trainer with great manners and an entry
>>>> level fighter plane. You never see it's fun personality till you feel
>>>> comfortable with the snappy handling. Wingovers and steep turns are
>>>> great, but we all agreed it's a bit lacking in power for a roll or
>>>> loop.
>>>> Mike was right on with his cruse and landing numbers, too. He got
>>>> 110 to 115 mph at 2300 rpm cruse and that's about what I saw. It
>>>> feels faster than that and the plane just seems to like those speeds
>>>> cause full throttle or 2250 rpm don't change it much up or down. Mike
>>>> weighs about 40 pounds more than I do so I was curious to sii if
>>>> the stall
>>>> speed would be different. He gets 51 mph power off and 47 ish power
>>>> on. I seemed to get similar numbers so it is Light Sport Aircraft
>>>> qualified. As expected, the big fat wing gives a lot of warning of
>>>> impending stalls. It gripes a bit, shakes a little, shakes more,
>>>> and finally breaks mildly into an increased rate of descent. No
>>>> tendancy to drop a wing at all. You would have to be
>>>> distracted by Angelina Jolie in the right seat to ignore the warnings
>>>> of a stall.
>>>> I was mildly anxious about the first landing at our 2500 foot turf
>>>> strip with a 8 knot tailwind so I went to Covington and Monroe
>>>> airports to get some landing experience. Mike suggested 100 on
>>>> downwind, 90 on base, and 80 on final, with a mild flare with power
>>>> and 60/65 at touchdown. These numbers sounded hot to me since I use
>>>> about 10 mph less in landing configuration on my taildragger.
>>>> As usual Mike's numbers were very close and the first landing I set
>>>> up at Covington would have been impossibly high in my plane. The
>>>> nosegear configuration seems to settle into a solid descent angle
>>>> without picking up speed and high approaches are almost always
>>>> recoverable. I noticed up to 1500 fpm descent at 1800 rpm and the
>>>> airspeed seemed nailed to the gauge. As you would expect, the speed
>>>> will bleed off pretty fast as you rotate to a flare with these
>>>> approach angles and you would be right. I added power and it rounded
>>>> nicely and made an acceptable aquaintance with runway 10 at Covington
>>>> at about 60 indicated airspeed. I opened the throttle and watched out
>>>> for the right brake interaction with the rudder pedal and rotated
>>>> in a
>>>> few hundred feet. The torque factor wasn't as bad as from dead start
>>>> but it still needed right rudder. It climbed better than out of
>>>> Lenora and I saw up to 1000 feet at times. After a few more landings
>>>> at Covington and Monroe I felt better about landing at Lenora and had
>>>> no problem at all getting back into Lenora.
>>>> All in all it's a great plane! It's different from mine, but 45
>>>> less horsepower is bound to make any plane feel different. The
>>>> biggest
>>>> change I noticed was the descent angle with power off. It has a very
>>>> solid and predictable glide angle for landings that Mike says is
>>>> almost identical to the Piper Pacer. I haven't flown a Pacer but
>>>> bet I
>>>> would like it. The rudder pedals will remain stiff due to the
>>>> nosewheel linkage and the ailerons will certainly loosten up. BTW
>>>> Mike
>>>> installed a mechanical trim tab on the elevator and it's awesome!
>>>> Half
>>>> inch movement on the tab sets it up for climb or cruse and takes off
>>>> almost all stick pressure.
>>>> Mike and I discussed the dramatic landing differences between our
>>>> planes and decided that maybe the nosewheel disturbs the airflow
>>>> under the flat belly of the plane. It does make for a better trainer
>>>> or transition plane than the taildragger because speed management
>>>> isn't much of an issue. Just to prove this I made a flight in my
>>>> taildragger later in the afternoon and came in hot and high because I
>>>> didn't bleed off speed on the downwind as I should have. Slipping the
>>>> tailwheel HDS just lets it gain speed even as it increases it's
>>>> descent rate, and you get the momentum right back as soon as you take
>>>> the crab angle out. Not so in Mike's plane.
>>>> Mike is getting a little bored with flying off the rest of his 40
>>>> hours of Phase I because he us used to high performance planes that
>>>> cruse about 80 miles an hour faster than his little HDS but for the
>>>> rest of us it's a refreshing little plane with nice manners and
>>>> surprising performance for it's power.
>>>> What will Mike's Aircraft Factory come up with next?
>>>> Ron DeWees
>>>> N601TD
34.57 KB |
208 Time(s) |
p.mulwitz(at)worldnet.att Guest
Posted: Mon Sep 11, 2006 8:25 pm Post subject: Tri gear vs tailwheel test flight |
Hi Ron,
Thanks for the great flight report. It sounds like a really nice plane.
I do wonder, however, about your comment regarding stall speed and
being qualified as LSA. The 51 mph sounds OK, but I would have
thought the performance should be tested at full gross weight. I
gathered from your report that you were probably flying solo and a
couple hundred pounds under gross.
Best regards,
Paul
XL fuselage
At 07:08 PM 9/11/2006, you wrote:
| Quote: | Mike
weighs about 40 pounds more than I do so I was curious to sii if the stall
on. I seemed to get similar numbers so it is Light Sport Aircraft qualified.
Paul Mulwitz
32013 NE Dial Road
Camas, WA 98607
Posted: Tue Sep 12, 2006 3:25 am Post subject: Tri gear vs tailwheel test flight |
Hi Paul,
Yes, It's solo-- (has to be for the first 40 hours) and WELL under
gross. Turns out that the plane's gross weight is more than twice it's
empty weight . 569 empty and 1200 at gross. That's pretty amazing for
a 75 hp plane!
Ron
Paul Mulwitz wrote:
<p.mulwitz(at)worldnet.att.net>
Hi Ron,
Best regards,
Paul
XL fuselage
