europa(at)pstewart.f2s.co Guest
Posted: Wed Sep 06, 2006 10:52 am Post subject: prop bolts |
Anyone got a top tip for torquing up the prop bolts (Airmaster CS /
914 combo) - I can't get a socket and torque wrench on straight
without fouling on the gearbox housing.
Paul
G-GIDY
Dave Miller
Posted: Wed Sep 06, 2006 11:55 am Post subject: prop bolts |
Paul,
For my Woodcomp prop I used a "crowsfoot" open ended socket ( from an auto supply store), and adjusted the torque
setting for the extra length of the socket.
Dave C-FBZI
Paul Stewart <europa(at)pstewart.f2s.com>
Sent by: owner-europa-list-server(at)matronics.com
09/06/2006 02:52 PM
Please respond to europa-list
To: "europa-list(at)matronics.com" <europa-list(at)matronics.com>
cc:
Subject: prop bolts
--> Europa-List message posted by: Paul Stewart <europa(at)pstewart.f2s.com>
Paul
G-GIDY
ward.t(at)xtra.co.nz Guest
Posted: Wed Sep 06, 2006 11:59 am Post subject: prop bolts |
Paul,
Make your own torque wrench as I did for the airmaster prop as I had the
same problem.
Bolt the correct spanner size to a piece of 'U' aluminum to take it
exactly to 1 foot length from the bolt to the end. Drill a hole at the other
end and with a spring weight (hardware stall) tighten up the bolt to the
correct torque through the weight at 90 degrees. Very accurate.
Keep the tool as you will need it in the future!!
Cheers,
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Ph +64 3 3515166
Mobile 021 0640221
Posted: Wed Sep 06, 2006 3:40 pm Post subject: prop bolts |
Paul
I can lend you a crow'sfoot if you need one?
Graham
Paul
G-GIDY
Posted: Thu Sep 07, 2006 12:00 am Post subject: prop bolts |
Thanks for the tips - Graham I may well take you up on the offer when
we get back from France.
Paul
On 7 Sep 2006, at 00:41, Graham Singleton wrote:
Quote: |
<grahamsingleton(at)btinternet.com>
Paul
Graham
> CS / 914 combo) - I can't get a socket and torque wrench on
> straight without fouling on the gearbox housing.
> Regards
> Paul
> G-GIDY
sidsel.svein(at)oslo.onli Guest
Posted: Thu Sep 07, 2006 8:59 am Post subject: prop bolts |
Paul,
1. Set the torque limit on the torque wrench in the normal way.
1. Use a fixed spanner on the prop bolt.
2. Use a transition piece for the torque wrench that goes into the other end
of the spanner.
3. Orientate the torque wrench so that its handle is 90 degrees (right
angle) to the spanner.
4. Apply force on the torque wrench handle at 90 degrees to the handle, i.e.
straight out, i.e. parallel to the fixed spanner.
5. The torque thus created at the "other end of the spanner" transfers along
the length of the spanner and onto the prop bolt.
As you apply the force/torque, the prop. bolt will turn and you then simply
follow with it, i.e. maintain your hand force parallel with the spanner.
Re. 2 above: Alternatively, use the "open" end of the spanner on the prop
bolt and put a suitably sized bolt (one that the torque wrench will fit
onto) through the "star" end of the spanner, with a nut tightened hard on
the other side.
I have attached (I hope it comes through!) a rough sketch illustrating the
principle.
Good luck!
Svein
A225 - now in Norway
Quote: |
Anyone got a top tip for torquing up the prop bolts (Airmaster CS / 914
combo) - I can't get a socket and torque wrench on straight without
Paul
G-GIDY
Description: |
 Download |
Filename: |
Torque.pdf |
Filesize: |
34.39 KB |
Downloaded: |
216 Time(s) |
Posted: Thu Sep 07, 2006 10:20 am Post subject: prop bolts |
Thanks for the ingenious solutions
Paul
other end of the spanner.
(right angle) to the spanner.
handle, i.e. straight out, i.e. parallel to the fixed spanner.
transfers along the length of the spanner and onto the prop bolt.
then simply follow with it, i.e. maintain your hand force parallel
with the spanner.
the prop bolt and put a suitably sized bolt (one that the torque
wrench will fit onto) through the "star" end of the spanner, with a
nut tightened hard on the other side.
illustrating the principle.
Good luck!
Svein
> Regards
> Paul
> G-GIDY
> <Torque.pdf>
rowil(at)clara.net Guest
Posted: Fri Sep 08, 2006 5:12 am Post subject: prop bolts |
At 2006-09-07 18:58 +0200 Sidsel & Svein Johnsen wrote:
Svein - your diagram is excellent and clearly shows what you mean to
do - but I'm having trouble understanding how this ensures correct
torque at the prop bolt.
Initially, I thought it was fine, but when I try to analyse what is
happening in terms of the forces that are being applied at various
points, I don't seem to be able to extract a sensible answer.
I also imagined a different geometry - such as the torque wrench in
line with the ring spanner - and it seems that wouldn't work unless
the torque setting was adjusted to allow for the relative lengths of
the torque wrench and spanner.
Can you (or anyone else) offer an explanation of why the 90-degree
geometry works?
regards
Rowland
| Rowland Carson PFA #16532 http://home.clara.net/rowil/aviation/
| 750 hours building Europa #435 G-ROWI e-mail <rowil(at)clara.net>
kheindl(at)msn.com Guest
Posted: Fri Sep 08, 2006 12:54 pm Post subject: prop bolts |
I have seen a licenced aircraft engineer do same on my aircraft. It makes
sense to me, but I guess someone could provide the mathematics. My Woodcomp
nuts are 1/2 inch, and the torque wrench can also be set up for 1/2 inch.
The open end then of a common garden wrench fits onto the torque wrench, and
the other end fits onto the nut. Torque is then applied at right angle.
Karl
Quote: | From: Rowland Carson <rowil(at)clara.net>
Reply-To: europa-list(at)matronics.com
Subject: Re: prop bolts
Date: Fri, 8 Sep 2006 11:00:01 +0100
>principle.
Svein - your diagram is excellent and clearly shows what you mean to do -
but I'm having trouble understanding how this ensures correct torque at the
prop bolt.
happening in terms of the forces that are being applied at various points,
I also imagined a different geometry - such as the torque wrench in line
with the ring spanner - and it seems that wouldn't work unless the torque
setting was adjusted to allow for the relative lengths of the torque wrench
and spanner.
Can you (or anyone else) offer an explanation of why the 90-degree geometry
works?
regards
Rowland
Posted: Fri Sep 08, 2006 1:44 pm Post subject: prop bolts |
Quote: | Can you (or anyone else) offer an explanation of why the 90-degree
geometry works?
Apologies for replying to my own post, but the penny has finally dropped!
Consider (as they say in all the best textbooks) a virtual lever
going diagonally from the handle end of the torque wrench to the
centre of the prop bolt. This will be longer than the actual torque
wrench, but the component of force effective at right angles to its
axis will be smaller than the force exerted by the operator, in the
exact proportion required to apply the required torque to the prop
bolt.
All I had to do was remember that the torque-wrench & spanner
assembly is a rigid body (at least until the torque wrench clicks)
and sketch the components of the operator force. Sorry to be so slow
on the uptake, and apologies, Svein, for casting doubt on your
suggestion!
regards
Rowland
Posted: Fri Sep 08, 2006 10:34 pm Post subject: prop bolts |
Rowland,
You did not cast doubt on my suggestion, you only wanted to be certain that
you fully understood what you might be doing to your aircraft!
Your looking at the set-up as one rigid unit explains it in
easier-to-understand terms than if I had started explaining how a bending
moment (the torque) applied at one end of a cantilevered beam (the spanner
placed on the prop.nut) without any transverse force (since your hand pull
is axial on the spanner) sets up the same bending moment at all points along
the length of the beam and at its fixed end, i.e. onto the prop. bolt.
Your way of looking at it prompts one word of caution, however: It is
important to apply the hand force parallel to the spanner. If applied at an
angle, the transverse (to the spanner) component of this force acts at the
outer end of the spanner (where the torque wrench is affixed), giving an
additional torque moment on the prop.bolt (equal to the transverse force
component multiplied by the spanner length). This is the reason for
recommending that the torque wrench is orientated at right angle to the
spanner before you begin to apply hand force - it is natural to pull on the
torque wrench handle at right angle and thus the pull is approximately
Best regards,
Svein
philipgeorge347(at)hotmai Guest
Posted: Sat Sep 09, 2006 2:46 am Post subject: prop bolts |
Rowland I was at one time a Snap on tools dealer and Snap on used to
produce a chart for use with torque adaptors for use in this situation ie.
any adaptor offsetting the torque length as used on for example . V12 Jag
cylinder heads when the casting overhangs the head bolts . the angle that
the torque wrench is pulled makes no difference (unless someone corrects me)
any Snap on dealer should be able to supply the chart . Philip George
>principle.
prop bolt.
and spanner.
works?
regards
Rowland
BEBERRY(at)aol.com Guest
Posted: Mon Sep 11, 2006 10:16 am Post subject: prop bolts |
Inexperienced as I am (1 year with a Europa) perhaps I can ask more advice.
Today I wheeled my 914 out of the hangar for the first time in a good few weeks (having been away for some time) and immediately I noticed a slight clear oil drip from the air box breather pipe.
Engine was not started until later (ran beautifully) so I am puzzled at why this should happen. The engine has been dry as a bone until now but has not been run for some two months.
Comments please.
Patrick
hurstkr(at)growzone.com.a Guest
Posted: Mon Sep 11, 2006 7:17 pm Post subject: prop bolts |
Quote: | Sorry to be so slow on the uptake, and apologies, Svein, for casting doubt
on your suggestion!
Rowland,
If it makes you feel any better, I'm glad you asked the question. I have
known for some time (since purchasing my Airmaster) about the spanner trick
but didn't understand how (or why) it worked.
The diagram posted by Svein and your second posting combined sorted it out
for me so I am pleased to be able to say I now understand the principle and
conseqently will now be able to remember it.
I just wasn't game to ask for fear of getting foot in mouth disease.
So thanks again Rowland and to you too Svein.
Kingsley in Oz.
Posted: Tue Sep 12, 2006 12:02 am Post subject: prop bolts |
Svein
Many thanks for your solution - torqued up the airmaster last night
no problem at all. Even did a bench test with and without the
spanner just to get the 90 degree pull correct.
Paul
G-GIDY
Posted: Tue Sep 12, 2006 7:52 am Post subject: prop bolts |
Paul: Glad to be of help.
All: If for some reason you should find the 90 degree orientation awkward
for some application, where the spanner and wrench in straight line would be
better, here's the equation to use for setting the adjusted torque limit on
the wrench if you do not have a table for your wrench:
Twa = T x Lw / (Lw + Ls)
where
Twa = adjusted torque wrench setting
T = specified torque for the bolt
Lw = length of the torque wrench (from center of connection to the spanner
to the middle of the grip of your hand)
Ls = length of spanner (from center of bolt to center of connection to
wrench)
Examples: Wrench and spanner of equal length then set wrench to 1/2 of the
specified torque.
Wrench twice the length of the spanner then set wrench to
2/3 of the specified torque.
Again: Direction of your pull vs. wrench is not an issue (need not be 90
degr.), but the spanner and the wrench must be aligned. Somewhat sensitive
to where your grip is on the handle, but if you mark with tape or felt pen
and measure to the middle you should be all right for the applications in
question.
Best regards,
Svein
DuaneFamly(at)aol.com Guest
Posted: Tue Sep 12, 2006 8:08 am Post subject: prop bolts |
Svein and Others,
I'm not sure I agree with this method. I don't think the torque wrench knows how long a handle is exerting the force. I think that it will still "click" at the setting you set it at. If the proper setting is 50 inch lbs (EU's have to do the conversion) and you set it the torque wrench for 25 inch lbs, then the wrench is going to click when you have 25 inch lbs exerted on it. And your bolt is only torqued to 25 inch lbs, not 50. Making the handle longer only allows you to have to exert 1/2 the pressure to get that 50 inch lbs to the torque wrench.
Am I missing something here?
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300
Sensenich R64Z N
Ground Adjustable Prop
Posted: Tue Sep 12, 2006 9:45 am Post subject: prop bolts |
Mike,
Yes, with respect - assuming you refer to the "spanner and wrench in straight line" method:
Conider the case when you set the torque for 25 in lbs:
- Assume that the wrench is 10 in long (distance from grip to attachment to spanner)
- A fraction of force before the wrench clicks, the pull then is a fraction less than 2.5 lbs (10 in x 2.5 lbs = 25 in lbs)
- Assume that the spanner also is 10 in long.
- Just before the wrench clicks, the force of 2.4999999 lbs has a lever of 10 in (wrench) + 10 in (spanner) = 20 in on the bolt, i.e. a torque of 20 in x 2.5 = 50 in lbs.
- Look at it this way: Just before the wrench clicks, the set-up does not know that it is about to break. There is therefore only one stiff piece between your pull of 2.5 lbs and the bolt, and that piece is 20 in long. Using a torque wrench as an extension to the spanner limits your maximum pull, you might say, in this case to 2.5 lbs so that the torque on the bolt cannot exceed 50 in lbs - the click breaks any stronger pull.
Best regards,
Svein
Dave Miller
Posted: Tue Sep 12, 2006 10:12 am Post subject: prop bolts |
Still makes more sense to me to buy a set of crowsfoot socket wrenches.
They only add about an inch to the length of the torque wrench, so a huge mathematical error is unlikely.
Mine came from offshore, but excellent quality and only about $15 Canadian
Dave [quote][b]
Posted: Tue Sep 12, 2006 11:16 am Post subject: prop bolts |
Svein,
Please have no fear at offending me as I feel this is a very good example of a learning discussion and I appreciate your input.
Now back to the discussion, I understand your point and equations in this discussion. My only concern is changing the setting of the torque wrench. I feel that no matter what length spanner is added to the end of the torque wrench, the only thing that changes is the amount of force your hand needs to exert in order to achieve the torque wrench setting and get the click. If a bolt needs to be torqued at 50 inch lbs, then the torque wrench needs to be set at 50 inch lbs.
Unless you are saying that the spanner extension is on the bolt and then the torque wrench is attached to the end of the spanner? My idea is that the torque wrench is on the bolt. Is this the difference in our points of view?
Mike Duane
Redding, California
Jabiru 3300
