		amecum(at)comcast.net Guest
				 Posted: Wed Aug 16, 2006 7:50 pm    Post subject: RV-List: Tail lifting during full power static test |
				Oh yes it will and it will do it fast!
 From: owner-rocket-list-server(at)matronics.com [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of JOHN STARN
  Sent: Wednesday, August 16, 2006 8:43 PM
  To: rv-list(at)matronics.com
  Subject: RV-List: Tail lifting during full power static test
 Don't look now BUT Gummibear & I (and others) have been YELLING "Tie it down" & have someone (without glasses) hold the tail down for at least the past five years. Maybe we need to have re-runs of very important safety issues every 3 to 6 months. While on the subject: Do Not stomp on the brakes of ANY RV- conventional geared airplane at slow speed (walking/taxi speed). They WILL, not might, they WILL put their nose on the tarmac quicker than you can react.  KABONG  Do Not Archive it's already in there several times.
 Listers--We are close to flying our RV-6.  On the airworthiness certificate application it requires the builder to state that "the powerplant installation has undergone at least one hour of ground operation at various speeds from idle to full power. . . ."  Yesterday during the first full power static test holding brakes and with the stick full aft the tail came up on me.  Because I was approaching full power gradually (being nervous about just this sort of possibility) I was able to quickly close the throttle before the prop hit the ground.
 LeRoy Johnston in Ohio.
       | 	  0123456789012345
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		fbaldwin(at)nothnbut.net Guest
				 Posted: Wed Aug 16, 2006 10:37 pm    Post subject: RV-List: Tail lifting during full power static test |
				Regarding the statement "application requires one hour of  ground time..." is new to this DAR.
  Look at the sample FAA Form 8130-6 in Advisory Circular 20-27,  it shows ZERO time on the application.
  I hope this helps to eliminate some unsafe  procedures.  Frank
		smokyray(at)yahoo.com Guest
				 Posted: Thu Aug 17, 2006 2:39 am    Post subject: RV-List: Tail lifting during full power static test |
				My Dad's motto "it ain't done flying till you tie it down" still holds true...(I can hardly wait till we hear about the test flight...)
   Rob Ray
 Frank Baldwin <fbaldwin(at)nothnbut.net> wrote:
   [quote]    v\:* {   BEHAVIOR: url(#default#VML)  }  o\:* {   BEHAVIOR: url(#default#VML)  }  w\:* {   BEHAVIOR: url(#default#VML)  }  .shape {   BEHAVIOR: url(#default#VML)  }    <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />    st1\:*{behavior:url(#default#ieooui) }               Regarding the statement "application requires one hour of ground time..." is new to this DAR.
		swaneymj(at)mac.com Guest
				 Posted: Thu Aug 17, 2006 10:57 am    Post subject: RV-List: Tail lifting during full power static test |
				Kabong,
 Your descriptions are always classic.  Thanks for the lessons learned
 and keeping us newbies on track.  I might actually finish my Rocket one
 of these days, and I'll be sure to tie down the tail.  I'll check to
 see if you're available for the ballast : -)
 Mark Swaney
 F-1 Rocket #31 (N76TR)
 swaneymj(at)mac.com
 Do not archive.
 On Aug 17, 2006, at 11:00 AM, JOHN STARN wrote:
 [quote] During the first runup tests & subsequent "conditional inspection"
  ground run ups we anchor it down & I drape my 230# self over the tail
  of HRII N561FS so that Tom is not setting in a pogo stick. IF you
  don't remove your eyeglasses, not to worry, the prop blast with do it
  for you. As for end of the runway runups we DO NOT cycle the prop as
  part of pre-flight. N561FS has more than enough umph to get rolling &
  take off even if the prop is in cruise. Tom kinda likes the extra kick
  in the pants during the take off roll (Kinda like the AB on an F-4)
  when he cycles up the prop during the roll.
  Runup the engine, cycle the prop with brakes locked = Varooom, big
  bite of air, ding, ding, thud....followed by a long silence...KABONG
  Do Not Archive.
