rliebmann(at)comcast.net Guest
Posted: Mon Sep 04, 2006 5:15 am Post subject: trim tab for rudder |
Hello John,
Here is a picture of my rudder trim tab. It is adjustable from the cockpit
and works well. I made this modification after flying the Fox for a couple
of years. If I had it to do over I would make it a little bigger.
Ron N55KF
<janderson412(at)hotmail.com>
You mean "yaw" ind...Dee. I have one too on my turn & bank, find I need
right 1/2 ball of right pedal in cruse, has anyone fitted an ajustable
rudder tab?? John A.
302.48 KB |
463 Time(s) |
Fox5flyer Guest
Posted: Mon Sep 04, 2006 6:44 am Post subject: trim tab for rudder |
Looks good Ron. Is that a stock tailwheel spring?
Deke
Michel
Posted: Mon Sep 04, 2006 10:56 am Post subject: trim tab for rudder |
On Sep 4, 2006, at 4:42 PM, Fox5flyer wrote:
| Quote: | Looks good Ron. Is that a stock tailwheel spring?
While on the subject, I noticed it was a single leaf spring. After
about 980 landings, my Kitfox 3 tail spring broke in a "normal"
landing. Thanks to the good help of Lowell, I have now a two leafs and
I feel much safer.
Michel
Lynn Matteson
Posted: Mon Sep 04, 2006 11:47 am Post subject: trim tab for rudder |
That's what I was going to ask, Deke...it looks like one of the "fat"
springs, like maybe aluminum? Not the color of course, but the shape.
Lynn
On Monday, September 4, 2006, at 10:42 AM, Fox5flyer wrote:
<morid(at)northland.lib.mi.us>
Deke
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
janderson412(at)hotmail.c Guest
Posted: Mon Sep 04, 2006 1:15 pm Post subject: trim tab for rudder |
Thanks Ron, you just have a wheel in the cockpit?
Subject: Re: Re: trim tab for rudder
Date: Mon, 4 Sep 2006 08:13:44 -0500
Hello John,
Ron N55KF
<< Kitfoxtrims.JPG >>
Looking for love? Check out XtraMSN Personals
http://xtramsn.match.com/match/mt.cfm?pg=channel&tcid 0731
Posted: Mon Sep 04, 2006 1:58 pm Post subject: trim tab for rudder |
The trim is controlled by a small lever below and in front of the seat
against the left side. Pull up for left trim, push down for right.
The tailspring is fiberglass. Herb Gottelt gave it to me when my first steel
one broke about ten years ago. It is great! I do not know if it is still
around the market though.
Ron
