bill_dom(at)yahoo.com Guest
Posted: Sat Sep 02, 2006 2:48 pm Post subject: HELP! My sweat is causing corrosion like spots |
I’ve noticed that my sweat is causing white spots in the metal surface that cannot be removed with lacquer thinner after the sweat have been left for a while. In some cases these white spots have develop into some type of white corrosion (filiform) that I have removed with scoth-brite.
I’ve searched the archives and found that Kevin Bonds had the same problem back in 2004 but at that time, no definite answer was given. (Kevin, how did you solve this?)
Is this common? Should I be concerned?
William Dominguez
Zodiac 601XL Plans
www.ea-report.com (in hiatus for now)
gboothe(at)calply.com Guest
Posted: Sat Sep 02, 2006 3:10 pm Post subject: HELP! My sweat is causing corrosion like spots |
I found this in the archives. I think it’s Kevin… protecting his work from sweat.
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion
Tail done, wings done, working on c-section
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of William Dominguez
Sent: Saturday, September 02, 2006 3:47 PM
To: Matronics List
Subject: HELP! My sweat is causing corrosion like spots
26.7 KB |
337 Time(s) |
Kevin Bonds
Joined: 09 Jan 2006 Posts: 171 Location: Nashville, Tn
Posted: Sat Sep 02, 2006 3:57 pm Post subject: HELP! My sweat is causing corrosion like spots |
So I’m not the only one heh? I have resorted to cleaning most things with Alumiprep 33 just before spraying or riveting together. I also have had a moisture problem, in my basement shop, which has contributed. Most of my aluminum, that has not been cleaned, has a haze on it until I clean it. I suspect you have a humidity problem as well. Your sweat contains salt, and when it is humid you have moisture and salt. Sound like a bad combination? The only reason more people don’t complain of this is that they don’t live in Nashville, Tennessee like me.
Kevin Bonds
Nashville TN
601XL Corvair powered; Plans building.
Empennage done; working on wings and engine.
http://home.comcast.net/~kevinbonds
do not archive DO NOT ARCHIVE
Sent: Saturday, September 02, 2006 5:47 PM
To: Matronics List
_________________ KevinBonds
Nashville, TN
Plans-building Zenith CH601XL w/Corvair Power
http://home.comcast.net/~kevinbonds |
Kevin Bonds
Posted: Sat Sep 02, 2006 4:05 pm Post subject: HELP! My sweat is causing corrosion like spots |
No offense guys, but my wife says, “it’s funny that you are such a nerd, that even your nerd friends make fun of you”. Thanks guys.
Kevin Bonds
Nashville TN
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Gary Boothe
Sent: Saturday, September 02, 2006 6:09 PM
Subject: RE: HELP! My sweat is causing corrosion like spots
Gary Boothe
Cool, CA
Nashville, TN
jhstarn(at)verizon.net Guest
Posted: Sat Sep 02, 2006 5:09 pm Post subject: HELP! My sweat is causing corrosion like spots |
Just remember that it's your friends that kid you.
A: Because they can. and
B: Because they care.
They wouldn't spend the time or energy ribbing you if they didn't. KABONG Do Not Archive.
Posted: Sat Sep 02, 2006 5:29 pm Post subject: HELP! My sweat is causing corrosion like spots |
John,
Thanks for clarifying that! Kevin – thanks for being a good sport. The world is full of “friends” I haven’t met.
Gary Boothe
Cool, CA
Do not Archive
Kevin Bonds
Nashville TN
From: owner-zenith-list-server(at)matronics.com (owner-zenith-list-server(at)matronics.com) [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Gary Boothe
Gary Boothe
Cool, CA
| 01234567890123456
Posted: Sat Sep 02, 2006 7:05 pm Post subject: HELP! My sweat is causing corrosion like spots |
I live in Miami, it may explain the humidity problem.
William Dominguez
Zodiac 601XL Plans
kevinbonds <kevinbonds(at)comcast.net> wrote:[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> Clean Clean DocumentEmail false false false MicrosoftInternetExplorer4 <![endif]--> <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <![endif]--> So I’m not the only one heh? I have resorted to cleaning most things with Alumiprep 33 just before spraying or riveting together. I also have had a moisture problem, in my basement shop, which has contributed. Most of my aluminum, that has not been cleaned, has a haze on it until I clean it. I suspect you have a humidity problem as well. Your sweat contains salt, and when it is humid you have moisture and salt. Sound like a bad combination? The only reason more people don’t complain of this is that they don’t live in Nashville, Tennessee like me.
Kevin Bonds
Nashville TN
To: Matronics List
I’ve noticed that my sweat is causing white spots in [quote][b]
dredmoody(at)cox.net Guest
Posted: Sun Sep 03, 2006 6:20 am Post subject: HELP! My sweat is causing corrosion like spots |
Posted: Sun Sep 03, 2006 7:39 am Post subject: HELP! My sweat is causing corrosion like spots |
Women often fail to appreciate the finer qualities that attach to nerdiness. Let her run off with a bad boy and see how long that lasts.
Ed
