Seamus
Posted: Sat Sep 02, 2006 11:29 am Post subject: Need new Prop |
Hello All,
I have recently purchased a 2003 Kolb Mark III with a Rotax 582, B gearbox
with 2,58 gear ratio Minus a prop. Needles to say I'm in the market for a
new one. I researched some and have narrowed my selection down to the IVO
66" 3 blade prop. However, \I would like any wisdom anyone would share on
the subject.
Thank You for your time,
Shay Jones
Check the weather nationwide with MSN Search: Try it now!
http://search.msn.com/results.aspx?q=weather&FORM=WLMTAG
_________________ Seamus R. Jones |
planecrazzzy Guest
Posted: Sat Sep 02, 2006 12:29 pm Post subject: Re: Need new Prop |
I've noticed most guys "lean" towards a bigger dia. with the IVO props.
I have a 503 w/ 68" IVO ( Firestar II )
Guys...?
Gotta Fly...
Mike in MN
APilot(at)webtv.net Guest
Posted: Sat Sep 02, 2006 3:39 pm Post subject: Need new Prop |
I imagine that you could buy a 72" Ivo for about the same price as a 66"
Why not get the longer blades and cut them down to suit you. I
originally purchased a 72" 3-blade and now I am at 70" dia. It is doing
so good that I may not go to a smaller dia. Just a thought.
David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Sat Sep 02, 2006 8:02 pm Post subject: Need new Prop |
Well, there's a Warp Drive prop somewhere West of Chowchilla, CA... I think it ended up in a corn field... Prop shaft (belt drive) broke forward of the hub and the hub and prop departed my 503 Firestar at about 1000' taking the right aileron spar/torque tube with it... I landed in a disced field and thanx to my big tires, no landing damage... Second no power emergency landing in the first 11.6 hours I've put on the Firestar... Prior to that, I had no dead stick landings in over 4600 GA hours... I really like the concept and the way the Firestar flies, but I'll probably go back to a store bought plane...
David
On 9/2/06, planecrazzzy <planecrazzzy(at)yahoo.com (planecrazzzy(at)yahoo.com)> wrote: | Quote: | --> Kolb-List message posted by: "planecrazzzy" <planecrazzzy(at)yahoo.com (planecrazzzy(at)yahoo.com)>
Guys...?
Gotta Fly...
Mike in MN
ô¿ô "Attitude is everything ~ pick a good one"... [quote][b]
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
Posted: Sat Sep 02, 2006 8:38 pm Post subject: Need new Prop |
Question: Were you using a two blade or a three blade? I have been
warned about using a two blade on mine.
Richard Pike
Posted: Sat Sep 02, 2006 9:59 pm Post subject: Need new Prop |
Go with an Ivo 2 blade, 68", and you will have a good prop and a smooth
flight, and good performance. That is the combination I am using on
mine. After trying several Warp Drive, Ivo and Kiev Hot Prop options, an
Ivo 2 blade 68" prop gives the best overall compromise between a great
climb and a great cruise for a MKIII with a 582 with a B box, 2.58:1
ratio. Be sure you get the hub extension. And you may need to make up
some motor mount extensions to raise your engine about an inch higher to
get sufficient clearance between the prop and the main tube.
If you get the Ivo 66" three blade, you will get more acceleration from
a standing start, (it will be awesome out of the hole) but I will pretty
much match you on climb, and outrun you top end. And at cruise, I will
be about three or four hundred RPM less than you for a given airspeed.
You don't want that. You want an engine that runs at less than 75% power
at cruise, which is 5600 rpm or less, and you won't get that with what
you are currently planning. Guess how I know this? (Been there, done
that, the T-shirt is in the rag box...)
Richard Pike
MKIII N420P (420ldPoops)
Seamus Jones wrote:
<seamusrjones(at)hotmail.com>
Hello All,
gearbox with 2,58 gear ratio Minus a prop. Needles to say I'm in the
market for a new one. I researched some and have narrowed my
selection down to the IVO 66" 3 blade prop. However, \I would like
any wisdom anyone would share on the subject.
Shay Jones
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
jindoguy(at)gmail.com Guest
Posted: Sun Sep 03, 2006 6:15 am Post subject: Need new Prop |
Shay, You might want to consider doing a couple of things before deciding on a prop.
First, confirm that your "B" box is indeed a 2.58. Someone could have changed the ratio in the field and not restamped the box. Because of the damper in the "B", this is pretty simple. Pull a plug from each cylinder, find top dead center, you can use your thumb to tell when you have compression, then pull the engine thru counting the compressions you feel with your thumb. No, it won't get you fine detail, but you'll know real quick if you're in the 2 or 3 part of the ratio.
Second, get yourself a copy of the California Power Systems catalog and read the articles on choosing a prop. Then read the articles on gearboxes. What you'll see is that the "B" box is marginal on a 582, it is only rated for 66 HP, and it is rated for only half the rotational mass of the "C" and "E" boxes.
So what should you be looking for in props? In a word, light. While an adjustable prop might get you something to futz with, I'm going to guess that as a new owner you probably want to fly ASAP. A good wood prop is the lightest you can get, it's the easiest to balance, and the easiest to maintain. Call Travis or Donnie at the factory and get their input, too. Tennessee Propellor makes nice wood props, ask them what they recommend. Ask them if they have a return policy if they get the pitch wrong, or better yet, do they have a known good for a 582 prop that you can use to take a read on your particular setup.
Whatever you decide, when you get your new prop check it for balance, follow the manufacturers installation and prop bolt torque recommendation and RETORQUE schedule. Check the blade tip tracking after installation and after each retorque, it should be .06" (1/16") or less.
As the new owner, you have a lot of unknowns facing you. While you're waiting on the prop, pull the exhaust system and look in the ports to check for general engine condition. While the exhaust is in your hands give it a good shake to see if it's about to blow chunks through your new prop. Borrow a dial indicator and check the prop flange for runout at the prop mounting surface, it should be .003" or less. You say your Mk III is a 2003. Check the engine serial number and check when it was manufactured and whether it is a -90 or -99 engine (don't be fooled by a blue head, spray paint is cheap and at least one 582 has shown up on eBay recently with a spray can upgrade). After you get your new prop mounted, do a weight and balance check, the method is right in the plans and it's easy to do.
Rick
On 9/3/06, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:[quote] --> Kolb-List message posted by: Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Richard Pike
Seamus Jones wrote:
[quote] --> Kolb-List message posted by: "Seamus Jones"
<seamusrjones(at)hotmail.com (seamusrjones(at)hotmail.com)>
Hello All,
Shay Jones
when you live at the airport.
David.Lehman
Posted: Sun Sep 03, 2006 6:26 am Post subject: Need new Prop |
Two blade... And remember this is a belt drive, not a gearbox...
DVD
On 9/2/06, APilot(at)webtv.net (APilot(at)webtv.net) <APilot(at)webtv.net (APilot(at)webtv.net)> wrote: | Quote: | --> Kolb-List message posted by: APilot(at)webtv.net (APilot(at)webtv.net)
Question: Were you using a two blade or a three blade? I have been s Navigator to browse ronics.com/Navigator?Kolb-List"> content now also available via the Web Forums! sp; mail List Wiki! sp; - List Cont! &nb========================
jsflan(at)valornet.com Guest
Posted: Sun Sep 03, 2006 8:20 am Post subject: Need new Prop |
David,
Glad you survived that one. It ain't exclusive to the UL-ies though.
Had a friend drop off a passenger from a river trip in Utah at McCarran. Climbed back in the Cessna 206, fired it up and a blade went sailing. Said it was like riding a horizontal eggbeater until he shut it down in a hurry.
Contending with all-day rain here in the desertland of NM. So am home computer hangar flying. Do folks fly Kolbs in the rain? Thinking of taxiing mine just to wash off the wings.
jsf
74.54 KB |
607 Time(s) |
Mike Schnabel
Joined: 27 Jan 2006 Posts: 114 Location: Manchester, TN
Posted: Sun Sep 03, 2006 9:15 am Post subject: Need new Prop |
John,
Any time in a Kolb is a good time. Even washing the wings in the rain... gee, that actually sounds like fun!
But be warned... don’t play with your Kolb in strong winds! I did last Sunday, after a really cool flight with Steve G in his Mk III on Saturday, I left my Firestar out, tied down overnight. Sunday came a blistering windy day... so I moved her to the trailer... but not before I was knocked over by a gust, raked my shin against the ramp door in my haste, now its swollen, infected, and lordy I hope the doc does not want to amputate!
But then again, if that’s the price I have to pay for some Kolb fun, it was worth every penny!
Mike S
Manchester TN
Firestar 2 503
"john s. flannery" <jsflan(at)valornet.com> wrote:
David,
jsf
Posted: Sun Sep 03, 2006 12:36 pm Post subject: Need new Prop |
I am nursing jammed or broken big toe following multiple gout sessions. Soaks in Epsom's Salt may help. Don't know where you are but friends swear by soaks in creosote/chaparral/greasewood, whatever you ant to call it tea for infections. Abundant here in he desert. Good luck
The rain worked well on the red beast, followed by a toweling after pushback into hangar and rain is still coming down. First day we have had density altitude under 6,000 feet.
jsf
Ed in JXN
Posted: Sun Sep 03, 2006 1:10 pm Post subject: Need new Prop |
Hi David,
Which belt redrive was it? I'd suspect the redrive, and switch to the proper gearbox. Haven't heard of any GB's letting the prop depart the aircraft.
Ed in JXN
MkII/503
Seamus
Posted: Sun Sep 03, 2006 1:13 pm Post subject: Need new Prop |
Thanks for alll the insight on my prop purchase...........I bought this Mark
III (Miss B) from Bob Brocious in Kentucky who not only sold me a great
plane but threw in some sound advice for free, this Kolb-list being one of
them. Thanks again for the responses and thanks in advance for future
responses I will have as a new rookie Kolb owner.
Shay J.
| Quote: | From: Richard Pike <richard(at)bcchapel.org>
Reply-To: kolb-list(at)matronics.com
Subject: Re: Need new Prop
Date: Sun, 03 Sep 2006 01:57:45 -0400
flight, and good performance. That is the combination I am using on mine.
After trying several Warp Drive, Ivo and Kiev Hot Prop options, an Ivo 2
blade 68" prop gives the best overall compromise between a great climb and
a great cruise for a MKIII with a 582 with a B box, 2.58:1 ratio. Be sure
you get the hub extension. And you may need to make up some motor mount
extensions to raise your engine about an inch higher to get sufficient
If you get the Ivo 66" three blade, you will get more acceleration from a
standing start, (it will be awesome out of the hole) but I will pretty much
match you on climb, and outrun you top end. And at cruise, I will be about
three or four hundred RPM less than you for a given airspeed. You don't
want that. You want an engine that runs at less than 75% power at cruise,
which is 5600 rpm or less, and you won't get that with what you are
currently planning. Guess how I know this? (Been there, done that, the
Richard Pike
Seamus Jones wrote:
>Hello All,
>on the subject.
>Shay Jones
>_________________________________________________________________
Posted: Sun Sep 03, 2006 2:43 pm Post subject: Need new Prop |
Ya dub gud. Would love to have BB's beautiful bird.
jsf
Possum
Posted: Sun Sep 03, 2006 2:49 pm Post subject: Need new Prop |
Never seen a 503 Firestar with a "belt drive" - what's it look like?
Who's idea was that?
But, then again, I don't get out much.
gtb(at)commspeed.net Guest
Posted: Sun Sep 03, 2006 3:27 pm Post subject: Need new Prop |
JSF;
How long have you waited to actually use the term,
"pushback" in a sentence concerning the operation
of an ultralight.
P.S.; LMAO
George
DO NOT ARCHIVE
Posted: Sun Sep 03, 2006 4:49 pm Post subject: Need new Prop |
Apparently they got supplied with Challenger kits at one time.
Hegar drives.
http://www.adventureaviation.org/CH_For_Sale.html
capedavis(at)yahoo.com Guest
Posted: Mon Sep 04, 2006 4:05 am Post subject: Need new Prop |
Shay, Glad to hear that Bob sold his ,plane I made a deal and made a down payment and was ready n to pick it up when I was in a terrible crash with Norm at TNK . He gave my wife the check back after the crash . Its a besutiful aircraft and I hope you enjoy it ;Fair wind Chris Davis
Seamus Jones <seamusrjones(at)hotmail.com> wrote: [quote]--> Kolb-List message posted by: "Seamus Jones"
Shay J.
[quote]From: Richard Pike
Richard Pike
>Hello All,
>new one. I researched some and have narrowed my How low will we go? Check out Yahoo! Messenger’s low PC-to-Phone call rates. [quote][b]
David.Lehman
Posted: Mon Sep 04, 2006 5:17 am Post subject: Re: Need new Prop |
[quote="Ed in JXN"]Hi David,
Ed in JXN
MkII/503
Hi Ed...
I don't know the manufacturer of the belt drive...
I think this Kolb is/was an excellent example of "you get what you pay for"...
If it ever flies again, it will be with a gearbox, or direct drive, no more belt drives for me...
DVD
49.25 KB |
510 Time(s) |
55.31 KB |
523 Time(s) |
