dcsfoto
Posted: Thu Aug 31, 2006 6:44 pm Post subject: Jabiru 2200 conversion |
I have a Rotax 912 14 yr old and want to swap to a 2200 Jabiru at overhaul time.
Has anyone done this on a MIII round cowl ? how hard is it to do
mdps_mc(at)swoca.net Guest
Posted: Fri Sep 01, 2006 3:28 am Post subject: Jabiru 2200 conversion |
I did this conversion on a Model IV. The cowling work is the most
difficult. I left the aft cowling pretty much the same except for a little
bit of work on the aft bottom cowling in the exhaust area. I had to extend
the round bump cowling about five inches and widen it by splitting the top
and bottom in half. This past winter I made a brand new bump cowling which
took considerable time but it does look really nice. I have a few pics on
the Jabiru USA website.
algate(at)attglobal.net Guest
Posted: Fri Sep 01, 2006 4:10 am Post subject: Jabiru 2200 conversion |
Hi
Here are a few photos of the cowl on my Model4 with Jab 2200.
The main changes on this installation relate to a bump on the Pass side
front cowl (about 4" x 2" to clear the No.1 rocker cover and cut outs in the
ring cowl to fit the inlets in the to ram air ducts. The rest of the front
opening is closed using clear lexan so that the cowling is not pressurized.
There is also additional opening and some aluminum fairings in the bottom of
the cowl to allow sufficient air flow through the cowl.
Like Michel my CHT and oil temps run on the low side of recommended
operating range.
If you would like more detailed photos I would be happy to send them off
line
Gary Algate
Model4 Jab2200
time.
46.69 KB |
503 Time(s) |
34.37 KB |
502 Time(s) |
67.29 KB |
528 Time(s) |
Malcolmbru(at)aol.com Guest
Posted: Fri Sep 01, 2006 5:26 pm Post subject: Jabiru 2200 conversion |
the pics are cool BUT tell me more about the hanger. can I get one? mal
clint_bazzill(at)hotmail. Guest
Posted: Sat Sep 02, 2006 10:23 am Post subject: Jabiru 2200 conversion |
Hi, I looked at the pictures, nice. I thought that the Jabiru turned the
opposite to normal engines. Your picture shows a normal turning prop.
Clint
Subject: RE: Jabiru 2200 conversion
Date: Fri, 1 Sep 2006 08:12:37 -0400
Hi
operating range.
line
Gary Algate
Model4 Jab2200
time.
<< IMG_1237.jpg >>
<< kitfox020.jpg >>
<< MiscNewplane038.jpg >>
Michel
Posted: Sat Sep 02, 2006 10:55 am Post subject: Jabiru 2200 conversion |
On Sep 2, 2006, at 8:22 PM, Clint Bazzill wrote:
| Quote: | Hi, I looked at the pictures, nice. I thought that the Jabiru turned
the opposite to normal engines. Your picture shows a normal turning
prop. Clint
Indeed, the Jabiru turns in the "normal" way, that is, you have to
press right pedal when you take off. The only engines that turn the
prop the other way are the two-strokes Rotax, as far as I know. Another
thing that is "normal" with the Jabiru is that, if the throttle cable
breaks, a spring will keep the carburettor to WOT, and not idle like
the 582.
Michel
Lynn Matteson
Posted: Mon Sep 04, 2006 4:29 am Post subject: Jabiru 2200 conversion |
Wow, Gary, I was just looking at the heads on your engine, and noticed
how much more fin area I have around the exhaust pipe. Mine is the
newer engine, with larger heads, but I never realized how MUCH larger
'til I saw your engine. I had never seen a picture of the earlier
engine 'til now.
Lynn
On Friday, September 1, 2006, at 08:12 AM, Algate wrote:
| Quote: | Hi
in the
front
pressurized.
bottom of
operating range.
off
line
Gary Algate
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Tue Sep 05, 2006 7:28 am Post subject: Jabiru 2200 conversion |
Lynn
I haven't seen the newer model Jab so I don't know what to compare with. My
CHT's run at around 298 F at cruise during summer, so if you have more fin
area you must have great temps.
As mine is a tail dragger my oil level is pretty difficult to set so I have
been gradually increasing to get a reading mid way between the high and low
mark on the stick. On the weekend I went for a flight and it emptied about a
pint of oil into the overflow canister and the belly of my plane.
I ended up dumping all of the oil and refilling it with correct capacity but
it hardly registers on the dip stock when standing "3 point".
I checked with the Jab dealer in Canada and he said that this is a common
occurrence if you overfill the oil.
Just when I had become really confident in the engine. Oh well
Gary Algate
Classic 4 Jab2200
re
engine 'til now.
Lynn
Michel
Posted: Tue Sep 05, 2006 8:23 am Post subject: Jabiru 2200 conversion |
On Sep 5, 2006, at 5:31 PM, Algate wrote:
| Quote: | As mine is a tail dragger my oil level is pretty difficult to set so
I have
and low
mark on the stick.
With my model 3 and Jabiru 2200 (SN. 1665), I need only a tiny drop at
the end of the dipstick, in taildragger down position, Gary. Any excess
of that ends up in the recovery bottle, anyway. With my "drop at the
end of the stick" I fly many hours without needing more oil.
Michel
Posted: Tue Sep 05, 2006 9:59 am Post subject: Jabiru 2200 conversion |
Thanks Michel
It's a shame that they haven't come up with an extended dip stick for tail
dragger installations.
Gary
Michel
Float Flyr
Posted: Tue Sep 05, 2006 2:23 pm Post subject: Jabiru 2200 conversion |
I guess that is the advantage of the dry sump engine. Put on a set of
floats ....no probs.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Tue Sep 05, 2006 7:59 pm Post subject: Jabiru 2200 conversion |
Gary-
When I initially filled my engine, I used the (then) figure of 2.2
quarts (US), and filed a notch on the dipstick when the oil had settled
and leveled off. This is where I have flown for 140 hours on the
plane...with the obvious oil changes of course. I get some oil
collecting in the canister, but have not measured it. I have dumped it
when it gets about halfway full, which has happened a couple of times.
Mine is a taildragger too, and my installation instructions said to
re-calibrate the stick for 'draggin'.
My CHT's have always been under the max...I have an EIS so I just set
the top end parameters and let it go at that. Trying to recall any high
end temps...just can't recall the particular numbers...too many other
things to keep track of, as I'm still learning to fly and that keeps my
attention for the most part. But I'll make it a point to record some
numbers tomorrow....never over 300 F, that's for sure.
Go to Pete's (or Andy's I think) website and look at the engine
pictures there, and you'll see how much fin they added around the
exhaust pipe area, and maybe some on top too.
Probably better temps with the larger/newer heads, but the Economy
Tuning (lean burn) added some temperature, I'm sure...it sure did to
the EGT.
Lynn
p.s. Since I first filled my engine with oil, I have seen figures of
2.3 US quarts , and 2.43 US quarts, so what's a guy to believe?
On Tuesday, September 5, 2006, at 11:31 AM, Algate wrote:
Lynn
with. My
fin
I have
and low
about a
capacity but
common
Gary Algate
Classic 4 Jab2200
re
engine 'til now.
Lynn
N369LM |
Michel
Posted: Tue Sep 05, 2006 10:31 pm Post subject: Jabiru 2200 conversion |
| Quote: | From: Lynn Matteson [lynnmatt(at)jps.net]
Lynn, it could be with or without the oil cooler. I also have two figures in my manual, but in liters: 2 liters and 2.3 liters . But when changing oil, you can't empty the cooler so it is 2 liters I use.
Michel
smokey_bear_40220(at)yaho Guest
Posted: Tue Sep 05, 2006 10:49 pm Post subject: Jabiru 2200 conversion |
Same problem with my NSI engine in a TD aircraft. I
bought a new Soob dipstick this summer to fix that. I
don't mind being a cup or so low, but it would not
show on the old stick. Didn't know if it was a tad
low or empty, so now I can see every quart.
Kurt S.
--- Algate <algate(at)attglobal.net> wrote:
| Quote: | Thanks Michel
Gary
only a tiny drop at
my "drop at the
more oil.
Michel
Lynn Matteson
Posted: Thu Sep 07, 2006 2:32 pm Post subject: Jabiru 2200 conversion |
I just changed my oil today, Michel, and just to be contrary, I
disconnected the lower oil cooler line and drained the cooler, too.
Don't know how much I got out, but it made me feel better to try. On
start-up, I cranked a bit with the mags off until I saw pressure.
Lynn
On Wednesday, September 6, 2006, at 02:30 AM, Michel Verheughe wrote:
| Quote: | > From: Lynn Matteson [lynnmatt(at)jps.net]
Michel
www.matronics.com/Navigator?Kitfox-List</a>
contribution</a>
</b></font></pre>
N369LM |
Michel
Posted: Thu Sep 07, 2006 10:00 pm Post subject: Jabiru 2200 conversion |
On Sep 8, 2006, at 12:33 AM, Lynn Matteson wrote:
| Quote: | I just changed my oil today, Michel, and just to be contrary, I
Of course, it can be done, Lynn. But, if I remember correctly, the user
manual doesn't say that it should be done. I guess, when you change
oil, you always have a bit of the old one left. By disconnecting the
cooler, you certainly did a better job than me, my friend. I will do
the same as you at the next oil change.
Michel
