goinghawgwyld(at)ssctv.ne Guest
Posted: Sat Sep 09, 2006 5:05 pm Post subject: Recent purchase questions |
I recently purchased a Kitfox III with a model 4 wing. What enhancements will this provide to me over the model 3 wing? This kit comes with a Rotax 912 80hp. What performance specs should I expect? I am looking forward to finishing this project. If there is anything else you feel I should know I would appreciate any input! Thanks again!
Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
Posted: Sun Sep 10, 2006 10:30 am Post subject: Recent purchase questions |
I'm not sure how much I can help. I don't know for sure what
enhancements you might realize. Possible gross weight increase. I have a
model 2 which I bought as a repair project. I had to buy a new spar and
I got the model 4 wing instruction section of the builders manual with
the newer spar kit. The important difference of the model 4 is the
struts are longer than the model 2 (which I believe model 2 and 3 are
the same, I may be wrong). So you must build the spars to position the
internal "I" beam correctly for the struts you have. Model 3 struts or
model 4 struts?
I'm not at home so I can't get the reference dimensions for you.
Perhaps someone else could tell us how far from the root to the strut
bracket mounting bolt or the length of the model 3 or 4 struts. I could
supply either construction sections for both M2 or M4 spars and wings by
the end of the week.
Rex
Colorado
goinghawgwyld(at)ssctv.net wrote:
| Quote: | I recently purchased a Kitfox III with a model 4 wing. What
Ken Schwartz
_________________ Rex
N740GP - M2/582
Colorado |
