wayne.e(at)grandecom.net Guest
Posted: Fri Sep 01, 2006 2:29 am Post subject: gretzgretz |
You know for what ever it's worth I also went with the Gretz pitot tube, I liked the idea of the auto on feature, and I installed the controller for it right on the back of the inspection plate right next to where it's mounted. I've attached a picture. I think it will make it very easy to work on if necessary.
Also I think the tube is just a tad bit ugly so I call the owner who sells the Gretz unit and ask him if I could paint it and he told me that's not a problem. He said I could sand down the unit to smooth it up a little. I also talked to my paint guy and he said not a problem to paint it. Maybe if I paint it, it will blend into the underside and not look quite so ugly :>}
Wayne Edgerton #40336
116.94 KB |
142 Time(s) |
