Fred.Stucklen(at)UTCPower Guest
Posted: Thu Aug 10, 2006 9:16 am Post subject: Electric Elevator Trim connector |
I'm about to install my Electric Elevator Trim servo in the new RV-7A.
I'm interested in knowing what others have done for electrical
connectors for the servo, and where they have located that
connector (i.e., in the tail area or the fuselage).
So far, most everything I've seen will not allow the elevator to be
removed as the connector will not fit through the hole in the elevator
or the rear spare of the horizontal stab....This includes DB-9
connectors......
Fred Stucklen
RV-7A N924RV
frank.hinde(at)hp.com Guest
Posted: Thu Aug 10, 2006 9:47 am Post subject: Electric Elevator Trim connector |
I used a terminal strip screwd down just behind the empenage front spar.
I don't know for sure but I think the little ring terminals will go thru
the hole.
Frank
RV 7a
Paperwork submitted, final rigging of controls
connectors for the servo, and where they have located that connector
connectors......
Fred Stucklen
RV-7A N924RV
chaztuna(at)adelphia.net Guest
Posted: Thu Aug 10, 2006 9:53 am Post subject: Electric Elevator Trim connector |
At 01:15 PM 8/10/2006, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Stucklen, Frederic W UTPWR" <Fred.Stucklen(at)UTCPower.com>
connectors......
Fred Stucklen
RV-7A N924RV |
Fred,
The best solution to allow elevator removal is to use Bob Nuckoll's suggested method. Use D Sub male and female terminals without the S Sub block. Crimp or solder the male and female terminals to the 5 wires. Slide heat shrink over the wires then connect the terminals. Use heat to shrink the heat shrink tubing over the connected joint. This will hold the connection tight and keep it dry.
To remove, simply slice the heat shrink with a razor blade and disconnect the D Sub pins. It will allow the connector pins to be withdrawn through the rather small hole in the elevator spar. Stagger the connectors to ease removal. Bob has or had a photo "how to" page on his site. I looked quickly, but couldn't locate it.
Charlie Kuss
Posted: Thu Aug 10, 2006 10:08 am Post subject: Electric Elevator Trim connector |
connectors......
Fred Stucklen
RV-7A N924RV |
Fred,
Charlie Kuss |
Sorry Fred,
I meant to type D Sub, not S Sub
Posted: Thu Aug 10, 2006 10:43 am Post subject: Electric Elevator Trim connector |
My elevator trim motor is attached to the rear deck a la Gretz.....I have a molex on the rearmost bulkhead (609 IIRC).
Photos on direct request.......
[quote]--
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Fred,
I used a connector from the radio control world. Check your local hobby shop
or catalogue.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Thu Aug 10, 2006 11:24 am Post subject: Electric Elevator Trim connector |
Hi Fred-
I ran across some kits a few years back that had assorted Molex pin & socket connectors and included the crimping tool and pin removal tool. I got one each in the .062 and .093 sizes and they have been extremely useful for stuff like the trim servo connection where you can just0crimp pins on the end of the servo and cable wires, and insert them into the connector bodies and plug together. When you need to pull the cables0back through a hole, such as when removing your elevator, you simply unplug0the connector and remove the pins from the connector body with the tool that comes in the kit- it's a good idea to wrap some tape around the pin bundle0to protect them as you pull the cable out.
Called "Cable Connector Designer Kits", Digikey has 'em on page 130 & 131 of their current catalog:
http://dkc3.digikey.com/PDF/T062/0130.pdf for the .062 pins ($71.24)
http://dkc3.digikey.com/PDF/T062/0131.pdf for the .092 pins ($61.16)
here's Bob's how-to on Molex/AMP connectors:0 http://aeroelectric.com/articles/matenlok/matenlok.html
You can also use d-subs and remove the pins- Bob had a how-to on his website but looks like it's gone- basically just a male & female d-sub glued together with shoe-goo and covered in shrinkwrap IIRC-
From The PossumWorks in TN
Mark
http://websites.expercraft.com/n51pw/[url=http://aeroelectric.com/articles/matenlok/mat][/url]
_________________ From The PossumWorks... |
retasker(at)optonline.net Guest
Posted: Thu Aug 10, 2006 12:23 pm Post subject: Electric Elevator Trim connector |
Or go to www.mouser.com and get exactly the same things for less:
http://www.mouser.com/search/ProductDetail.aspx?R=WM-72 (at) $48.18
http://www.mouser.com/search/ProductDetail.aspx?R=WM-50 (at) $45.38
Dick Tasker
Fiveonepw(at)aol.com (Fiveonepw(at)aol.com) wrote:
| Quote: | Hi Fred-
I ran across some kits a few years back that had assorted Molex pin & socket connectors and included the crimping tool and pin removal tool. I got one each in the .062 and .093 sizes and they have been extremely useful for stuff like the trim servo connection where you can just crimp pins on the end of the servo and cable wires, and insert them into the connector bodies and plug together. When you need to pull the cables back through a hole, such as when removing your elevator, you simply unplug the connector and remove the pins from the connector body with the tool that comes in the kit- it's a good idea to wrap some tape around the pin bundle to protect them as you pull the cable out.
here's Bob's how-to on Molex/AMP connectors: http://aeroelectric.com/articles/matenlok/matenlok.html
Mark
rdunhamtn(at)hotmail.com Guest
Posted: Thu Aug 10, 2006 2:15 pm Post subject: Electric Elevator Trim connector |
The URL is
http://aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html
| Quote: | From: Charlie Kuss <chaztuna(at)adelphia.net>
Reply-To: aeroelectric-list(at)matronics.com
Subject: Re: Electric Elevator Trim connector
Date: Thu, 10 Aug 2006 14:05:53 -0400
>>connectors......
>>Fred Stucklen
>>RV-7A N924RV
>Fred,
>Charlie Kuss
Sorry Fred,
Mark Phillips in TN
aerobubba(at)earthlink.ne Guest
Posted: Fri Aug 11, 2006 3:25 am Post subject: Electric Elevator Trim connector |
Hi Fred-
| Quote: | I'm interested in knowing what others have done for electrical
I found a 7 pin annular connector, perhaps at RS, that works well. By
leaving the outer most shell off, it has a small enough diameter to fit
through the hole. Just make sure that if you use a snap bushing in the
butt rib hole it is oriented correctly for removal of the ass'y. I heat
shrink the connector into one lump which I then ty wrap to the aft deck
between the HS spars.
Hope this helps-
glen matejcek
aerobubba(at)earthlink.net
nuckollsr(at)cox.net Guest
Posted: Fri Aug 11, 2006 5:08 am Post subject: Electric Elevator Trim connector |
| Quote: | >>>
>>>connectors......
>>>Fred Stucklen
>>>RV-7A N924RV
>>Fred,
Funny thing about that Charlie, I couldn't either. Programming
is such a fussy science. I had one quote sign missing in the
articles index code and it hosed two lines of the index making
a couple of items disappear. The comic book you're remembering
is at:
http://aeroelectric.com/articles/macservo/macservo.html
and the code has been repaired. Thanks for bringing it up!
Also see last photo at:
or
http://aeroelectric.com/articles/Solder_Lap_Splicing/e.jpg
Keep in mind that the wires provide on the Ray-Allen
servos is (ugh!) 26AWG. The simple female-pin/male-pin splice
illustrated is still pretty fragile in tension on the small-wire
side of the simple shrink-over-D-sub-pin splice. I'd be
a bit more comfortable with the former solution where the
tiny wires are supported by the final doping of uckum-yucky.
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Fri Aug 11, 2006 5:40 am Post subject: Electric Elevator Trim connector |
The REAL problem I see is that the trim servo comes from Ray Allen with0 26AWG wires and most connectors, especially Molex, can only accomodate as small0 as 24AWG. I plan on following Bob's recommendation and using a 9-pin D-Sub0 connector.
Bret
_________________ Bret Smith
RV-9A (Emp) |
ktlkrn(at)cox.net Guest
Posted: Fri Aug 11, 2006 6:12 am Post subject: Electric Elevator Trim connector |
Hey Fred,
I used a Dean's 5 pin connector from the hobby0 shop. This is a thin connector with VERY tight fitting gold pins. It will fit0 through the oval shaped hole in the elevator. The hole in the spar was enlarge0 to accommodate.
A rubber grommet was used on the oval hole and0 works great. I split a grommet for the hole in the spar. As an added0 measure of protection I protected the wires with heat shrink tubing where the0 wires pass through the elevator and spar.
Very neat, simple and serviceable unit. Sorry don't0 have any pictures of this.
Darwin N. Barrie
Chandler AZ
RV7 N717EE
130+ hours
Posted: Fri Aug 11, 2006 7:02 am Post subject: Electric Elevator Trim connector |
Darwin,
I suggest you contact Vans regarding enlarging the hole in the left elevator main spar. I did the same thing, but ended up installing a doubler plate to shrink the hole back to the original size. When I spoke to Vans, they said that I should not open that hole, as it will weaken the spar. The elevator has a fair amount of load placed on it. Hence my choice of using D Sub pins and heat shrink per the last photo below.
Be sure to stagger the splice connectors, to avoid creating a knot of wire.
Charlie Kuss
| Quote: | Hey Fred,
I used a Dean's 5 pin connector from the hobby shop. This is a thin connector with VERY tight fitting gold pins. It will fit through the oval shaped hole in the elevator. The hole in the spar was enlarge to accommodate.
A rubber grommet was used on the oval hole and works great. I split a grommet for the hole in the spar. As an added measure of protection I protected the wires with heat shrink tubing where the wires pass through the elevator and spar.
Very neat, simple and serviceable unit. Sorry don't have any pictures of this.
Darwin N. Barrie
Chandler AZ
RV7 N717EE
130+ hours |
Posted: Fri Aug 11, 2006 12:52 pm Post subject: Electric Elevator Trim connector |
Actually if you want to use 26 AWG they do sell pins for these
connectors that work with 24-30 AWG.
Mouser part number 538-02-06-1132 for the female pins and 538-02-06-2132
for the male pins.
I have used some of these and they do work down to 26 AWG without any
trouble (except for the fact that the wire is pretty small). Use good
external strain relief.
Dick Tasker
Bret Smith wrote:
[quote] The REAL problem I see is that the trim servo comes from Ray Allen
with 26AWG wires and most connectors, especially Molex, can only
accomodate as small as 24AWG. I plan on following Bob's
recommendation and using a 9-pin D-Sub connector.
Bret
Posted: Sun Aug 13, 2006 12:58 am Post subject: Electric Elevator Trim connector |
Hi Charlie,
The enlargement of the hole was very minor to get the Deans connector through. I did check with Vans and they said it was fine I think their concern is running some type of large connector through that requires a significant hole.
Darwin N. Barrie
willslau(at)alumni.rice.e Guest
Posted: Sun Aug 13, 2006 7:37 am Post subject: Electric Elevator Trim connector |
Hi Darwin,
I just checked the Dean's website and did not find a listing for a five wire connector. Can you give me a source for the one you used, or did you use a three and a two or ? Thanks.
William Slaughter
RV-8QB Wings
Posted: Mon Aug 14, 2006 12:23 pm Post subject: Electric Elevator Trim connector |
At 10:34 AM 8/13/2006 -0500, you wrote:
significant hole.
Darwin N. Barrie
Darwin . . . or anyone else. Exactly what is the size of the
hole under discussion?
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
Bret Smith
Posted: Mon Aug 14, 2006 6:16 pm Post subject: Electric Elevator Trim connector |
Bob, here is a pic of the hole in the rear horizontal stabilizer spar
(RV-9). I have mine stored but you can see the hole is approx. 5/8 to 3/4".
Bret Smith
RV-9A (91314)
Mineral Bluff, GA
www.FlightInnovations.com
126.32 KB |
495 Time(s) |
RV-9A (Emp) |
