Gull-wing Doors
heliav8r(at)swbell.net
PostPosted: Tue Aug 15, 2006 1:30 pm    Post subject: Gull-wing Doors Reply with quote
I am considering replacing the canopy with gull-wing doors like that on the CH2000. Does anyone have information on how I should go about that change? Anyone have drawings or suggestions as to how I could accomplish this?
Samm Munn
Zenith 601XL (plans builder), Corvair
(129% to go)
tya2(at)4-fly.net
PostPosted: Tue Aug 15, 2006 3:57 pm    Post subject: Gull-wing Doors Reply with quote
Dear Samm,
I own a CH2000. The factory offers an upgrade kit out of Georgia with all of the parts necessary to do the change over from the old style CH2000 to AMD Alarus style Ch2000. Go to www.newplane.com prices can be found in the owners section. The information is kind of scanty but the pictures of the CH640 construction on one of the local builders websites will show you how it is done.
Personally the best kind of Canopy is the AA-1 or AA-5 style as used in the Grumman AA-x series. Split in the middle and slides back like an F-86... You can choose to fly with the canopy open and that is a fine feeling on warm days. Turn off the radios and fly nordo through the mountains
Rocky near Edmonton, AB
At 04:30 PM 8/15/2006 -0500, you wrote:
[quote]I am considering replacing the canopy with gull-wing doors like that on the CH2000. Does anyone have information on how I should go about that change? Anyone have drawings or suggestions as to how I could accomplish this?
Samm Munn
(129% to go)
- NEW MATRONICS WEB FORUMS -
http://forums.matronics.com
- NEW MATRONICS LIST WIKI -
http://wiki.matronics.com
- List Contribution Web Site -
[/b]
larry(at)macsmachine.com
PostPosted: Tue Aug 15, 2006 4:35 pm    Post subject: Gull-wing Doors Reply with quote
Samm,
The gull wing doors I've seen on a few 601 series weren't too well
represented. The problem being that the stability between the vertical
edges had no serious
framework to keep things in sound alignment in flight. The hinges at
the top were placed too far apart to allow both to be open at the same
time. I suspect the
added framework for rigidity at the hinges would add some considerable
weight as well. The gull wing doors are best seen on the composite type
aircraft where
support is full perimeter. The complexity is a challenge and I hope
you're able to do better than the ones I've seen so far. It's a neat
concept if done well, but that's
the hard part with this bubble canopy and for all of the above, I'd be
reluctant to do it.
The forward tilt canopy is really much easier to do and use, but that's
just an opinion.
Good luck, seriously,
Larry McFarland - 601HDS at www.macsmachine.com
accomplish this?
Samm Munn
(129% to go)
steveadams
PostPosted: Wed Aug 16, 2006 4:23 am    Post subject: Re: Gull-wing Doors Reply with quote
The canopy on the CH2000 and CH640 with gull wing doors is a one piece structure built from carbon fiber which extends from the firewall back to the rear windows. It is amazingly thin and light, but very strong. I think to put gull wing doors on a 601, you would need to build something similar, and would need to be pretty good at working with composites. Not that it couldn't be done, but it would be a very big job, and would likely change the aerodynamics of the 601 unless you built it to the same profile as the current canopy. To build it from aluminum would IMHO be extremely difficult to do right.
Steve Adams
ashontz
PostPosted: Sat Feb 10, 2007 8:56 pm    Post subject: Re: Gull-wing Doors Reply with quote
[quote="tya2(at)4-fly.net"]Dear Samm,
Samm Munn
(129% to go)
[/b]
Do you know the link of the guy building the CH640 and his pix of the gull wing doors. I'm interested in this option too. Any other info on the AA-1 and AA-5 sliding canopy? That sounds interesting too. Thanks
steveadams
PostPosted: Tue Feb 13, 2007 4:51 am    Post subject: Re: Gull-wing Doors Reply with quote
Here is a photo of the CH2000,CH640 cabin structure.
 Filesize:  31.41 KB
 Viewed:  838 Time(s)
ashontz
PostPosted: Tue Feb 13, 2007 5:33 am    Post subject: Re: Gull-wing Doors Reply with quote
I see no reason why that can't be easily adaptable to the CH601XL. If you ask me the CH2000 looks just like a CH601XL except with a hardtop canopy.
[img]http--www.airbum.com-pireps-CH20001.jpg[/img]
Doesn't even look all that difficult to make, unless I'm missing something.
 Filesize:  45.73 KB
 Viewed:  796 Time(s)
Gig Giacona
PostPosted: Tue Feb 13, 2007 6:41 am    Post subject: Re: Gull-wing Doors Reply with quote
To each his own... but that big bubble canopy on the 601XL was a big selling point for me.
W.R. "Gig" Giacona
601XL Under Construction
pilot4pay
PostPosted: Tue Feb 13, 2007 6:50 am    Post subject: Gull-wing Doors Reply with quote
I used to monitor the RV list, and after listening to them complain about
the quality of the canopy, I'm glad I've chosen to go with Zenith, not to
mention not having to buck all those rivets! Looks like very high quality
glass work.
Craig Smith
Craig Smith
CH640 builder
SN: 0078
"Just think how stupid the average person is,
and then realize that half of them are even stupider!"
--George Carlin
ashontz
PostPosted: Tue Feb 13, 2007 6:56 am    Post subject: Re: Gull-wing Doors Reply with quote
To each his own.
I like the hardtop. Looks like a Piper Cherokee. May give a little more roll-over protection too if done right. I also don't like the idea of being trapped in a bubble upside down, you can pop the door latch (per a lot of flight manuals in prep for an emergency landing) prior to landing, especially if it's a regular front hinge door like a Cherokee. Not only that but I'd be easier and cleaner to put a couple slider windows in the thing and it also offers some measure of sun protection without giving up too much visibility. To me the hardtop just looks more like a GA airplane. I think it's cool and would probably be cheaper too. Also, it looks like something I can make and repair. Crack a fullsized bubble canopy while doing something to it and you're screwed and have to buy a new one. I also don't like the idea of having something on the plane I can't make myself or would be really hard-pressed to make. Worst case if for some reason say the smaller windshield cracked and I couldn't find another one at a reasonable price, it'd be a hell of a lot easier to make a small plexi-glass front or side windshield that it would be to make a full-sized canopy. I intend to keep this plane for a long time. If in 2030 I need a windshield and the company that made the original wasn't around I wouldn't be SOL.
Jaybannist(at)cs.com
PostPosted: Tue Feb 13, 2007 7:34 am    Post subject: Gull-wing Doors Reply with quote
The 640 may be similar to the 601XL, but look at the proximity of the spar insertion hole to the main landing gear attach bracket. It's MUCH different from the 601XL. I see quite a few, less obvious, differences in the fuselage structure. It's nopt just a 601XL with a different canopy.
Jay in Dallas
CH601XL - Corvair
www.mykitlog.com/ashontz
http://forums.matronics.com/viewtopic.php?p=94676#94676
ashontz
PostPosted: Tue Feb 13, 2007 8:14 am    Post subject: Re: Gull-wing Doors Reply with quote
Jay in Dallas
CH601XL - Corvair
I'm sure a 640 or a ch2000 aren't just a scaled up version of a 601xl, but they are very similar looking from photos, especially before the canopy is installed. I don't see any obvious reason that a canopy from one model couldn't be adapted to another model. I guess what I'm getting at is that in either case, the canopy doesn't appear to add to the structural intengrity of the fuselage, certainly not in the XL and I would venture to guess that it doesn't add anything structurally from a design stand-point (that's needed anyway) to the CH2000 or the 640 and any additional strength it does add is just a bonus, kind of like a hardtop versus convertible car. You can put the top down or cut the hardtop off a Chrysler Seibring and it wouldn't effect the strength of the chasis because they're built on the same chasis and the structural integrity is not compromised sans a roof.
agustafson(at)chartermi.n
PostPosted: Tue Feb 13, 2007 11:01 am    Post subject: Gull-wing Doors Reply with quote
That $20 piece of Plexi selling for $1000 was why I modified to use flat
Lexan and am now sealing the gull wing doors on my HD.
Aaron Gustafson do not archive
ashontz
PostPosted: Tue Feb 13, 2007 12:19 pm    Post subject: Re: Gull-wing Doors Reply with quote
Yeah, that's way to much for a piece of formed plexiglass.
steveadams
PostPosted: Wed Feb 14, 2007 5:08 am    Post subject: Re: Gull-wing Doors Reply with quote
I am sure that you could adapt a similar designed canopy to the 601, however it would have to be built from scratch, not a modification of the 640 canopy because the dimensions are all different. In the 640 it is a structural component of the fuselage, tying the upper 1/2 of the firewall into the fuselage. It is also quite complex, made completely of carbon fiber, with many areas a sandwiched structure with an inner and outer layup. Since it wouldn't be primarily structural in a 601, you could probably make a much simpler design and use fiberglass rather than carbon fiber however it would have to be pretty sturdy to give adequate support to the doors and the roll over protection you are looking for. Also, being a very well made $4000 piece of the 640, it is definitely not cheap.
ashontz
PostPosted: Wed Feb 14, 2007 5:15 am    Post subject: Re: Gull-wing Doors Reply with quote
Good info. I was wondering it was structural or not in the 640. Obviously it wouldn't be in the 601XL so the contruction woould be easier. I'm going to have to look into this.
caspainhower(at)aep.com
PostPosted: Wed Feb 14, 2007 10:08 am    Post subject: Gull-wing Doors Reply with quote
I considered gull-wing doors also, there are a few flying out there. I
ended up designing cantilever hinges so I could have a permanent windshield
and rear opening canopy. I had Todd at www.toddscanopies.com build a custom
canopy with a little extra headroom and a more gradual rear slope. For the
scratch builders out there, he produces an excellent product at a
reasonable price.
Craig
N601XS, 601xl, 0-235 lyc, wiring/plumbing left
ask me
This e-mail message and all attachments transmitted with it from the
Nuclear Generation Group of American Electric Power are for the sole
use of the intended recipient(s) and may contain confidential and
privileged information. Any unauthorized review, use, disclosure or
distribution is prohibited. If you are not the intended recipient, please
contact the sender by reply e-mail and destroy all copies of the original
message.
