heat box
gommone7(at)bellsouth.net
PostPosted: Thu Sep 07, 2006 9:31 am    Post subject: heat box Reply with quote
Hi all, does some body replace the aluminum heat box provide with the kit with an Stain. steel one,if so please can you share manuf. and model and how you like it.
Thanks, Hugo #40456
av8or(at)cox.net
PostPosted: Thu Sep 07, 2006 10:26 am    Post subject: heat box Reply with quote
I saw this vendor, EPM.VA Corp., at OSH2006 that had SS heater boxes. I'm not to that stage yet, but here's a link to there webpage: http://www.epm-avcorp.com/ssdiv.html
#40262
--> RV10-List message posted by: <gommone7(at)bellsouth.net (gommone7(at)bellsouth.net)>
Thanks, Hugo #40456
bldgrv10450(at)comcast.ne
PostPosted: Thu Sep 07, 2006 2:25 pm    Post subject: heat box Reply with quote
Hugo
Try these guys. I spoke with them and they seem willing to try new ideas and
work custom. They may be the guys that build Van's pipe fittings.
http://www.aviacompworldwide.com/connectors.html
Paul Grimstad
RV10 40450 fuselage
Portland, OR
bcondrey
PostPosted: Thu Sep 07, 2006 4:20 pm    Post subject: Re: heat box Reply with quote
I bought a set from EPM at Oshkosh, they are the same units that Avery sells. I don't have any installation pix handy but they form & fit identical to the aluminum units supplied in the kit.
Bob #40105
evmeg(at)snowcrest.net
PostPosted: Thu Sep 07, 2006 5:05 pm    Post subject: heat box Reply with quote
Yep...that is Don London and he is an outstanding guy. He builds for Vans
and spruce and Adam and Cirrus among others. I just spoke with him a bit
about this and he is doing a SS heat box as well as the directional vents
for the cabin heat. (you can select heat for one side or the other at will)
I don't think he is shipping them yet but he is supposed to be bringing me
some to look at next weekend at the Reno air races. I will let you fellows
know how they look if you are interested.
Evan
VHMUM(at)bigpond.com
PostPosted: Fri Sep 08, 2006 2:41 pm    Post subject: heat box Reply with quote
Guys I might have missed it but what is the advantage of a SS heat box
regards Chris
n223rv(at)wolflakeairport
PostPosted: Fri Sep 08, 2006 3:25 pm    Post subject: heat box Reply with quote
A SS heat box won't melt if you have an extreme thermal condition in the
engine compartment. That is why your firewall is also made of
stainless. So the question is, why have a SS firewall and drill a 3"
hole in it for heat and cover it with an aluminum heat box.....
PostPosted: Fri Sep 08, 2006 4:20 pm    Post subject: heat box Reply with quote
Fantastic and great info Thanks. I would think that if you had that much
heat you would have been in deep shit before it melted! Anyway good upgrade.
Chris
