ETCHY1(at)comcast.net Guest
Posted: Sat Jan 21, 2006 10:32 am Post subject: rv antenna locations |
I am building a 7A and would like to know the antenna locations and type of antennas used and how well or not well they have worked. For the following. Comm ,Nav, Glideslope,Gps,tranponder and elt. Thanks Jim
ronlee(at)pcisys.net Guest
Posted: Sat Jan 21, 2006 2:04 pm Post subject: rv antenna locations |
| Quote: | I am building a 7A and would like to know the antenna locations and type
Comm: Bent whip on bottom of fuselage. Works great.
Nav/Glideslope: Archer antenna in wingtip. Seems ok but cannot assure that
there is no body blockage. I am assuming that the GS
is from
that antenna.
GPS: Mine is on the fuselage top behind the slider but many here build a ledge
on the firewall top area and it seems to work ok there (just under the top
cowl)
Transponder: Small one on bottom
ELT: Aft fuselage under empennage fairing but some place it in the cargo area.
Ron Lee
Rick Galati
Joined: 10 Jan 2006 Posts: 91 Location: Lake St. Louis MO.
Posted: Sat Jan 21, 2006 4:51 pm Post subject: Re: rv antenna locations |
| ETCHY1(at)comcast.net wrote: | | I am building a 7A and would like to know the antenna locations and type of antennas used and how well or not well they have worked. For the following. Comm ,Nav, Glideslope,Gps,tranponder and elt. Thanks Jim |
I have a Comant bent whip comm ant. centered between the gear legs and works as advertised.
Like many RV builders I installed the ELT antenna underneath the empennage fairing.
http://img28.imageshack.us/img28/1739/rvelt99ph.jpg
The ELT itself is mounted on a tray tied into the ribs underneath the baggage floor.
http://img23.imageshack.us/img23/7508/cabin32xv.jpg
The Garmin 430 GPS locks on quickly and has performed flawlessly with the antenna located under the upper cowl.
http://img79.imageshack.us/img79/2617/gps20de.jpg
Rick Galati RV-6A "Darla" 106 hours
