Gary's Cheap Flanging Dies
Goto page 1, 2  Next
gboothe(at)calply.com
PostPosted: Sat Sep 02, 2006 3:06 pm    Post subject: Gary's Cheap Flanging Dies Reply with quote
Ever since Bill Naumuk convinced me that I could scrap build my center section and fuselage (after kit building the tail and wings), I have been known to stare at the ceiling in the middle of the night, visualizing how I could build flanging dies out of wood.
Not to be outdone by Dave’s Cheap Sheet Metal Bending Brake, and in an obvious effort to take the food right out of the mouths of the babies of machinists, I finally made, and used (successfully), flanging dies out of plywood!
I hope the attachments are within the abilities of all to download, and, since this is my first attempt at attaching an image, I am currently sitting uncomfortably in my asbestos underwear.
Wood is really what I am most comfortable with. Switching from a Pietenpol to a 601 was a last minute decision after completing the WW Corvair Conversion. Any of you wood-chucks out there, like me, who wish a more detailed account can e-mail me directly. (any body skinned their 601 fuselage with plywood?....just kidding…)
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion
Tail done, wings done, working on c-section
 Filesize:  84.52 KB
 Viewed:  396 Time(s)
 Filesize:  84.13 KB
 Viewed:  389 Time(s)
Kevin Bonds
PostPosted: Sat Sep 02, 2006 4:00 pm    Post subject: Gary's Cheap Flanging Dies Reply with quote
I tried this approach, but found the ply’s delaminated when I tried to use them.
Kevin Bonds
Nashville TN
601XL Plans building.
http://home.comcast.net/~kevinbonds
do not archive DO NOT ARCHIVE
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Gary Boothe
Sent: Saturday, September 02, 2006 6:04 PM
Subject: Gary's Cheap Flanging Dies
KevinBonds
Nashville, TN
Plans-building Zenith CH601XL w/Corvair Power
PostPosted: Sat Sep 02, 2006 4:32 pm    Post subject: Gary's Cheap Flanging Dies Reply with quote
I was able to accomplish all 10 large holes in the nose ribs in approximately 15 minutes. The dies still look good, too. And that was Home Depot plywood! Guess I’ll keep my fingers crossed…
Gary
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of kevinbonds
Sent: Saturday, September 02, 2006 4:58 PM
Subject: RE: Gary's Cheap Flanging Dies
Kevin Bonds
Nashville TN
mtherr(at)yahoo.com
PostPosted: Sat Sep 02, 2006 5:27 pm    Post subject: Gary's Cheap Flanging Dies Reply with quote
I also used wooden flanging dies similar to your's.
The person who made them available to me made them out
of "Russian plywood". He also made all forming blocs
using that material. It is a very good plywood, but I
have no idea where we can find this.
Using them with a hydraulic press was very efficient.
See picture below:
http://mthobby.pcperfect.com/ch601/images/p6v31h.jpg
Michel
nose ribs in
Depot plywood! Guess I'll keep my fingers crossed.
Gary
_____
Not to be outdone by Dave's Cheap Sheet Metal
Michel Therrien CH601-HD, C-GZGQ
http://www.zenithair.com/bldrlist/profiles/mthobby
http://pages.infinit.net/mthobby
PostPosted: Sat Sep 02, 2006 5:42 pm    Post subject: Gary's Cheap Flanging Dies Reply with quote
Michael,
You're my kind of guy! You could have bought a hydraulic press from Harbor Freight for about $100, but, no, you've got to build one out of wood!
Gary
--> Zenith-List message posted by: Michel Therrien <mtherr(at)yahoo.com>
See picture below:
Michel
nose ribs in
Gary
_____
p.mulwitz(at)worldnet.att
PostPosted: Sat Sep 02, 2006 6:11 pm    Post subject: Gary's Cheap Flanging Dies Reply with quote
I agree that Russian plywood is really good. It is not the same sort
of low-quality junk plywood available at the Harry Home-owner stores
at all. It is usually at least 7 layers of Birch. You get more
layers as you get thicker plywood. It is also called Nordic Birch
plywood - some of it even comes from countries other than Russia.
I can get it at two different wood stores in Portland, OR. I like
using it for all sorts of stuff around the shop including nice wood
boxes. You can probably find it at higher class hardwood outlets
rather than construction lumber companies.
Paul
XL fuselage
See picture below:
Michel
naumuk(at)alltel.net
PostPosted: Sat Sep 02, 2006 8:23 pm    Post subject: Gary's Cheap Flanging Dies Reply with quote
Gary and all-
The credit belongs, as it should, to those who came before me.
I learned to scratch build from necessity, and wouldn't have had a clue if it weren't for the "Old timers". I've said it before and I'll say it again- Zenith builders are a tiny fraction of the world's population. We fight like hell (Although the latest Scotchbrite posts have been relatively tame), but that's because we're brothers, and brothers fight.
Just finished building a slight modification of Larry Mac's cruciform jig, leveled and mounted my center wing. 30 hours total, less than $50 (Only if you make a trip to the scrapyard- buy new steel and you're screwed). I consider it a necessity. Check out Larry's site- I can give a few tips, but all the basics are there. His is designed for an HDS, but you can modify it for an XL.
Waiting for corrosion protectant to dry on aileron bellcranks before assembly, then tomorrow I start on the fuse!!! (Larry and Jeff, I figured I'd leave the relief radii until after I rig everything).
One final note. I HIGHLY recommend the Homebuilder's Help DVDs. Wish I had them years ago. I doubt if Jon and Mark have a single dissatisfied customer.
Good building!
Bill Naumuk
45%HDS
Townville, Pa
J2j3h4(at)aol.com
PostPosted: Sat Sep 02, 2006 9:06 pm    Post subject: Gary's Cheap Flanging Dies Reply with quote
I'm thinking of using pressure-treated pine. If you have ever worked with this, you know that it is very hard.
Jim Hasper
In a message dated 9/2/2006 9:12:38 P.M. Central Daylight Time, p.mulwitz(at)worldnet.att.net writes:
--> Zenith-List message posted by: Paul Mulwitz <p.mulwitz(at)worldnet.att.net>
Paul
XL fuselage
601zv(at)ritternet.com
PostPosted: Sun Sep 03, 2006 4:09 am    Post subject: Gary's Cheap Flanging Dies Reply with quote
Pine is very soft compared to true hardwoods like oak, walnut, and hickory, and you shouldn't need the poison of the PT. I can't see using fragile soft wood like pine or birch unless you are going to whittle it by hand with a pocket knife. Modern power tools don't care if they are cutting hard or soft wood, and the hard wood would be more durable. 'Course I'm in the hardwoods country of the Ozarks where these woods are plentiful. I'll soon be burning a truck load of hardwood scraps to keep warm, free from a local mill, and most would be ideal chunks to cut dies from. There is one advantage to plywood - the cross grain would prevent cracking with the grain. I'd use ply before PT.
rstone4(at)hot.rr.com
PostPosted: Sun Sep 03, 2006 4:40 am    Post subject: Gary's Cheap Flanging Dies Reply with quote
Gary,
Beautiful work on the flanging die. Considering the quality of your wood work I can see only one thing wrong, you should have used hard wood then your die would last a lot longer. Your die looks like western fir and if it is, that's a soft wood.
Bob Stone, Harker Heights, Tx
ZodiacXL
PostPosted: Sun Sep 03, 2006 5:24 am    Post subject: Gary's Cheap Flanging Dies Reply with quote
Of course you are right. This being the “prototype”, and the fact that it worked so well, I’ll make the two smaller ones out of oak. A few weeks ago someone posted that they had used some of that man-made wood decking material with good results. A person can use whatever they want. Mostly, I thought to show the simple ‘jig’ that I used to create the male and female bevels.
Gary
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Robert L. Stone
Sent: Sunday, September 03, 2006 5:40 AM
Subject: Re: Gary's Cheap Flanging Dies
Gary,
ZodiacXL
dredmoody(at)cox.net
PostPosted: Sun Sep 03, 2006 7:41 am    Post subject: Gary's Cheap Flanging Dies Reply with quote
DUH!!! At a Russian plywood plant..... wasn't that obvious?
Ed
PostPosted: Sun Sep 03, 2006 7:53 am    Post subject: Gary's Cheap Flanging Dies Reply with quote
Don't feel bad. At one time or another, all men spend some time thinking about pressure-treated pine. It's just a phase that you are going through. In the end, you will come to the realization that if pressure treated wood requires the use of specially coated screws so that your fence or deck does not fall apart in a couple of years, then it probably isn't a good material to use to squeeze aircraft aluminum into shape. There now, take a deep breath.... feel better?
Ed Moody II
PostPosted: Sun Sep 03, 2006 8:04 am    Post subject: Gary's Cheap Flanging Dies Reply with quote
Pine and spruce are soft but birch is fairly hard.
Ed Moody II
Kevin Bonds
PostPosted: Sun Sep 03, 2006 8:19 am    Post subject: Gary's Cheap Flanging Dies Reply with quote
I’m looking at the video of Bigfoot carrying the scothch-brite, but can’t tell if the trees behind him are softwood or hardwood. Anyone know what he prefers for flanging dies? . . . .My apologies to everyone.
Kevin Bonds
Nashville TN
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Edward Moody II
Sent: Sunday, September 03, 2006 11:03 AM
Ed Moody II
[quote] [b]
KevinBonds
Nashville, TN
leinad(at)direcway.com
PostPosted: Sun Sep 03, 2006 10:59 am    Post subject: Gary's Cheap Flanging Dies Reply with quote
Gary,
Nice work. There's been a lot of talk about using a better material. Well here's one more. Consider using masonite or MDF. I made my set of dies from a combination of 3/4" thick fiberboard and 1/4" masonite. These materials provide a few advantages. I did all my flanging with these and they showed no ware and tear. It's hard and there is no grain. Best of all, it's cheap compared to plywood. I bought a 4x8 sheet of the 3/4 fiberboard for under 10 dollars. I made all my form blocks and dies from that sheet, with exception of the form for the firewall that I had already made from plywood.
I looked into these materials when someone on this list suggested using the plastic wood now available for deck materials. I like the idea, but I found that these were very expensive.
Dan
J2j3h4(at)aol.com
PostPosted: Sun Sep 03, 2006 12:22 pm    Post subject: Gary's Cheap Flanging Dies Reply with quote
I'm not planning to leave the wood in contact with the aluminum for very long. I figure that the short contact time will save me from having to use an acid metal prep. Smile
Jim
In a message dated 9/3/2006 10:54:56 A.M. Central Daylight Time, dredmoody(at)cox.net writes:
[quote] Don't feel bad. At one time or another, all men spend some time thinking about pressure-treated pine. It's just a phase that you are going through. In the end, you will come to the realization that if pressure treated wood requires the use of specially coated screws so that your fence or deck does not fall apart in a couple of years, then it probably isn't a good material to use to squeeze aircraft aluminum into shape. There now, take a deep breath.... feel better?
Ed Moody II
PostPosted: Sun Sep 03, 2006 2:32 pm    Post subject: Gary's Cheap Flanging Dies Reply with quote
No need to apologize, Kevin. We had it coming…but if it could be determined that those were Russian Plywood trees, we might have a clue where Bigfoot lives!
Gary Boothe
Cool, CA
Do not archive…
Sent: Sunday, September 03, 2006 9:17 AM
Kevin Bonds
Nashville TN
Ed Moody II
PostPosted: Sun Sep 03, 2006 5:06 pm    Post subject: Gary's Cheap Flanging Dies Reply with quote
He ain't dumb - he uses his GPS to locate those synthetic trees that are strong and stable for his dies, and only scotchbrites the surfaces that don't contact the AL.
Do not archive.
PostPosted: Sun Sep 03, 2006 5:23 pm    Post subject: Gary's Cheap Flanging Dies Reply with quote
He's not in Louisiana.... he's got too much fur for our heat and besides, Cajuns would have turned him into jambalaya long ago.
Ed Moody II
Goto page 1, 2  Next
Page 1 of 2
