701 wing tie-down points
billmileski
PostPosted: Mon Aug 14, 2006 11:21 am    Post subject: 701 wing tie-down points Reply with quote
Hello,
Is there an accepted way to attach ropes to the wings for tying down a 701? Like adding something at the main spar wing attach points that allows a rope to be conveniently looped through? There's nothing obvious in the archives about this.
Help appreciated,
Bill Mileski
Ledyard, CT
701 912S 35 hrs
hrs1(at)frontiernet.net
PostPosted: Mon Aug 14, 2006 12:29 pm    Post subject: 701 wing tie-down points Reply with quote
Bill . . . in the lower left corner sheet 7V8 of my 701 plans, there's a
detail of a tiedown bracket. I discussed this with Roger at ZAC, and he
said they are seldom installed. Most simply tie a line around the
strut. Robert Schoenberger 701
billmileski wrote:
Hello,
Help appreciated,
Bill Mileski
Ledyard, CT
701 912S 35 hrs
http://forums.matronics.com/viewtopic.php?p=54740#54740
cffd(at)pgrb.com
PostPosted: Mon Aug 14, 2006 1:15 pm    Post subject: 701 wing tie-down points Reply with quote
Bill,
Here is what I did. The added piece is from 1/16" 4130 sheet. I put the
"quick link" through the hole in the 4130 and tie the rope to it. I carry
the quick links with me.
Chuck D.
N701TX
Hello,
Help appreciated,
Bill Mileski
Ledyard, CT
701 912S 35 hrs
 Filesize:  66.26 KB
 Viewed:  467 Time(s)
NYTerminat(at)aol.com
PostPosted: Mon Aug 14, 2006 3:44 pm    Post subject: 701 wing tie-down points Reply with quote
Bill,
Not sure what drawings you are using but I installed the Tie down rings per the bottom left hand corner of 7-V-8. It works well. Drawings are dated 11/2004
Bob Spudis
N701ZX CH-701/912ULS 75 hrs
--> Zenith-List message posted by: "billmileski" <mileski(at)sonalysts.com>
Hello,
Help appreciated,
Bill Mileski
Ledyard, CT
701 912S 35 hrs
billmileski
PostPosted: Tue Aug 15, 2006 6:45 am    Post subject: Re: 701 wing tie-down points Reply with quote
Thanks.. didn't think to check the plans, and not sure mine will have it, mine are circa 2003, but will check. And thanks for the pic, Chuck, it looks like that would work well too. So I should be all set.
