experimental208nd(at)COMC Guest
Posted: Fri Sep 08, 2006 11:43 am Post subject: Kitfox Runs out of gas Please read on! |
Hi Guys,
Well just to let you know Jim and the passenger are OK.
He is a friend of mine and this is how it happened as he told me last night.
He did do a preflight , and had half full tanks in Both wings. He even
checked the caps before flight, But he thinks he did not put the right side
one on tight or at all. As it was missing at the landing site?
While flying he noticed the pilots side gauge had no gas in it, but the
right tank still had 1/2 left. No Problem they always read diff untill
settling after landing.
Then as they headed back a few min later the engine Stopped!
Tried the restart, called in emergency landing , and started the landing, at
1,500'. Not too high but better to be in a kitfox than a fast plane.
Made the landing but slid off the Bog into the smallriver that feeds the
bog.
No prop strike, engine was dead, no major damage, except fiberglass and
Pride.
Problem is: If the cap of the half full tank had come off, why was there
gas still in it??? I donot remember if he has the glass fuel filters off of
each tank?
I would assume the gas would siphon out fast. Maybe he had two probs, clog
in line and ran out of gas in the other wing.
He did not use auto gas with alcohol either, he filled up a week ago in NH
at an airport with their auto fuel with no alcohol.
They are still invesigating it.
But they are OK, I think that is the first thing to be concerned with, not
making jokes about someones life just because you do not know them.
Lets just learn from the accidents, ok.
Plus , he is a retired fighter pilot, so he also has a few hours under his
belt and he is not a low timer . Just for extra info.
Jay Fabian
4-1200 912UL
PS. What ever was the out come on the auto fuel / alcohol problem? we have
the up to 10% methanol in our gas here in Mass.
dave(at)cfisher.com Guest
Posted: Fri Sep 08, 2006 12:07 pm Post subject: Kitfox Runs out of gas Please read on! |
Jay,
Thanks for the report and good news that they are ok.
It can happen to anyone and sounds like a pretty good forced approach he
made and with little damage .
Dave
Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
Posted: Fri Sep 08, 2006 12:36 pm Post subject: Kitfox Runs out of gas Please read on! |
One other thing that irks me is the terms often thrown about by the news
media. On the video the term "nosedived into a cranberry bog" was used.
Obviously the aircraft damage was not consistent with what I understand
as a nosedive accident.
m-w.com defines "Nosedive" as:
*1* *:* a downward nose-first plunge of a flying object (as an airplane).
Maybe it's debatable, but I would have said "nosed over after an
emergency landing" as he had run out of roll out room before reaching
the water.
Well, what can you do when News folks don't bother to run their script
by even a low time student pilot for accuracy.
Rex
Colorado
Jay Fabian wrote:
<experimental208nd(at)comcast.net>
Hi Guys,
night.
side one on tight or at all. As it was missing at the landing site?
the right tank still had 1/2 left. No Problem they always read diff
untill settling after landing.
landing, at 1,500'. Not too high but better to be in a kitfox than a
fast plane.
the bog.
and Pride.
there gas still in it??? I donot remember if he has the glass fuel
filters off of each tank?
clog in line and ran out of gas in the other wing.
in NH at an airport with their auto fuel with no alcohol.
not making jokes about someones life just because you do not know them.
his belt and he is not a low timer . Just for extra info.
Jay Fabian
4-1200 912UL
we have the up to 10% methanol in our gas here in Mass.
_________________ Rex
N740GP - M2/582
Colorado |
occom
Posted: Fri Sep 08, 2006 12:52 pm Post subject: Kitfox Runs out of gas Please read on! |
kirkhull(at)sbcglobal.net Guest
Posted: Fri Sep 08, 2006 1:40 pm Post subject: Kitfox Runs out of gas Please read on! |
We had a Piper get caught in a wake behind a 767 ( I thank it might have
been something else)here in Kansas City about 8 or 9 months ago. On the
news report they said that " it was heard shifting gears and then it fell
out of the sky" . I'm still waiting for some one to show me where the gear
shift lever. It seems to be the case that most media outlets are more
interested in saying something fast rather then something correct or
intelligent.
mike Guest
Posted: Fri Sep 08, 2006 2:29 pm Post subject: Re: Kitfox Runs out of gas Please read on! |
Glad all is well with the pilot and passenger. Now to reilerate on the fuel caps. They are the last things I check before I get in the plane. In the last month I've had one cap that was off, forgot I put it in the window next to where the pin for the wing goes. Now this one will scare you guys, I had a cap that was not clipped on the second clip, if that makes sense. When I check the cap I always grap the vent end, this does two things, makes sure the cap is on right, forward, and if it's solid on the wiggle test, then both clips are secure. This cap wasn't, scared me, but then I was on the ground so all was well, removed the cap, reinstalled and went flying.
john(at)leptron.com Guest
Posted: Fri Sep 08, 2006 3:37 pm Post subject: Kitfox Runs out of gas Please read on! |
Jay,
Ok, to tell this story I have to admit that I, a man, perfect as I am, made
a mistake..... once, 2 years ago I flew out of the primitive area and
fueled at Salmon. While self fueling, I was talking, and well shooting the
bull. Some one else pulled up a bit close for me and I hurried to finish. I
remember that I left the passenger cap a bit loose or something. I was going
to go back to it after I put the hose down. Ok, I did not. After take off I
listened to other guys talk about debris on the runway. One asked what color
it was, one asked what it looked like, some one said it had a goose neck on
it and was chrome..... Duh, at the same time my fuel system was alarming
with bells that I had low pressure. Investigation showed almost 0 lbs of
pressure. My wife said there was a blue cloud on her side... ok crap... we
announced the part was ours and were returning, lord don't let us back
fire.... we lost 8 gal. In about 10 minutes, it sucked the fuel from the
wing with the cap on, and lowered the pressure to the point to alarm my
gages..... I assume this has happened today ...again..
John Oakley
mike Guest
Posted: Fri Sep 08, 2006 4:45 pm Post subject: Re: Kitfox Runs out of gas Please read on! |
John, what an experience. Do you have seperate shut off valves for each tank? I do and I usually pic a tank to run off of and shut the other one off. I wonder if that would prevent problems by turning off one tank and running on the other if the cap was missing. One thing I am serious about doing is putting a low fuel alarm on my header tank. Seems a wise thing to do now.
eskflyer(at)lvcisp.com Guest
Posted: Fri Sep 08, 2006 5:55 pm Post subject: Kitfox Runs out of gas Please read on! |
Thanks for the heads up . Very Glad both are ok . I do agree this is no
place to make jokes but to learn and not condemn . Hopefully he will have
the lady back in the air soon .
Fly safe fly low fly slow
John Perry
Kitfox 2 N718PD
582 But soon to be Subbie
TD and Straight Floats
neflyer48(at)cableone.net Guest
Posted: Fri Sep 08, 2006 5:58 pm Post subject: Kitfox Runs out of gas Please read on! |
I ran off without a gas cap a couple of years ago. After about 20 miles the
capless tank was running over and the tank with the cap on showed empty. I
made it to my destination OK. I'm sure the reason the capless tank ran over
is that the tank with the cap on is pressurized from the forward tube and
forced the gas over to the tank with no cap. (I don't have shut-off valves
between them).
Jerry Kohles M3,912
Posted: Fri Sep 08, 2006 6:05 pm Post subject: Kitfox Runs out of gas Please read on! |
OK OK OK i will tell one on Myself After refuleing the nose tank on my Mod
2 i set the cap on , then proceeded to fill the wing tank I did put that one
on good and tite and the vent pointing forward . A friend came by and we
talked for 5 min or so then i got in started up and taxied out on the take
off 150 into the roll the front cap left the plane and rolled to the side of
runway and the gas was being siphoned out up and over the windshield faster
than i could get her shut down . I thought she would burn with all that gas
dripping into and on the exhaust but some one was looking out for em that
day and i survived . after new windshield .
Preflight now says fuel first check caps on Last part of preflight says
Check fuel caps on . I think even i get complacent in my daily life and
things i do . so a written reminder is good .
John Perry
kitfox 2 N718pd
582 Soon to be Subbie
Posted: Fri Sep 08, 2006 9:26 pm Post subject: Kitfox Runs out of gas Please read on! |
Kitfox mike,
I firmly believe if I had a vent from the header tank, I would have gone
down with fuel in the tanks. I have since, been very wary of my fuel
systems; we lost several good people from our list the same way years ago.
John Oakley
pwmac(at)sisna.com Guest
Posted: Sat Sep 09, 2006 5:08 am Post subject: Kitfox Runs out of gas Please read on! |
John,
Can you or someone clarify. Please explain.
Vent from the header to one main tank is the standard design.
Did the forced landing have the standard fuel system with the header
behind the seat?
This design gives some small margin even with empty main tanks and
the low level sensor warns the pilot of impending fuel exhaustion.
Thanks, Paul
At 11:30 PM 9/8/2006, you wrote:
Kitfox mike,
John Oakley
Posted: Sat Sep 09, 2006 6:00 am Post subject: Kitfox Runs out of gas Please read on! |
Paul,
We have had discussions on the header tank vent many times on the web. I
have had several, just lately on this subject with a couple of our guys. We
lost several planes over the years due to fuel starvation and had full or
partial full tanks, I don't want to libel myself here, but do want to save
any of us from repeating accidents. I can't say what happened to the plane
this week, but do know that with a open header tank vent you can empty the
header and still have fuel on board. I believe we had problems earlier with
the loops in the hose from the tank (for wing folding) getting air in them,
causing the tank to unport. The header then emptied.
Valves in the lines to the header from the tanks will allow some degree of
trouble shooting in the air. These valves would have stopped the suction
from pulling fuel from both tanks. A valve in the header vent will be closed
in flight forcing the fuel to be pulled from one tank or the other as
controlled. You still have to worry about plugged tank vents or full
screens. I use a fuel pressure gage to help trouble shoot, it is a life
saver for me. I also have an electric booster under the seat that is my
comfort thing.
Sorry for the ramble, John Oakley
dosmythe(at)cox.net Guest
Posted: Sat Sep 09, 2006 6:10 am Post subject: Kitfox Runs out of gas Please read on! |
This might not apply but, is along the same subject line. I have a riding
lawnmower and the fuel system is "similar" to a kitfox. That is, has a
large tank above the engine and is gravity fed to the engine. Now, my
lawnmower will run 1/2 of the fuel in the tank and then, go dead (out of
fuel). This is observed by the completely empty inline fuel filter. It's
not the vented cap because it happens with the cap off????? If I pull the
tank side line off the filter, fuel again starts to flow from the tank,
refills the filter and off she runs again??? It has to be some sort of
vapor lock and wonder if some sort of similar situation could happen to a
Kitfox system. BTW, the lawnmower will use the whole tank if filled with
100LL. 100LL tends not to vapor lock like autofuel. I spend hours and
weeks testing my Fox fuel system to see what would conditions could cause
flow restrictions etc. This lawnmower system has me stumped.
Don Smythe
Posted: Sat Sep 09, 2006 6:58 am Post subject: Kitfox Runs out of gas Please read on! |
John,
This fuel thing used to be one of my favorite subjects. I am missing a
couple things you said. See below
rjdaugh
Posted: Sat Sep 09, 2006 7:22 am Post subject: Kitfox Runs out of gas Please read on! |
John,
If the fox that went down in the bog had a "standard" kitfox fuel system
with the header vented into one of the main tanks, I can understand what
happened. As someone already pointed out, if the cap is missing or leaking,
it will suck fuel out of the other tank and the engine should run until the
other tank is empty. This will leave the tank with the missing cap with
fuel in it.
When you talk of the header tank vent, do you mean with it vented to one of
the main tanks? Or elsewhere?
I don't understand how the header tank can empty and still have fuel in the
mains unless a cap is missing or the header tank is vented to somewhere
else.
This is an important issue.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
occom
Posted: Sat Sep 09, 2006 7:57 am Post subject: Kitfox Runs out of gas Please read on! |
It might be wrong to claim the "standard" design has one thing or another as
there are many iterations of the design. Mine has two 13? gal wing tanks and
a 2? gal header. The header tank has only a bleed vent that ends at the
firewall and is normally closed. This is exactly as documented in my manual
from '92.
Posted: Sat Sep 09, 2006 12:07 pm Post subject: Kitfox Runs out of gas Please read on! |
restricted line, bad fuel pump???
PW
At 08:08 AM 9/9/2006, you wrote:
riding lawnmower and the fuel system is "similar" to a kitfox. That
is, has a large tank above the engine and is gravity fed to the
engine. Now, my lawnmower will run 1/2 of the fuel in the tank and
then, go dead (out of fuel). This is observed by the completely
empty inline fuel filter. It's not the vented cap because it
happens with the cap off????? If I pull the tank side line off the
filter, fuel again starts to flow from the tank, refills the filter
and off she runs again??? It has to be some sort of vapor lock and
wonder if some sort of similar situation could happen to a Kitfox
and weeks testing my Fox fuel system to see what would conditions
could cause flow restrictions etc. This lawnmower system has me stumped.
Don Smythe
Thanks Don,
You are technically correct. and proved it by testing. Now I wonder
what the real story was about the forced landing. Maybe John can
expand his explanation?
Paul
At 08:58 AM 9/9/2006, you wrote:
John,
missing a couple things you said. See below
