small file Blank series V weight and balance
Goto page 1, 2  Next
AMuller589(at)aol.com
PostPosted: Mon Aug 07, 2006 4:23 pm    Post subject: small file Blank series V weight and balance Reply with quote
I will try to attach a much smaller jpeg file that I found. Hope it comes0 thru ok. I don't know much about changing formats. I edited the numbers off0 of this one so you would have a blank one. I will also try the recommended way0 to reduce files. thanks and Good Luck. An associated note said
" NOTE: it is recommended that flap deflection be limited to (unspecified)0 notch on Series V tail draggers when operating at CG stations forward of 11.700 inch. The aircraft may not be able to achieve a three point attitude upon0 landing at extreme forward CG stations with full flaps.
FLIGHT LOAD FACTOR FLAPS UP + 3.8g - 1.52g"
since our series 5 with 2.2 Eggenfellner subaru has electric trim0I0 cannot associate with notches of flaps.
 Filesize:  266.41 KB
 Viewed:  298 Time(s)
smokey_bear_40220(at)yaho
PostPosted: Mon Aug 07, 2006 5:35 pm    Post subject: small file Blank series V weight and balance Reply with quote
What was the source of the note? First I have seen
that.
Kurt S. S-5/NSI turbo
flaps......
PostPosted: Tue Aug 08, 2006 2:23 am    Post subject: small file Blank series V weight and balance Reply with quote
the source of this note is page 2-4 "OWNERS MANUAL AND PILOTS OPERATING0 HANDBOOK SERIES V" dated July 2004
PostPosted: Tue Aug 08, 2006 2:53 am    Post subject: small file Blank series V weight and balance Reply with quote
Attached is subject page from SERIES V POH page 2-4. I found a way to0 reduce it from 2.4mb to 266.4KB. Hope I can figure a way to repeat it for future0 X-MSN.
--> Kitfox-List message posted by: kurt schrader0 <smokey_bear_40220(at)yahoo.com>
What was the source of the0 note? First I have seen
that.
Kurt S. S-5/NSI0 turbo
...... An associated note0 said
" NOTE: it is recommended that flap deflection0 be
notch on Series V tail0 draggers when operating at CG
three point attitude0 upon
0 flaps......
 Filesize:  266.41 KB
 Viewed:  313 Time(s)
PostPosted: Tue Aug 08, 2006 5:18 pm    Post subject: small file Blank series V weight and balance Reply with quote
I can confirm it is true on my S-5 for over 50% flaps
and FWD CG. I run out of trim at around 60 knots and
no flaps. Still can get enough elevator until 1/2
flaps. After that it is difficult to get the tail
down with FWD CG. Just never saw it in a note before.
Kurt S.
I found a way to reduce
X-MSN.
that.
CG
> flaps......
PostPosted: Tue Aug 08, 2006 5:21 pm    Post subject: small file Blank series V weight and balance Reply with quote
Hummm. Didn't have it in my older copy I guess or I
think I would have remembered it. Mine is at the
hangar. I'll have to check it later to be sure.
Kurt S.
AND PILOTS OPERATING HANDBOOK SERIES V" dated July 2004
kr2(at)earthlink.net
PostPosted: Fri Aug 11, 2006 6:28 pm    Post subject: small file Blank series V weight and balance Reply with quote
Hi Kurt,I am also having a hard time with full elevator control for a stal
landing,I am landing with no flaps and seem to flair high and then
drop...no bounces yet lol...,I am flying with 2 200lb pilots and 26gal fuel
so I know Im heavy,but can we get more elevator authority?
Thanks for your input.........Kitfox4..N61AC
Mark.
[Original Message]
From: kurt schrader <smokey_bear_40220(at)yahoo.com>
Date: 8/8/2006 9:27:31 PM
Subject: Re: small file Blank series V weight and balance
Kurt S.
> X-MSN.
> that.
> CG
> > flaps......
PostPosted: Fri Aug 11, 2006 7:20 pm    Post subject: small file Blank series V weight and balance Reply with quote
In the two kitfoxes I have flown the cushions and my belly seem to block0 full up elevator travel, so I fly with no back cushion and had to make a cutout0 in the seat cushion. You might check yours for this problem. On the Citabria I0 have to lower my grip to keep my fingers out of the gut and I'm only 185 lb, 60 ft.
PostPosted: Fri Aug 11, 2006 7:23 pm    Post subject: small file Blank series V weight and balance Reply with quote
what is your c.g. you may need weight in the tail and should have0at0 least a mid range c.g.
PostPosted: Fri Aug 11, 2006 7:54 pm    Post subject: small file Blank series V weight and balance Reply with quote
I kept my CG forward so that I could carry a large
load in the baggage area with no problem. If I need
to move it aft some, I have a second battery just aft
of the firewall that I can relocate further aft to
make fine adjustments.
I calculate it will hold 135 lbs in the back, even
with full fuel and 2 people and still be OK. Running
empty, a 170 lb pilot can run all but the header tank
dry and still be in CG. I am over that weight, so
I've got all the fuel available too.
This does mean that I have a forward CG with no other
load on board though. But on my cross country flights
the average load puts it in a great place for an
enjoyable ride.
For landing, I normally use 1/2 flaps and push flaps
up on touchdown. It sits right down and stays there.
No flaps, I have to be careful or it will bounce, if I
don't stick the tail right. So far I do my best
landings when no one is looking and flub it
publically. Sad
and should have at least a mid range c.g.
PostPosted: Fri Aug 11, 2006 7:58 pm    Post subject: small file Blank series V weight and balance Reply with quote
I made cutouts for the sticks too. Origionally had
the sticks stop just forward of the seat, but later
adjusted the elevator so they stopped more forward.
My problem is not my gut but my legs reducing lateral
stick when it is back. I like all the crosswind
control I can get when landing. The more forward the
stick, the less I hit my legs. Still I probably only
get 50% throw stick back, unless I shove the stick
hard against my legs.
Kurt S. S-5
belly seem to block
gut and I'm only 185 lb, 6 ft.
PostPosted: Fri Aug 11, 2006 8:29 pm    Post subject: small file Blank series V weight and balance Reply with quote
I closed the gap from the stabilizer to the verticle
stab hatches with foam as much as I could when I built
mine just to increase the elevator authority. It has
no gap now when at full nose up stab. (stab front
down to the widest part of the verticle stab)
Later I plan to put in gap seals too. If that isn't
enough, I can add VG's under the stab or move that
little battery I have just aft of the firewall to
adjust the CG a little.
But for elevator authority you need to close the gaps,
make sure you have full elevator deflection, but no
more, and then stay within CG limits. That should do
it. Move some weight aft if you need to.
For some of my testing, I installed a 7 gal water tank
in the cargo bay aft end and that gave me near
centered CG. That didn't do as much as you might
expect to increase the elevator authority. Only near
aft CG limits made a big difference and I don't like
flying it like that for other reasons.
I compare my plane's feel to a C-180 with a stick and
twice the roll rate. In calm air, it feels like a
heavier plane, but it is still only takes a flick of
the stick to go where I want. Smile
Kurt S. S-5
elevator control for a stall
high and then
so I know Im heavy, but can we get more elevator
authority?
Mark
bmwebb(at)cox.net
PostPosted: Sat Aug 12, 2006 4:23 am    Post subject: small file Blank series V weight and balance Reply with quote
I think we had a similar discussion a while back. Try closing the gaps on
the elevator with clear tape, as seen on the Sportflight pics. While I can't
confirm a huge change on mine, others swear by it for getting elevator
effectiveness. I noticed an improvement, but nothing radical.
Also, a forward CG is a classic scenario of running out of elevator at low
speeds (in the flare). As the CG moves aft, the elevator gets move
authority, but it also gets more sensitive to small inputs at higher speeds.
Eventually it will get uncontrollable. Forward is better than aft, but you'd
be relegated to wheel landings.
Airplanes have loading limits, i.e., limited fuel with two passengers, etc.
You might want to check your W&B and see how different loadings affect you.
If you've not looked at it that way, you might be surprised.
My 2 runs out of elevator really quick with flap landings, but the gap seals
helped a little. Going from memory, a test I read showed that even a small
gap in a control surface reduces control effectiveness by as much as 30%. Hi
pressure always seeks low pressure, and it flows very nicely through that
gap. Thereby that air leak is not working for you.
Bradley
rjdaugh(at)rapidnet.com
PostPosted: Sat Aug 12, 2006 9:24 am    Post subject: small file Blank series V weight and balance Reply with quote
I should pass on something I found to give more tail down authority.
When I built my plane I wasn't sure where the adjustment should be on the
trim screw jack. So I put it about mid point. During a recent condition
inspection, I got curious and found that I was not getting the leading edge
of the horizontal stabilizer down as far as I could. So I moved the
connection on the screw jack to a low as I could get it.
This gives me much more tail down authority. I can put the tail wheel down
first even with full flaps. I have only tried dumping flaps a couple of
times. It works well, but I feel I am busy enough on landing without adding
another task. Wink
Randy Series 5/7
janderson412(at)hotmail.c
PostPosted: Sat Aug 12, 2006 3:30 pm    Post subject: small file Blank series V weight and balance Reply with quote
My CoG position sounds identical to yours Kurt, by my self I tend to do wheelers mostly for the same reason, but must try the dropping flap mthod. And yes, every time...old days I'd do 'greezers' all day in the old 188, come back to home base and 'plonk' every time!!
Date: Fri, 11 Aug 2006 20:53:02 -0700 (PDT)
--> Kitfox-List message posted by: kurt schrader <smokey_bear_40220(at)yahoo.com>
enjoyable ride.
publically. Sad
[quote] what is your c.g. you may need weight in the tail
Copy_of_RJA_W_Bal.xls
 Filename:  Copy_of_RJA_W_Bal.xls
 Filesize:  34 KB
 Downloaded:  250 Time(s)
PostPosted: Sat Aug 12, 2006 3:42 pm    Post subject: small file Blank series V weight and balance Reply with quote
I find that gap seals make quite a improvement.
Subject: RE: small file Blank series V weight and balance
Date: Sat, 12 Aug 2006 08:22:03 -0400
--> Kitfox-List message posted by: "Bradley M Webb" <bmwebb(at)cox.net>
Bradley
 Filesize:  57.08 KB
 Viewed:  277 Time(s)
 Filesize:  59.95 KB
 Viewed:  328 Time(s)
PostPosted: Sat Aug 12, 2006 8:51 pm    Post subject: small file Blank series V weight and balance Reply with quote
Hi Randy,
I am trying to remember from construction. Was the
slot in the access panel for the stab leading edge
already cut? Did yours go to the bottom of the slot
origionally and you cut more out, or did you already
have more room? I am just trying to figure an easy
point of comparison.....
Kurt S.
down authority.
So I moved the
it.
on landing without adding another task. Wink
Randy Series 5/7
PostPosted: Sun Aug 13, 2006 5:45 am    Post subject: small file Blank series V weight and balance Reply with quote
Kurt,
That slot, cut by Skystar, was what got me looking at it again. My trim was
not going all the way to the bottom of the slot. Now it does.
I thought that slot was awful big when I was building. But now I am using
all the slot! Hopefully I am the only one to make this mistake.
Randy
kerrjohna(at)comcast.net
PostPosted: Sun Aug 13, 2006 3:46 pm    Post subject: small file Blank series V weight and balance Reply with quote
This is a recurring thread and often addresses the benefit of sealing the horizontal stabilizer/elevator gap.
John Kerr
[quote]-------------- Original message --------------
load on board though. But on my cros s coun
& > _
PostPosted: Mon Aug 14, 2006 8:42 pm    Post subject: small file Blank series V weight and balance Reply with quote
Thanks John for the pics of the gap seals,this is the way I need to go.......Did you get this from spruce?
Thanks Mark
Goto page 1, 2  Next
Page 1 of 2
