PeterHunt1(at)aol.com Guest
Posted: Sat Aug 26, 2006 6:54 pm Post subject: Tire Wear |
Over time, do RV main tires wear more on the outside or the inside treads?
Pete
RV-6, 123 hours.
| | - The Matronics RV6-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
komisa_m(at)bellsouth.net Guest
Posted: Sat Aug 26, 2006 7:11 pm Post subject: Tire Wear |
k9hxt(at)sbcglobal.net Guest
Posted: Sun Aug 27, 2006 8:04 am Post subject: Tire Wear |
Yes, they do...........on hard surface runways mine wear on the inside much more than the outside. If you do a lot of crosswind landings then that certainly enters into wear patterns (outside wear upwind). In fact, I reverse them every 100. hrs of so. I have also found that the "RV Shimmy" on my RV-6A seems to depend to a great extent on the main tire wear/unbalance. Van's kit ires must be very inexpensive tires as they tend to wear out quickly also. A friend of mine whose plane build I mentored has Michelin Aero tires with almost 300 hrs and they show little wear.(RV- . Go figure? I am replacing my Van's tires next annual (Sept.06) with Goodyear Flt Custom 5.00-5 x 6 plys as I have 185.hrs on Van's and they are junk. Michelin's are good but they are French owned and unless they give em'away I won't use them. Guess I am getting old or something.
How are yours wearing???? (with 123.hrs)
Just for the record, how are your oil temps running? Mine were always high until I found the culprit..........
Luck,
Larry, RV-6A N939LT since July 2001
"LIMA TANGO SENDS"
ghfrost(at)earthlink.net Guest
Posted: Sun Aug 27, 2006 8:43 am Post subject: Tire Wear |
Thanks for the tire info. Mine are wearing the same way with 95 hours
and mostly crosswind landings.
On Aug 27, 2006, at 12:03 PM, Larry Rush wrote:
[quote] Yes, they do...........on hard surface runways mine wear on the inside
Luck,
"LIMA TANGO SENDS"
beech19pilot(at)yahoo.com Guest
Posted: Sun Aug 27, 2006 9:28 am Post subject: Tire Wear |
Hey Larry,
What was the culprit of your high oil temps.
Mark
Luck,
"LIMA TANGO SENDS"
tcervin(at)valkyrie.net Guest
Posted: Sun Aug 27, 2006 2:50 pm Post subject: Tire Wear |
You'll love the Goodyear's!!!
Tom in Ohio RV6-A
