Scratch built Spars
ter_turn(at)yahoo.com
PostPosted: Thu Sep 07, 2006 7:48 pm    Post subject: Scratch built Spars Reply with quote
A while back someone asked for a picture of a Spar being scratch built. Here's on my Grandson is working on:)
Terry Turnquist
601 XL Plans
St. Peters, MO
 Filesize:  588.81 KB
 Viewed:  339 Time(s)
TxDave
PostPosted: Fri Sep 08, 2006 6:51 am    Post subject: Re: Scratch built Spars Reply with quote
Hey Terry,
I was the guy making the inquiry about scratch building spars. Thanks for sharing the photo. I'm to the point of deburring all those many, many holes. Any advice you have to offer would be appreciated.
Dave Clay
Temple, Texas
Ch601XL Scratch Builder
http://www.daves601xl.com
VideoFlyer(at)aol.com
PostPosted: Fri Sep 08, 2006 8:32 am    Post subject: Scratch built Spars Reply with quote
In a message dated 9/8/06 dclaytx2(at)HOTMAIL.COM writes:
Start deburring!
hrs1(at)frontiernet.net
PostPosted: Fri Sep 08, 2006 9:18 am    Post subject: Scratch built Spars Reply with quote
Check the archives regarding a special type of file - the name might be
a Vixen (somebody have the exact name?). It has curved ridges and
lightly rubbed against the line of rivet holes, takes a lot of the rough
stuff off. Then deburr in the normal manner with a drill point, etc.
Robert Schoenberger 701
Start deburring!
grs-pms(at)comcast.net
PostPosted: Fri Sep 08, 2006 12:17 pm    Post subject: Scratch built Spars Reply with quote
Yes, it's a vixen. (This is a reference to a type of file, not to a foxy
stripper from NAPA.) If you can't find a vixen file, try a laminate file.
They are made for use on Formica-type laminates, but they do a good job on
aluminum.
George
mgraves(at)usmo.com
PostPosted: Sat Sep 09, 2006 3:07 am    Post subject: Scratch built Spars Reply with quote
use a short vixen file or a dog leg de burr tool.. I prefer the
latter, to each his own.
http://www.yardstore.com/index.cfm?action=ViewDetails&ItemID=118&Category 5
Its item number14031 if the link doesn't work
Monty
At 07:51 AM 9/8/2006 -0700, you wrote:
Hey Terry,
Dave Clay
Temple, Texas
http://forums.matronics.com/viewtopic.php?p=60357#60357
