PIREP on XRX PCAS
dlm46007(at)cox.net
PostPosted: Sun Aug 27, 2006 9:46 am    Post subject: PIREP on XRX PCAS Reply with quote
installed an XRX traffic unit in the Glastar. Having a unit to provide both
distance and altitude to the traffic is quite helpful. We set the unit to
check for transponder replies +- 2000 ft. The traffic is more easily spotted
when the altitude is about our level. The previous unit the MRX simply gave
distance which could have been far above or below. Also helpful to know
whether the conflicting traffic is climbing into our altitude or descending
into it.
More useful than mode S because it identifies traffic that is interrogated
by ATC, military aircraft and TCAS (airlines and corporate) equipped
airplanes.
At $500 it is far more cost effective than Mode S transponder ($3000) and
TCAD at about $5000.
In addition it provides an internal altimeter showing pressure altitude
or/and your Mode A or Mode C data.
coop85(at)bellsouth.net
PostPosted: Sun Aug 27, 2006 12:12 pm    Post subject: PIREP on XRX PCAS Reply with quote
Sounds pretty good, especially since I couldn't find some potentially factor
traffic to day until after they had passed. I went to the Zaon Flight
Systems website and it shows the XRX model listing for $1795 and the less
capable MRX for $499. Where did you get the XRX for $500?
Marcus
glastar(at)gmx.net
PostPosted: Sun Aug 27, 2006 12:19 pm    Post subject: PIREP on XRX PCAS Reply with quote
Hi David,
interesting indeed, but I found it for 1795$ the MRX is 499$, if I can
get it somewhere for 500$ it's a done deal, however the aircraft which
are not flying with the transponder on are the most dangerouse one, I
had more then one near in the last 3 weeks with such traffic.
br
Werner
both distance and altitude to the traffic is quite helpful. We set the
unit to check for transponder replies +- 2000 ft. The traffic is more
easily spotted when the altitude is about our level. The previous unit
the MRX simply gave distance which could have been far above or
below. Also helpful to know whether the conflicting traffic is
climbing into our altitude or descending into it.
interrogated by ATC, military aircraft and TCAS (airlines and
corporate) equipped airplanes.
and TCAD at about $5000.
altitude or/and your Mode A or Mode C data.
dlm46007(at)cox.net
PostPosted: Sun Aug 27, 2006 1:22 pm    Post subject: PIREP on XRX PCAS Reply with quote
My confusion ; I got the $499 version apparently confused the letters.
