W-1007E extends beyond rear spar flange. pg 15-3
jchang10
PostPosted: Sat Jul 29, 2006 11:00 am    Post subject: W-1007E extends beyond rear spar flange. pg 15-3 Reply with quote
Hi Deems...
http://www.deemsrv10.com/15-3s1-4.html
I noticed on your construction log where you had a problem with the
W-1007E flange being longer than the rear spar flange by 1-10". Van's
actually had to ship a new rear spar for you.
I have the same issue, extends beyond by 1-16" on BOTH left and right
wing doublers. The pictures below show a similar issue as yours. You can
see the doubler is flush against the spar in one of the pics. You can
click on each of the slide photos to get the full-sized 1024x768
picture.
http://www.jline.com/log/aviation/build/wingkit/photos/IMG_4366.html
http://www.jline.com/log/aviation/build/wingkit/photos/IMG_4367.html
http://www.jline.com/log/aviation/build/wingkit/photos/IMG_4368.html
http://www.jline.com/log/aviation/build/wingkit/photos/IMG_4369.html
I am wondering if anyone else had this similar issue. It did not seem
like much of an issue to me, until I happened across your web page.
Van's agreeing that it warranted shipment of a new rear spar, obviously,
makes me nervous.
Did anyone else see this issue?
Jae
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
Deems Davis
PostPosted: Sat Jul 29, 2006 12:38 pm    Post subject: W-1007E extends beyond rear spar flange. pg 15-3 Reply with quote
Jae,The real problem is not just that the doubler extends beyong the
spar cap, but when they make these parts ALL of the holes are
punched/drilled prior to bending, and when the bends get made wrong,
(which is what is causing the problem) it will shift all of the holes,
some might be tempted to match drill lthe holes into the doubler and
continue, but all of these holes will be misalligned with the skins,
when it come time to put them on, check to make sure this isn't the case
with the parts you get, (I'm a bit surprised to see this problem showing
up in later wing kits).
Deems Davis # 406
Fuse/Finishing/Panel
http://deemsrv10.com/
Jae Chang wrote:
Hi Deems...
picture.
makes me nervous.
Jae
jchang10
PostPosted: Thu Aug 03, 2006 1:11 pm    Post subject: W-1007E extends beyond rear spar flange. pg 15-3 Reply with quote
I just want to close this thread. I got a response back from Van's. They
said it is not an issue. I could file the bit that over-extends the
flange, if I want to.
I will just continue on and hope for the best, as always.
Jae
Deems Davis # 406
#40533 RV-10
Deems Davis
PostPosted: Thu Aug 03, 2006 1:39 pm    Post subject: W-1007E extends beyond rear spar flange. pg 15-3 Reply with quote
Jae, FWIW check that the distance of the holes in the spar cap from the
edge is the same all of the way along the spar. In the spar I received
they were not, which meant that the holes were not going to align with
the wing skins. Also I had a small gap at the bend between the spar and
the doubler, when I received the new spar there was no gap and the
pieces fit snuggly.
Deems Davis # 406
Jae
Deems Davis # 406
