james(at)berkut13.com Guest
Posted: Fri Aug 25, 2006 10:20 am Post subject: Noise filter noise |
Hi all,
I'm wondering if someone could educate me a little on something I
encountered while trying to eliminate electrical noise coming from an
autopilot servo. The story goes like this:
I recently installed a new autopilot servo in my Berkut (all composite). It
worked perfectly, but for some reason, the servo makes a loud squealing
noise in the intercom audio when it's activated. I did all the usual
things - changed ground points, increased grounding, double checked
shielding on cables, un-bundled wires, ferrite beads on the cables, etc.
The only thing that really worked was to power the servo from a separate
battery - indicating electrical propagation, not RF. I spoke with the
manufacturer, and they did mention that there was a 2.5KHz PWM signal that
is used to control the servo, and that the "noise" I hear is likely that.
So, on to trying to isolate the servo from everything else...right.
I first tried (at the manufacturer's request) a pair of capacitors (.1uf and
4700uf) in parallel, grounded off the servo power lead itself. This did
slightly dampen the noise, but certainly not enough. So, I also went out
and purchased a common 10-amp car audio power filter - just like those sold
by Radio Shack and documented by Bob on his site - 2 caps with a choke coil
potted in a case although I can not see the ratings on the caps. I placed
the filter in an orientation that isolated the power source from the servo,
instead of servo from power source as IT was the verified source of the
noise.
The good news is, that filter eliminated about 99% of the noise - and that's
good to go. I have not yet done extensive tests to see if the AP now
operates properly in flight with the filter in-line (possible I/O errors,
proper servo feedback, etc)...that's coming soon. But, I want to explore
the "weirdness" first.
Now, the weird (to me anyway) part is that the filter itself now audibly
"sings" with the same frequency that I had heard before on the intercom. I
mean, it literally makes the noise like a speaker would. Is this normal?
What would be causing that? Is this symptomatic of some additional problem
that might effect servo operation? Something else I should do or try?
All information and education is welcome...but remember, I'm not an EE.
Eager to learn,
James Redmon
Berkut #013 N97TX
http://www.berkut13.com
By the way, this is not a common situation as the manufacturer has not seen
this type of issue before...although they are doing everything they can to
get this under control - under warranty, to their credit! I have no issues
with the way they are handling this..so please don't pester me about that
part.
FLYaDIVE(at)aol.com Guest
Posted: Fri Aug 25, 2006 2:23 pm Post subject: Noise filter noise |
In a message dated 8/25/06 2:26:09 PM Eastern Daylight Time,
james(at)berkut13.com writes:
| Quote: | Hi all,
It
| Quote: | worked perfectly, but for some reason, the servo makes a loud squealing
[Barry] When what is activated, the intercom or the servo?
| Quote: | I did all the usual
and
| Quote: | 4700uf) in parallel, grounded off the servo power lead itself. This did
[Barry] I gather the 47000uf cap was an electrolytic and the other was a
ceramic disc?
| Quote: | So, I also went out
sold
| Quote: | by Radio Shack and documented by Bob on his site - 2 caps with a choke
coil
| Quote: | potted in a case although I can not see the ratings on the caps.
| Quote: | I placed the filter in an orientation that isolated the power source from
the servo,
| Quote: | instead of servo from power source as IT was the verified source of the
noise.
[Barry] I'm not sure what you mean my that statement.
Is the filter mounted as close to the servo as posable, short leads and a
clean ground? That is how it should be installed.
that's
| Quote: | good to go. I have not yet done extensive tests to see if the AP now
I
| Quote: | mean, it literally makes the noise like a speaker would. Is this normal?
[Barry] Weird to me too? Are you saying that the filter has a noise coming
from it? If so then your GROUND is poor and maybe your leads too long. This
of course is assuming that the filter is made well and the coils of the filter
are mounted / potted securely. But, the first thing I would check is the
GROUND.
Other thing to check would be your crimps. I would rather have you tell me
that you soldered these connection.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
brian-av(at)lloyd.com Guest
Posted: Fri Aug 25, 2006 4:36 pm Post subject: Noise filter noise |
On Aug 25, 2006, at 11:17 AM, James Redmon wrote:
| Quote: | Now, the weird (to me anyway) part is that the filter itself now
audibly "sings" with the same frequency that I had heard before on
the intercom. I mean, it literally makes the noise like a speaker
would. Is this normal? What would be causing that? Is this
symptomatic of some additional problem that might effect servo
You are putting current pulses through an inductor so it has a
magnetic field that is varying with the current pulses. Any steel
object nearby is going to be alternately pulled and released by the
varying magnetic field. It is probably the case of the inductor or
the inductor's core that is making the noise.
OTOH, there shouldn't be that much current change. Put the capacitor
combo back at the input to the servo.
Brian Lloyd 361 Catterline Way
brian HYPHEN av AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
N6030X(at)DaveMorris.com Guest
Posted: Fri Aug 25, 2006 4:57 pm Post subject: Noise filter noise |
Well, 2.5 KHz is within the audible frequency range. The A above
Middle C is 440 Hz. So you're only talking about less than 6 octaves
above it. All it would take is having the coil inside the filter
that has this frequency applied to it being physically in contact
with the case or other structure. I can envision that real
easily. We usually call that "headphones" or "loud speaker". So,
you might have to take it apart and make sure the filter is
physically isolated from the box around it using RTV or rubber
gaskets or something.
Be careful about filtering the PWM signal, though. The whole purpose
is to feed that signal to the servo, and if you are applying a filter
that changes the shape, the servo might start functioning incorrectly.
Dave Morris
At 01:17 PM 8/25/2006, you wrote:
Hi all,
an autopilot servo. The story goes like this:
composite). It worked perfectly, but for some reason, the servo
makes a loud squealing noise in the intercom audio when it's
activated. I did all the usual things - changed ground points,
increased grounding, double checked shielding on cables, un-bundled
wires, ferrite beads on the cables, etc. The only thing that really
worked was to power the servo from a separate battery - indicating
electrical propagation, not RF. I spoke with the manufacturer, and
they did mention that there was a 2.5KHz PWM signal that is used to
control the servo, and that the "noise" I hear is likely that. So,
(.1uf and 4700uf) in parallel, grounded off the servo power lead
itself. This did slightly dampen the noise, but certainly not
enough. So, I also went out and purchased a common 10-amp car audio
power filter - just like those sold by Radio Shack and documented by
Bob on his site - 2 caps with a choke coil potted in a case although
I can not see the ratings on the caps. I placed the filter in an
orientation that isolated the power source from the servo, instead
of servo from power source as IT was the verified source of the noise.
and that's good to go. I have not yet done extensive tests to see
if the AP now operates properly in flight with the filter in-line
(possible I/O errors, proper servo feedback, etc)...that's coming
soon. But, I want to explore the "weirdness" first.
Eager to learn,
James Redmon
Berkut #013 N97TX
not seen this type of issue before...although they are doing
everything they can to get this under control - under warranty, to
their credit! I have no issues with the way they are handling
this..so please don't pester me about that part.
Posted: Fri Aug 25, 2006 8:55 pm Post subject: Noise filter noise |
| Quote: | > I recently installed a new autopilot servo in my Berkut (all composite).
It
When the servo is active. The squeal is itermittent but coupled with the
motion of the servo. As in when pressure is applied against the stick and
the servo is commanded to move the other direction. This was without the
filter installed, of course.
| Quote: | > I did all the usual
> that
> that.
and
ceramic disc?
Yup. The cap combo didn't do much to squelch the noise. The filter cuts it
by 99%.
| Quote: | > So, I also went out
sold
coil
the servo,
> noise.
Yes, they are short - about 3" from servo. I rigged up a short pig-tail so
I could attach it and detach it for testing. I just mean that the filter
is a stimple choke coil with a two caps in parallel like Bob has documented:
http://www.aeroelectric.com/articles/filter/RS_Noise_Filters.pdf#search=%22filter%22
| Quote: | > The good news is, that filter eliminated about 99% of the noise - and
that's
> errors,
> explore
I
> normal?
coming
This
filter
GROUND.
Yup. the filter itself is the source of the audible noise. It is connected
to the common "nose" ground block. That block is fat wired striaght back to
the battery. I'm not sure what else to "check" or how. I have opened the
filter's case up, but it's components are potted with glue and I can't read
the cap values. But I can see that it's just a coil, and two caps in a
plastic case.
| Quote: | Other thing to check would be your crimps. I would rather have you tell
me
All PIDG crimps. All have been checked as secure.
Filter still singing like a canary.
James Redmon
Berkut #013 N97TX
Posted: Fri Aug 25, 2006 9:01 pm Post subject: Noise filter noise |
| Quote: | You are putting current pulses through an inductor so it has a magnetic
field that is varying with the current pulses. Any steel object nearby is
going to be alternately pulled and released by the varying magnetic
field. It is probably the case of the inductor or the inductor's core
Humm...might be the inductor core..it's not mounted near anything else (6"+
minimum). The noise is definately coming from inside the filter case
(plastic) and I can feel it vibrating with the sound.
| Quote: | OTOH, there shouldn't be that much current change. Put the capacitor
The cap combo didn't do much at all to help the noise. Maybe a 5%
reduction.
Thanks for the input!
James Redmon
Berkut #013 N97TX
Posted: Fri Aug 25, 2006 9:06 pm Post subject: Noise filter noise |
| Quote: | Well, 2.5 KHz is within the audible frequency range. The A above Middle C
is 440 Hz. So you're only talking about less than 6 octaves above it.
All it would take is having the coil inside the filter that has this
frequency applied to it being physically in contact with the case or other
structure. I can envision that real easily. We usually call that
"headphones" or "loud speaker". So, you might have to take it apart and
make sure the filter is physically isolated from the box around it using
RTV or rubber gaskets or something.
Well, the caps and coil are in a plastic case, and are installed with some
kind of clear gel glue - like hot glue. I can not see that anything is
touching the case without the goop inbetween.
| Quote: | Be careful about filtering the PWM signal, though. The whole purpose is
to feed that signal to the servo, and if you are applying a filter that
Yeah. There does not seem to be any issues with the servo operation, but
then I have not flown it either. I will do some flight testing tomorrow.
I also plan to disconnect the filter, setup the AP servo, get it working in
flight (if I can bear the noise in the headset), and then re-connect the
filter and see if there are any servo problems.
I'll know more tomorrow. One thing - I can live with the singing filter if
the AP works properly. It's not loud enough to hear over any engine
noise....but the noise over the headsets is LOUD!
James Redmon
Berkut #013 N97TX
jindoguy(at)gmail.com Guest
Posted: Fri Aug 25, 2006 11:11 pm Post subject: Noise filter noise |
I've had singing capacitors in audio equipment before, it means it's a bad capacitor. Try replacing it or the whole filter assembly.
Rick
On 8/25/06, James Redmon <james(at)berkut13.com (james(at)berkut13.com)> wrote:[quote] --> AeroElectric-List message posted by: "James Redmon" <james(at)berkut13.com (james(at)berkut13.com)>
Posted: Sat Aug 26, 2006 6:27 am Post subject: Noise filter noise |
On Aug 25, 2006, at 9:58 PM, James Redmon wrote:
<james(at)berkut13.com>
> the varying magnetic field. It is probably the case of the
> inductor or the inductor's core that is making the noise.
else (6"+ minimum). The noise is definately coming from inside the
filter case (plastic) and I can feel it vibrating with the sound.
> capacitor combo back at the input to the servo.
reduction.
I know that but it might help with the noise coming from the filter.
Posted: Sat Aug 26, 2006 6:45 am Post subject: Noise filter noise |
Humm...given the potting inside the filter, I think I'd end up destroying it in the process of dis-assembly. I might try replacing the whole filter.
Attached is a picture of the unit - I have not been able to track down any electrical specifics.
Curious, if one of the two capacitors went bad, wouldn't it fail (at least partially) to squelch the noise and no longer "filter" as well? Or is there a partial failure mode of a capacitor that I'm not aware of?
Thank you all for the help and ideas - it's very educational.
I'll fly it today, and see if the servo is operating properly with and without the filter attached. (it's rigged as a small jumper cable so I can easily plug and un-plug it)
I think if the AP servo works properly, I'll just let the filter audibly "sing". At least there's no appreciable noise in the headsets.
James Redmon
Berkut #013 N97TX
41.64 KB |
377 Time(s) |
Posted: Sun Aug 27, 2006 7:39 pm Post subject: Noise filter noise |
An update to the noise issues:
Well, in short, the noise problems are solved. The test flights showed that
the filter disrupted the PWM signal to the extent that it was un-flyable.
So, the quick fix "filter" solution was not possible.
I tried various combinations of grounds and power and the only combination
that eliminated the noise was feeding the unit directly from the battery and
grounding it only to the battery as well. This meant isolating the unit's
mounting so that it did not touch a ground in the front of the plane
(battery is in the back).
So, with this combination required tearing the plane apart to install
dedicated lines (all out of spares), but at least all systems are functional
and quite happy with one another. The one combination I didn't try was to
install the filter on the intercom or audio circuit itself. I figured I'd
take the simplest route to solve the problem as protecting the audio may
have opened the door to at least 6 different sources (2 coms, audio panel,
intercom, engine monitor, etc.). Yikes!
Moral: if you are still building, do yourself a favor and pre-installed
triple the number of fore-aft wires that you think you need - you'll run our
of spares before you know it.
Anyway, the AP tracks dead-nuts-straight-on...and no noise to boot. All
smiles here...despite the bloody knuckles and pricked fingers.
Thanks to those offering explanations and ideas. I learned a lot on this
one.
James Redmon
Berkut #013 N97TX
phillip.johnson(at)lmco.c Guest
Posted: Mon Aug 28, 2006 5:13 am Post subject: Noise filter noise |
The core of the inductor is probably lightly magnetostrictive which will cause the core to vibrate under electrical excitation. This is normal, however if the mechanical resonance of the core is close to the excitation frequency then it will howl quite loudly and may induce premature failure of adjacent components. If this is the case then you can damp the vibration by adding some silicone or epoxy to the inductor. This will move the natural frequency and damp the vibration.
Phillip Johnson
L
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Chief Engineer & Manager Underwater Systems Group
Tel (613) 599 3280 ext. 3232
Cell (613) 799 1644
FAX (613) 599 3282
