Forest of Tabs
Deems Davis
PostPosted: Fri Aug 25, 2006 12:21 pm    Post subject: Forest of Tabs Reply with quote
Where have people mounted their forest of grounding tabs?
Deems Davis # 406
Fuse/Finishing/Panel
http://deemsrv10.com/
jesse(at)itecusa.org
PostPosted: Fri Aug 25, 2006 12:44 pm    Post subject: Forest of Tabs Reply with quote
On the Firewall into a nutplate.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Dick Sipp
PostPosted: Fri Aug 25, 2006 8:11 pm    Post subject: Forest of Tabs Reply with quote
 Filesize:  146.72 KB
 Viewed:  306 Time(s)
dlm46007(at)cox.net
PostPosted: Sat Aug 26, 2006 7:21 am    Post subject: Forest of Tabs Reply with quote
One thing to consider here is that there are now two extra holes in a
structural piece that were not envisioned by the aircraft designers. I
usually try to avoid putting any additional holes in pieces that hold the
engine or gear or flight surfaces securely
capsteve
PostPosted: Sat Aug 26, 2006 4:13 pm    Post subject: Forest of Tabs Reply with quote
Where did you find those connectors?
steve
Deems Davis # 406
Here is one option. There are two similar ground connectors mounted above
and below the triangular reinforcement where the firewall and top longeron
meet. There are at least thirty ground pins available in each connector.
The paint was removed under the mounting. I am planning to also terminate
the large ground lead from the engine on the same triangular reinforcement.
Dick Sipp #65
Finishing
Dick Sipp
PostPosted: Sun Aug 27, 2006 6:56 am    Post subject: Forest of Tabs Reply with quote
dmasys(at)cox.net
PostPosted: Mon Aug 28, 2006 8:08 am    Post subject: Forest of Tabs Reply with quote
B&C has several different configurations of 'forest of tabs' grounding plates:
http://www.bandcspecialty.com/cgi-bin/ez-catalog/cat_display.cgi?26X358218
-Dan Masys
FWF and panel
steve
> Deems Davis # 406
Dick Sipp #65
Finishing
