Fox5flyer Guest
Posted: Fri Sep 08, 2006 3:14 am Post subject: Turtle deck vibration |
My S5 has always been a pretty smooth flyer. However, one thing that has always bothered me and is causing some wear is the turtle deck vibrating at cruise speeds, presumably due to some turbulent air. I can't hear it, but I can see it in the rear view mirror and the vibration is causing wear on the contact surfaces. I am thinking that perhaps some vortex generators might smooth out the air flow and help to either solve or ameliorate the problem. I think it might work, but I don't know where to place them. Has anybody tried this with any success?
Deke
lcfitt(at)sbcglobal.net Guest
Posted: Fri Sep 08, 2006 6:12 am Post subject: Turtle deck vibration |
Deke, I get a little bit of pulsing evident in the fabric under the wing
from time to time. I have attributed it to the prop pulses in the prop wash
area. Keep us posted on what you find out.
Lowell
Posted: Fri Sep 08, 2006 10:34 am Post subject: Turtle deck vibration |
Same with me Deke,
The only vibrating part seems to be the turtledeck.
I wonder if the air is seperating over the windscreen,
or the strakes on the side of the turtledeck are
vibrating in the turbulence from the draggy pocket
behind the aft spar. Maybe both. I'd like to attend
to both myself, when I get the time.
The VG's are easy to do. You can test them by taping
them down with enough good clear tape. Try them 6"
between pair centers. The pairs are 1" apart and set
17 degrees off in opposite directions, leading edge
closest. Run a straight edge parallel to the wing
leading edge 6" back and put the VG backs against it.
A cardboard template makes it easier to set the 17
degree angle and distances.
You can adjust the distance back from the leading edge
and test fly to get the best results. Somewhere
between 4" and 8" back should do it IMHO.
I expect to retire at the end of the year and maybe
fly all for fun then. Then I can do a lot more
of this fun testing stuff. Not there just yet.
Kurt S. S-5/NSI turbo
--- Fox5flyer <morid(at)northland.lib.mi.us> wrote:
| Quote: | My S5 has always been a pretty smooth flyer.
Deke
mino2(at)verizon.net Guest
Posted: Fri Sep 08, 2006 1:04 pm Post subject: Turtle deck vibration |
Deke,
I wonder if the glass area in the turtle deck had a slight bow to it, it
wouldn't oilcan and vibrate. I purchased mine, a one piece affair, an it
came with about a one inch crown on it. The instructions said it was to
keep it from vibrating. Can't be sure as I'm still not flying yet.
Fly safe,
Nelson
Lynn Matteson
Posted: Fri Sep 08, 2006 4:26 pm Post subject: Turtle deck vibration |
I got mine from LP Aeroplastics, and it is domed and does not vibrate.
Like you said, Nelson, it has about a 1" dome to the "glass". This
required that I remove the hinge, therefore the whole 'deck has to be
dealt with as an unbendable whole and not hinging it any more....but it
doesn't leak, either.
Lynn
Lynn
On Friday, September 8, 2006, at 05:03 PM, Nelson Goguen wrote:
Deke,
it wouldn't oilcan and vibrate. I purchased mine, a one piece affair,
an it came with about a one inch crown on it. The instructions said
it was to keep it from vibrating. Can't be sure as I'm still not
flying yet.
Fly safe,
Nelson
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Fox5flyer Guest
Posted: Sat Sep 09, 2006 3:28 am Post subject: Turtle deck vibration |
Thanks Kurt. I suspect most of them vibrate, but the pilot just doesn't
know it. It isn't bad. It just vibrates enough that it causes black dust
around the edges where it contacts the wings. Perhaps this winter when I
have the time and the airplane is down for annual I can conjure up
something. I'd like to do the VGs across the whole wing, but I'm concerned
about the loss of speed. That's about the only thing that's held me back.
Deke
Same with me Deke,
> Deke
Fox5flyer Guest
Posted: Sat Sep 09, 2006 3:51 am Post subject: Turtle deck vibration |
Thank you Nelson. You're probably correct because a slight bow would give
the turtle deck a small amount of lift thereby putting some constant tension
on it. My turtle deck is in great shape and I'm not quite ready to replace
it yet so I'm considering the VGs first to see what will happen. My gut
feeling is that it will work.
Deke
Deke,
Fly safe,
Nelson
dave(at)cfisher.com Guest
Posted: Sat Sep 09, 2006 3:58 am Post subject: Turtle deck vibration |
Deke ,
I have a vibration at run up on turtle deck but nothing in flight. I
have Vgs in shop but have not used yet.
Kitfox IV works good now with full elevator authority and great slow speed
performance. But my Kitfox is about 550 lbs so the weight helps alot.
I think I will try them some time as well. I have heard that a few vgs
placed on the back of the windshield near the turtle deck will stop the
vibrations.
I have harrison designs ones here . You can get I think 100 of them for ?
under 100$ ithink. Plus just try with 2 sided carpet tape.
Dave
Posted: Sat Sep 09, 2006 4:57 pm Post subject: Turtle deck vibration |
Hi Deke,
When I tested the VG's on my plane 2 years back, I
found that the max speed varied a bit with position.
Closer to the leading edge seemed to have no speed
loss, while further back did cost a few knots. This
is why I suggested a max of 6" back. My worst loss in
max speed was about 5 knots on a further aft position.
The VG stalls were much more controlled in that I
could cross control or use considerable rudder and
still fly the plane in the stall without uncontrolled
fall off to a side. That alone made the VG's a good
deal to me. If you inadvertently stall it, nothing
real scarry happens and recovery is even easier than
usual for a KF. It makes slow flight and short field
work much more secure.
Unfortunately I got no significant reduction in stall
speed from them. I'll test again in the future with
some enhanced elevator authority and see if that
helps.
But I wouldn't let any worry about cruise speed loss
stop you. You can test several positions and use the
one that works best without more than a knot
difference in max speed.
Now cleaning the wing.... that will be a little
harder.
Kurt S.
......I'd like to do the VGs across the whole
| Quote: | wing, but I'm concerned about the loss of speed.
Deke
Fox5flyer Guest
Posted: Sun Sep 10, 2006 3:54 am Post subject: Turtle deck vibration |
Thanks for the feedback Dave. Do you have a url for Harrison Designs?
Deke
Fox5flyer Guest
Posted: Sun Sep 10, 2006 4:04 am Post subject: Turtle deck vibration |
Thanks Kurt. I definitely don't want to lose 5 kts, nor even 1 kt if I can
get away with it. However, I can probably live with one kt if it has a good
enough trade off. Lowering stall speed is always a good thing and making
the airplane more controllable close to stall is equally good. Actually my
S5 is pretty good at low speeds, but it's always better if I can gain a
little more without the top end loss. I know, there's almost always a trade
off somewhere. One just has to decide what one can live with.
Deke
From: "kurt schrader" <smokey_bear_40220(at)yahoo.com>
| Quote: | Hi Deke,
helps.
harder.
Kurt S.
.......I'd like to do the VGs across the whole
> Deke
Posted: Sun Sep 10, 2006 4:15 am Post subject: Turtle deck vibration |
http://www.landshorter.com/
