Throttle Cable for Rotax
Tommy Walker
PostPosted: Tue Sep 05, 2006 5:15 am    Post subject: Throttle Cable for Rotax Reply with quote
Rotaxers,
I'm scratching my head trying to figure out how to substitute a conventional throttle with a throttle cable for the T-Handle throttle supplied with my kit. I figured it would be easier to operate and keep the RPM at a cruise setting compared to the T-Handle.
My problem is how to connect it to the Bellcrank. There has to be a way, but so far I've not figured it out yet. The throttle cable is an ACS model with a friction lock. The cable is about between 1/16- 1/8 diameter. Surely there is a device somewhere out there that will work.
Any ideas?
Tommy Walker in Alabama
Tommy Walker
N25A - Anniston, AL
rstone4(at)hot.rr.com
PostPosted: Tue Sep 05, 2006 5:40 am    Post subject: Throttle Cable for Rotax Reply with quote
Tommy,
A picture or drawing of the part you want to connect and the place
where you want to connect it would help us all help you to figure it out. I
personally would install a verner throttle cable. This is the kind that you
can push in or out for general usage or turn to get fine adjustments like
when you are flying formation.
Bob Stone, Harker Heights, Tx
ZodiacXL
jon(at)joncroke.com
PostPosted: Tue Sep 05, 2006 6:18 am    Post subject: Throttle Cable for Rotax Reply with quote
This is from our friend from Iceland, Johan, who has finished his very nice
701... without his permission I include:
(sorry for small size picture... I am restricted to dialup out in these
woods that I live...! ) (not complaining, tho!)
Any ideas?
 Filesize:  28.89 KB
 Viewed:  668 Time(s)
bryanmmartin
PostPosted: Tue Sep 05, 2006 7:37 am    Post subject: Throttle Cable for Rotax Reply with quote
I used a vernier throttle in my 601. It works very well. One thing about a vernier type throttle is that will make the second throttle useless because the vernier mechanism locks the throttle cable up in such a way that it can only be operated from the vernier. I couldn't see any way to make a second throttle function with a vernier on the other side so I eliminated the entire throttle system supplied with the kit and fabricated my own bracket to hook the vernier up to just the pilot's side of the panel. In a pinch, the right seat co-pilot can switch hands on the stick and reach across to operate the throttle. Since all take-offs and landings will normally be flown from the left seat, this arrangement presents no problem.
-------------- Original message ----------------------
I personally would install a verner throttle cable. This is the kind that you
Bryan Martin
do not archive.
webmaster(at)upac.ca
PostPosted: Tue Sep 05, 2006 9:56 am    Post subject: Throttle Cable for Rotax Reply with quote
Tommy, I converted mine to the ACS throttle as well. It was actually quite
easy. I made a part from aluminum stock on a lathe to adapt the wire to
the bell crank.
I'm not the originator of the idea however, Johann in Iceland is. Have a
look on his 701 website for pictures of the adaptor here:
http://www.gi.is/fis/zenithpanel.htm
Trevor Page
CH601HD
R912
Rotaxers,
Any ideas?
Tommy Walker
http://forums.matronics.com/viewtopic.php?p=59586#59586
ggower_99(at)yahoo.com
PostPosted: Tue Sep 05, 2006 10:12 am    Post subject: Throttle Cable for Rotax Reply with quote
Great idea from Johan,
My comment, I will just add a little drop of Locktite to the bolt tread... Will not hurt and will prevent loose from vibration.
Saludos
Gary Gower
Flying from Chapala, Mexico.
Any ideas?
Johann G. Johannsson
PostPosted: Wed Sep 06, 2006 11:42 am    Post subject: Re: Throttle Cable for Rotax Reply with quote
Hello Tommy.
I used the Vernier throttle from ACS wit the solid wire end, A820 on both sides. I started with the throttle on the left side, and then decided to install it on both sides, because it was the perfect setup.
The old T from Zenith is still on the right side in the picture on my home page.
Did not like that long stick because it was hard to control.
If you need the part to attatch the cable to the steel rod, I could send it to you. Just contact me off list with your address, and I will ship it to you.
Best regards,
Johann G.
Iceland.
Johann G.
Iceland.
Flying Zenith 701.
Tommy Walker
PostPosted: Sun Sep 10, 2006 9:15 am    Post subject: Re: Throttle Cable for Rotax Reply with quote
Johann,
I sent email, but I'm not sure you got it, so I will reply here. I would sure like to have the part. I can send you a check, just let me know.
My Address:
Tommy Walker
28 Old Coach Road
Anniston, AL 36207
Ph. 256-835-6610
email: twalker(at) cableone.net
Johann G. Johannsson wrote:
Hello Tommy.
Best regards,
Johann G.
Iceland.
Tommy Walker
N25A - Anniston, AL
