owl40188(at)yahoo.com Guest
Posted: Sun Jan 22, 2006 7:49 pm Post subject: Longeron holes for rudder pedal support blocks. |
Looks like I had another temporary brain shutdown. I miss drilled the six longeron holes that are used to hold the rudder pedal support blocks. Vans instructions say to cleco the jig on to the forward most holes on the longeron and drill the 6 rudder pedal support holes. Actually just clecoing is not enough, one has to align the edge of the jig with the edge of the longeron. Thats where I went wrong. I believe only three holes are needed. The other three holes are for a more aft placement of the rudder pedals (about 1 1/4 inches). I am planning on drilling a third set of holes between these two sets. It appears that I would have enough room however I would lose the adjustability. Since I am 5'7" I figured the middle position might actually fit me well.&nb sp; Any comments or suggestions on this are appreciated.
Niko
40188
dlm46007(at)cox.net Guest
Posted: Sun Jan 22, 2006 8:16 pm Post subject: Longeron holes for rudder pedal support blocks. |
Better check with Van's ; You appear to be making Swiss cheese of the main structural piece in that area.
