Yak-50 Electrical System Troubleshooting
hairball192(at)yahoo.com
PostPosted: Mon Sep 11, 2006 10:38 am    Post subject: Yak-50 Electrical System Troubleshooting Reply with quote
All:
I'd appreciate any assistance people are willing to
provide to assist me in troubleshooting my Yak-50's
electrical system.
Symptoms:
1. Chronic problem of the left gear down indicator
light on or off-on when landing gear is up (with two
red up-and-locked lights also on)
2. Recently all annunciator lights (all four gear
indicators, generator, Over-G, chip, all cells on fuel
ladder) flashing on-off; Last flight all annunciator
lights were on and steady (same look as pushing the
press-to-test by the gear handle)
3. My electrical switches are labeled "Gear" and
"Inst"; The "Inst" switch controls the proper reading
of the fuel ladder (ie: it reads the correct amount of
fuel with this switch on), generator annunciator light
and engine instruments; The "gear" switch controls the
landing gear position indicator lights, all the light
cells on the fuel ladder (same as pushing the "k"
button to test the fuel indicator), the chip light and
the over-G light
In troubleshooting over the weekend, I performed the
following steps and got the following results:
1. Turned on the following switches: Battery, inst,
and gear; All annunciator lights came on, I heard what
I think is some kind of electrical motor wind up for a
few seconds, then the "Gear" switch-breaker flipped
itself off and the associated annunciator lights went
off and the sound ceased
2. After cycling the switch a half dozen times with
my head under the panel to try to locate the noise,
the motor stopped coming on with the gear switch, but
it continues to break to the off position after
several seconds in the on position; There is about a 2
amp draw with the "gear" switch on as indicated by the
aircraft guage; The noise was coming from behind the
instrument panel, but I couldn't locate the component
3. There are two wires attached to the "gear" switch;
Removed the wire labeled 05-CW1 and turned on the
batt, inst and gear switches with the same result -- 2
amp draw and gear switch breaks to off after several
seconds
4. Removed the wire labeled 05-CW2-01 and turned on
the batt, inst and gear switches and now the gear
switch does not break, the elec system remains on; The
landing gear indicator lights, fuel ladder lights,
chip light, and over-G light do not illuminate (proper
fuel indication, generator light on, and engine
instruments are powered) -- so the bad wire is this
one, I think
5. Re-installed both wires and verified that the
system fails in the same way as before
6. Friends manually held both landing gear position
squat switches in the "gear-up" position and turned
the electrical switches off with the same result --
Gear switch breaks to off after several seconds
7. Disconnected the left gear position squat switch
at the bus bar in the wing root by removing the lower
three of the four wires (I believe the top wire is for
pitot heat) and turned on the batt, inst and gear
switches -- GOT IT -- Same result as step 4 above --
Gear switch does not break, the elec system remains on
with a right gear down green light; I'm fuzzy on this
part, but I believe I did the push-to-test for the
annunciator lights and all worked EXCEPT the chip
light and over-G light
8. And then the plot thickens -- With the electrical
system on, manually depressed the RIGHT landing gear
squat switch -- The RIGHT gear down light went out and
the LEFT gear up light went on (hopefully a simple
crossed wire) AND got a 2.5 amp draw and the gear
switch broke to the off position after several seconds
Only two things scare me and both of them are
electricity, so I wouldn't have been able to do any of
this without the able help of some airport buds (Ken
and John). I hope I've given those who know something
about this enough information to narrow things down
for me.
I've got a couple of specific questions in addition to
the overall recommendations I hope will be
forthcoming:
- What electrical component do you think was making
the noise described in troubleshooting steps 1 and 2?
- It looks like there are separate parts for the left
and right landing gear squat switches; Is that true?
- From anyone out there has removed the entire Russian
electrical system and rewired new, how much time and
money did that take? Do you have a parts list for the
new system?
- Does anyone out there have an electrical diagram for
the Yak-50?
Many thanks in advance to everyone who's read this far
and to those who take the time to respond.
Harry
viperdoc(at)mindspring.co
PostPosted: Mon Sep 11, 2006 12:10 pm    Post subject: Yak-50 Electrical System Troubleshooting Reply with quote
Hitman,
I think Mark Bitterlich does. When I get home from the office today, I will
look at the CD that I have on 50 maintenance and let you know offline.
Doc
[Original Message]
To: Yaklist Yaklist <yak-list(at)matronics.com>
Date: 9/11/2006 1:48:14 PM
Subject: Yak-50 Electrical System Troubleshooting
All:
electrical system.
Symptoms:
the over-G light
seconds
one, I think
for me.
forthcoming:
new system?
the Yak-50?
Harry
Rob Rowe
PostPosted: Mon Sep 11, 2006 3:41 pm    Post subject: Re: Yak-50 Electrical System Troubleshooting Reply with quote
Hi Harry,
FWIW from what I know of the YAK-52 electrical schematics I'm hoping may extrapolate to your YAK-50 diagnostics.
The breaker switches for the gear & instruments are probably both 5 Amps ... so I'm assuming when you're quoting a 2-3 Amp draw you're reading this verbatim from the ammeter gauge. If so then be aware that this gauge reads "x 10" ... in which case you're seeing 20-30 Amps being drawn which is why the breaker cuts out.
From your general description of numerous problems occuring simultaneously I wonder if you have something loose in your relay box that holds the lamp test relay(s) ... causing shorts to various circuits ... so find the box labelled "РЕЛЕ ЩИТОК" or similar & take a look inside for anything loose, metallic & probably blackened!
Hope this helps.
Rob
mark.bitterlich(at)navy.m
PostPosted: Tue Sep 12, 2006 1:08 pm    Post subject: Yak-50 Electrical System Troubleshooting Reply with quote
Harry, I do not have a 50 electrical diagram (Doc if you have one, I'd
dearly love to get a copy), but I have traced out a lot of it, and most
of what I have seen duplicates the 52 in many ways. I am going to need
the full electrical diagram to help you out further, but I have a lot of
comments to make here. Also, please excuse my lack of tact, I am an
EA-6B Avionics Tech Rep by profession and I work on problems like this
ALL the time. There are a few general rules that you always go by when
dealing with this type of nonsense.
A. Always suspect what was last worked on as the FIRST place you should
look for a problem. If human hands have recently been involved anywhere
near wiring, and you now have an electrical problem that you never had
before... GO WHERE PEOPLE RECENTLY PUT THEIR HANDS AND LOOK THERE FIRST.
You'd be amazed at how often that rule is ignored out of simple ego, but
boy is it accurate!
B. If you are dealing with a system of wires, switches, lights, etc.,
always suspect any part that moves, like switches, as being the first
thing you check for failure.
C. NEVER EVER reset a circuit breaker more than once if it pops. You
NEVER, EVER EVER troubleshoot a problem like this by pulling this wire,
or that wire, and then turning on the breaker again to see if it pops.
There are many reasons for this, but the most obvious is that you can
easily end up starting an electrical fire, and please keep in mind where
the fuel tanks are in your YAK-50. For example, let's say a wire was
arcing out against your fuel tank. Not hard to imagine since it is only
inches away from your wiring. Each time you reset that breaker you get
an ARC. Eventually the arc actually cuts a hole in the tank and now you
have gas fumes adding into the mess. Explosion, fire, you name it. You
can also generate a wiring fire, even without gas involved. Bottom
line, stop doing that and never do it again... Please. Anyone that says
I am wrong in this regard is an idiot.... Avoid them.
Ok. So you now ask... How do I troubleshoot this problem WITHOUT doing
that? The answer requires you to have a grasp of the basics of
electrically, which you admitted that you do not have, but here we go, I
am going to teach you one trick now and anyone else who bothers to read
this.
You did exactly the right thing when you took the wires off the circuit
breaker/switch. You need to get an electrical meter and learn how to
read DC VOLTS with it. It's pretty easy. Set it to DC VOLTS, hook the
black wire to aircraft ground (any good bonding point in the aircraft
itself to the frame) and then use the red wire to touch a wire and read
voltage. Turn on your electrical master.. The one marked BATTERY. Now
look at the switch going to the gear. With the switch turned off, one
side will have 28 volts on it, and the other side will have NO volts on
it. The side with NO volts on it will be the one we want to mess with
first. In this case, you have already done that part... You have
located a wire that if you pull it off, it stops the problem. Luckily
nothing that we know of blew up in the process. God loves you.
What you need to do now is to learn how to troubleshoot to the next
step. One good way to accomplish this is by rigging the aircraft so
that it limits the current draw to this wire. The wire that you found
is going to a short circuit, and that is why the breaker is popping.
You need to locate some 28 volt light bulbs. If you do not have any, I
will send you some. Let me know. You get about a 25 watt bulb rated at
28 volts (again, I will be glad to give you as many as you need). You
solder two wires to this light bulb. Now, hook one wire of the bulb (it
does not matter which one) to the terminal on the switch. Hook the
other wire soldered to the light bulb to the wire that you have hanging
that used to connect to the switch.
Now when you turn on your switch, your light bulb will come on, because
you have a short to ground in the aircraft wiring SOMEPLACE. But the
circuit breaker/switch will NOT blow anymore, because the light bulb
that you just installed in series between the wire you pulled off, and
the switch itself, will limit the current to ONE AMP (plus or minus a
tiny bit). All the wiring and crap in the aircraft can handle one amp
with ease. If you want to lower the amount of current, just use a
smaller bulb... For example a 12 watt bulb would give you a maximum
current draw of about 1/2 amp. Current in this case will be equal to
the wattage of the bulb divided by the voltage.
You can now start trying to find the problem by tracing and removing
other wires, as you were doing before, or simply by jiggling things
around.
Some might recommend that instead of doing it this way, you simply use
an OHM METER connected to your wire that you pulled OFF the switch.
This will also work if you know exactly what you are doing, but the
light bulb trick makes finding a problem like this easier and it is an
ACTIVE versus a PASSIVE check. If the bulb is brightly lit, you have a
short circuit involved. Which is of course what you DO have. When the
bulb goes out, or gets very dim... You just located the problem.
You need to be more detailed with your explanation if you could please.
There are NO SQUAT switches in the YAK-50. A SQUAT switch is one that
closes when you LAND THE AIRPLANE and put weight on the landing gear.
The YAK-50 does not have anything like that.
Instead there are FOUR switches that control the landing gear lights on
the 50. One switch for each light on the dash. There are two switches
on the left side, and two switches on the RIGHT side. ONE SWITCH FOR
EACH LIGHT! You are only seeing the switch back behind the gear
actuator where the wheels go into the hole. There is ANOTHER switch
that is located underneath a panel right behind the gear leg itself.
The panel right behind that landing gear fiberglass shroud.
I do not know of any electrical motors behind the instrument panel.
There is of course the electrical inverter for the attitude indicator
(if you still have it installed) behind the seat. At this point, I
would not waste a lot of time looking for the weird noise... Since you
already have enough other weird crap already happening.
You took the fairings off the wing root(s) and have access to the wiring
connections going out to the pitot probe and the switches. REMEMBER
AGAIN... Two switches on each landing gear! Anyway, that is a good
thing. You might want to do the same for the other side too, so that
you can access that wiring, but I suspect the wiring short circuit is
not out there.
QUESTIONS:
What happens in the cockpit when you leave the instrument breaker OFF
and just turn on the landing gear breaker?
What happens when you turn on the instrument breaker and leave the
landing gear breaker off?
REALLY NEED TO KNOW THE ABOVE ANSWERS.
What is obvious here is that when you apply voltage to wire 05-cw2-01 by
connecting it to the switch and turning it on, the voltage through this
wire is shorting to some other WIRE that it should not be doing. The
problem is that this wire is also obviously the main voltage feed for
the landing gear circuits. The voltage on this wire feeds to all four
of the landing gear switches... The two UP switches and the two DOWN
switches. Wires coming back from these switches then go to the light
bulbs in the cockpit themselves and make them come on. So picture that
in your mind.... Voltage comes out this wire (the one hooked to the
switch), and someplace goes to a terminal board and splits to go out to
all four switches. It then comes BACK from those switches and goes BACK
into the instrument panel and to the lights themselves.
Next, consider that you have had a problem on the LEFT side of the
aircraft for quite some time. This has been a case where the landing
gear DOWN switch has probably gone bad or is out of adjustment. Again,
you need to locate that switch, because that is yet another problem,
probably not related to this current mess.
The short circuit you are dealing with is probably NOT in the wings.
When you pressed the switch on the right landing gear, and then the
light for the left gear lit up, this is not a case of a wire switched
around, this is a case of some wires that are SHORTED TOGETHER.
So some advice.
When describing what switches you are pushing in the future, make sure
you name them correctly. One is for right gear down and locked. One is
for right gear UP and locked. Same thing for the left side. No squat
switches ok?
It appears that the wire that is shorted is one of the wires coming BACK
from one of the switches TO the lights on the instrument panel. One of
THOSE wires has shorted to another wire or wires causing all the other
lights to come on. Most likely it is a short to the TEST SWITCH that
causes all those other lights to come on. So to repeat, this is
probably a dead short between one of the wires coming back from the
landing gear position switches, that is shorted to the TEST switch
WIRING.
To repeat again, the way I would try to find this would be to pull the
05-CW2-01 wire off the switch as you already had done. The install the
28 volt light bulb with the wires connected to it in series. It will
go: switch, wire, bulb, wire, then hooked to the 05-CW2-01 wire itself.
In SERIES. You will then limit the current draw and will pose little
to zero risk of blowing anything up any further. When you turn on the
switch, this light will come on brightly. If you want, you can put
plenty of wire on the bulb and remote it out of the cockpit so it does
not get in the way. Have someone watch this bulb like a hawk. Now get
your hands back in the wiring and start moving wires and wire bundles
around... All over the place. When you see that light bulb start
flickering wildly, you are on top of the problem.
A complete wiring diagram will be really handy. I do not have one.
HOWEVER... This is not a case of a failed component. This is a case of
some wires shorting together that were never meant to be. Wire
CHAFFING, or rubbing under a clamp, etc.
There is a very VERY small chance of a relay failing internally ...
Literally falling apart inside, and shorting everything out that could
cause this. This would be the light bulb TEST RELAY that is turned on
with the light test push button, and we would definitely need the
schematics to identify which relay this is. It is also possible that
this relay got fried during this failure. So other than wiring, this
would be the first component I would spot light for sure.
Harry.. You're out on the west coast aren't you?
Mark Bitterlich
N50YK
P.s. Rewiring the aircraft is a do-able thing, but man oh man, it would
cost a small fortune.
PostPosted: Tue Sep 12, 2006 4:15 pm    Post subject: Yak-50 Electrical System Troubleshooting Reply with quote
Good discription Mark, I am not an electrician/avionics guy by any sense of
the word. Took in physics and remember a thimb full. I will send you the
wiring diagram I currently have courtesy of Tim Gagnon. Credit be given
where due. Send me a fax # offline and when I get back to the office
tomorrow.
Doc
[Original Message]
From: Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E
<mark.bitterlich(at)navy.mil>.
To: <yak-list(at)matronics.com>
Date: 9/12/2006 4:18:49 PM
Subject: RE: Yak-50 Electrical System Troubleshooting
MALS-14 64E" <mark.bitterlich(at)navy.mil>
boy is it accurate!
this.
around.
not out there.
QUESTIONS:
So some advice.
switches ok?
WIRING.
Mark Bitterlich
N50YK
netmaster15(at)juno.com
PostPosted: Wed Sep 13, 2006 8:10 pm    Post subject: Yak-50 Electrical System Troubleshooting Reply with quote
Doc,
I would be most appreciative if you would fax me a wiring diagram of the electrical system. My fax is : 1 828 321 0878. Thankyou.
Cliff
tomorrow.
Doc
[Original Message]
boy is it accurate!
this.
around.
PostPosted: Thu Sep 14, 2006 8:16 am    Post subject: Yak-50 Electrical System Troubleshooting Reply with quote
Cliff,
Here is a emial version that is the same as the hardcopy that I have. Hope it helps.
Doc
Yak-50_Electrical_Sys.doc
 Filename:  Yak-50_Electrical_Sys.doc
 Filesize:  62 KB
 Downloaded:  637 Time(s)
Mike Bell
PostPosted: Thu Sep 14, 2006 8:33 am    Post subject: Re: Yak-50 Electrical System Troubleshooting Reply with quote
Damn, I'm glad Bitterlich works for OUR navy.
Mike Bell
Elk Grove, CA
avbell2(at)comcastdotnet
PostPosted: Thu Sep 14, 2006 9:09 am    Post subject: Yak-50 Electrical System Troubleshooting Reply with quote
Amen brother...glad he has such a grasp on the electrical systems of YAK's
also!
Doc
[Original Message]
Date: 9/14/2006 11:50:11 AM
Subject: Re: Yak-50 Electrical System Troubleshooting
Mike Bell
Yak 52
Elk Grove, CA
yakflyr(at)comcastdotnet
http://forums.matronics.com/viewtopic.php?p=61600#61600
PostPosted: Thu Sep 14, 2006 2:29 pm    Post subject: Yak-50 Electrical System Troubleshooting Reply with quote
Nice thing to say Mike, thanks. (!!!)
Mark
Rob Rowe
PostPosted: Fri Sep 15, 2006 10:50 am    Post subject: Re: Yak-50 Electrical System Troubleshooting Reply with quote
Hi Harry
First off I'd like to whole heartedly endorse Mark B's excellent advice on fault finding ... if you're uncertain of what you're doing then find someone qualified.
However they will probably find a set of accurate circuit drawings invaluable ... so I did a a little research into YAK-50s, courtesy of Russian Engineering who are only a half hour drive away, which highlighted the following;
- real-world feedback suggests YAK-50 electrics vary in detail from machine to machine & the schematics suggest an evolution of the DC power management in particular. I think the DC power diagram kindly supplied by Doc is "early" in that there does not appear to be any over-voltage protection [OVP] unit & the "controller RK-1500R" / "filter SF-3000R" are not types fitted to other YAK52/55s or SUs ... AFAIK). Doc - does your documentation have any date info?
- schematics dated 1979 show DC power components identical to a YAK-52 with an A3P-1MB OVP unit (assume as -52s went into production they started to standardise the fit)
- schematics dated 1982 show an A3P-A2 OVP the same as contemporary YAK/SUs (complete with hand drawn amendments!)
I d like to have copies of these schematics made (with RE's permission) ... the challenge lies in that they're probably 3rd imprints already & they're 2m x lm sheets ... so difficult to scan or photograph, let alone make legible.
So ... before looking into this further what's the full construction number of your -50 Harry?
Cheers, Rob
Scooter
PostPosted: Fri Sep 15, 2006 11:46 am    Post subject: Re: Yak-50 Electrical System Troubleshooting Reply with quote
Harry,
Could you clarify steps 6 through 8 again. I think the Yak-52 has two switches per gear leg (gear up and gear down... i think). Does the 50 have a single switch? Also, what is your current draw before you get the short?
Is this correct:
6. Left Gear Up/Right Gear Up - short
7. Left Gear Disconnected/Right Gear Up - no short
8. Left Gear Disconnected/Right Gear Down - short
"6. Friends manually held both landing gear position
switch broke to the off position after several seconds "
Rob Rowe
PostPosted: Fri Sep 15, 2006 5:52 pm    Post subject: Re: Yak-50 Electrical System Troubleshooting Reply with quote
Hi Harry,
I've annotated the attached PDF file from a photo of the YAK-50 gear & instruments circuits, as per the 01.10.1982 schematic.
The wiring nomenclature does not tie up with your description of the gear switch wires ... but most of the symptoms you described (save for the inverter turning on) suggest the lamp test relay"C10" is worth investigation by a qualified engineer.
A brief word of caution ... my experience of YAK wiring diagrams is that occasionally they contain typos and/or small wiring anomalies ... another reason to seek professional assistance with fault finding.
This schematic has such an anomaly on the far right hand side marked with the hatched red line & query mark ... don't think this is significant with your issues, but worth noting.
Cheers, Rob
YAK-50 Electrical Circuits.pdf
 Filename:  YAK-50 Electrical Circuits.pdf
 Filesize:  550.58 KB
 Downloaded:  759 Time(s)
PostPosted: Fri Sep 15, 2006 6:14 pm    Post subject: Yak-50 Electrical System Troubleshooting Reply with quote
Rob,
There is not a date on the manual. I have another question. As I rotated
today, my Airspeed went to 0. My altimeter worked fine. I have a Dynon
hooked in series with the Russian Airspeed indicator. The Dynon went to 0
also. Landed using A/S from the GPS. Works!
Plan to pull the rubber hose of the A/S indicator at the T fitting to Dynon
and blow high press back through the system. Before I do that, I am going
to drop the inspection panel in the left wing root and drain any water out
of the system if any is in there? Any other suggestions?
Doc
[Original Message]
Date: 9/15/2006 2:17:03 PM
Hi Harry
someone qualified.
the following;
make legible.
Cheers, Rob
http://forums.matronics.com/viewtopic.php?p=61838#61838
PostPosted: Fri Sep 15, 2006 6:15 pm    Post subject: Yak-50 Electrical System Troubleshooting Reply with quote
Rob,
Can you forward a cc of the wiring diagram also. My 50 is a 78 model though.
Doc
[Original Message]
Date: 9/15/2006 9:00:47 PM
Hi Harry,
Cheers, Rob
http://forums.matronics.com/viewtopic.php?p=61891#61891
http://forums.matronics.com//files/yak_50_electrical_circuits_151.pdf
Rob Rowe
PostPosted: Fri Sep 15, 2006 6:40 pm    Post subject: Re: Yak-50 Electrical System Troubleshooting Reply with quote
Hi Doc,
viperdoc(at)mindspring.co wrote:
As I rotated today, my Airspeed went to 0. My altimeter worked fine.
FWIW - looks like your static source is ok, but your dynamic feed is blocked / open to atmos ... given you've recently installed the Dynon guess that would be a good place to start checking the plumbing.
Careful with blowing high pressure into the either the static or dynamic lines (especially dynamic) without first double checking the instruments are disconnected ... could be expensive.
Re YAK-50 schematics - will email you the file shortly
Cheers, Rob
PostPosted: Fri Sep 15, 2006 7:54 pm    Post subject: Yak-50 Electrical System Troubleshooting Reply with quote
Thanks Rob. I plan to disconnect the dynamic (impact) line proximal to the
Dynon and the RU A/S indicator. That way they will be isolated from any
pressure applied to the impact line.
Doc
[Original Message]
Date: 9/15/2006 9:48:54 PM
Hi Doc,
Cheers, Rob
http://forums.matronics.com/viewtopic.php?p=61897#61897
PostPosted: Mon Sep 18, 2006 6:56 pm    Post subject: Yak-50 Electrical System Troubleshooting Reply with quote
Doc,
Schematic received, excellent, thanks very much.
Cliff
Cliff,Here is a emial version that is the same as the hardcopy that I have. Hope it helps.Doc ---
PostPosted: Tue Sep 19, 2006 4:19 am    Post subject: Yak-50 Electrical System Troubleshooting Reply with quote
Cliff,
From talking to Rob Kent, it is not complete. Seems our aircraft were kind of hand built and each one was somewhat different in each way. Later today, I will try to get you what he sent me in addition to what I had.
Doc
