europa(at)triton.net Guest
Posted: Tue Aug 15, 2006 6:27 pm Post subject: Retro Fitting MG Wings |
We are trying to retrofit glider wings to our XS fuselage. We completed the spar bush installation per Chapter 8 with no problem. Moving to Chapter 27a, we are able to fit the port wing to the fuselage and insert the EUR047 bolts. The top skin of the port wing forward of the spar does just touch the fuselage. However, we are unable to fit the stbd wing. It seems as though the wing will not go far enough into the fuselage, by about ¼ inch. The top skin of the stbd wing forward of the spar is hitting the side of the fuselage and preventing the wing from sliding in as far as necessary. We also notice that the gap between the GDG01 jigs and the lift drag pin sockets (W26 & W27) on the stbd wing is large - over ½ inch while it is small on the port wing - 1/8 inch. Is this a common problem and is the solution to trim the top skin?
We have also noticed that the flap cross tube FL15 hits the top skin of the wing on both sides. Is the solution to trim the top skin to clear?
When fitting the short wings to the fuselage, we stretched a string from wing tip to wing tip to check for sweep (Chapter 27-4). The MG manual does not include this step. It only requires measurement of the wings from the tailplane torque tube (Chapter 27a-2). Should we also check sweep with a string as before?
Finally, the thickness of the spar bushings seems to be greater on the MG wings. Is a different length spar pip pin required?
Jim & Heather Butcher N241BW
n100rh(at)sbcglobal.net Guest
Posted: Fri Aug 18, 2006 8:31 am Post subject: Retro Fitting MG Wings |
Jim,
I was really hoping you would get a response to your question. I'm
building the MG and don't have short wings at this time, but have always
wondered what the retro fit problems would be to add the short wings.
Hopefully someone will give you some feedback.
Ralph
Reno, NV
Jim Butcher wrote:
Gary.Leinberger(at)miller Guest
Posted: Fri Aug 18, 2006 10:00 am Post subject: Retro Fitting MG Wings |
I am building a mg and am not as far along - and I just got some short wings - my understanding is that the wings have to be trimmed to fit - you need to cut off some of the material on the wing skin in order to allow the spar to fit in and bolt up. I am thinking about fitting the short wings first, and then the mg wings - since the short wings are already drilled for the bolts and hopefully in the right place.
Glad to hear someone is out there on point.
Gary Leinberger
A237
Lancaster, Pa.
gleinberger(at)millersville.edu
Posted: Sat Aug 19, 2006 4:21 am Post subject: Retro Fitting MG Wings |
To update this thread, we talked to Bob Berube who confirmed that the top
skin needs to be trimmed. He suggested 1/2 inch gap to the fuselage.
We still have a pretty large gap between the jigs and lift drag pin, 30 mm
at the stbd aft. But there is plenty of length on the pin, so we bonded in
three plates at the aft position on each wing. The forward pins only
required one or two plates.
The top skin will need to be trimmed to clear the flap cross tube, but the
fairings will cover that.
We didn't do the string but the measurements should ensure sweep.
Yes, the spar bushings definitely make the spar thicker. We'll have to
modify the spar cup that is attached to the stbd side of the cockpit module
as well as the one that goes on the port MG wing. We think the pip pin is
probably long enough, but will require a different number of washers than
fitted for the short wings.
Posted: Sun Aug 20, 2006 3:23 pm Post subject: Retro Fitting MG Wings |
Ralph Hallett wrote:
Jim,
always wondered what the retro fit problems would be to add the short
wings. Hopefully someone will give you some feedback. Ralph
Reno, NV
Ralph
I think the factory missed a wonderful oportunity here. I would have
designed the wing with bolt on tip extensions for gliding and semi short
wings for cruising. Lots of gliders have this option. The original wings
are not quite long enough for ideal cruise and climb performance, but
then Ivan is still obsessed with scarumbatics. (he's scared me more than
once > ) I prefer the more graceful aerobatics you have with long
wings not the brute force and ignorance of stubby wing aeroplanes,
Just my prejudice
Graham
paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Sun Aug 20, 2006 6:20 pm Post subject: Retro Fitting MG Wings |
Graham,
I thought you might be interested in looking at some "quick and dirty"
measurements I took. I looks like the wing is optimized for 120 knots. I
still haven't figured out the best speed to fly for maximum range.
Paul
 Download |
| Filename: |
Fuel_burn_vs_IAS.xls |
17.5 KB |
| Downloaded: |
282 Time(s) |
