701 seat belt attach
John Bolding
PostPosted: Wed Aug 02, 2006 10:53 pm    Post subject: 701 seat belt attach Reply with quote
What DIFFERENCE does it make if some dimension on0 the seat belt attach fitting does not match a drawing when the WHOLE DAMN0 FITTING pulls out in an accident and lets you kiss the panel ??? This is0 NOT green vs. maroon scotchbrite, this is the restraint system on0 your aircraft which some of us on this list (and/or our friends and loved0 ones)will one day need and test to its limits. The 701 seat belt0 attach has been shown recently that it is probably/possibly (you0 choose)not up to the task .
I have no clue if the 601 is the same design as I0 don't have those drawings (somebody help me here) but if it does hopefully0 enough folks will bug Zenith for an analysis of the failure(MAYBE it was an0 anamoly) and a fix, if warranted. Since Jon's accident I have looked thru my0 collection of about 35 homebuilt aircraft drawings (too many airplanes, not0 enough time) and NONE of the seat belt fittings are secured with a row of 50 pulled rivets into a single thickness of .025 aluminum. Not even close. Maybe0 Chris has figured out something that Thorpe, Thurston,C.G. Taylor,Van, and0 others didn't......If a seat belt attach fitting pulled out of a Ford and some0 cute 10yr old went thru a windshield you would hear about it on CNN.and0 1,678 personal injury lawyers would have a collective orgasm. The engineers0 would be all over it NOW.
This was brought up right after Jon was gracious0 enough to allow us post mortum pictures and the interest level was0 almost non-existent but since then there has been hundreds of posts of0 mostly fluff when compared to the importance of this (in my deranged mind0 anyway). If I'm playing left field without a glove somebody tell me to sit0 down and keep quiet. When you do, gently explain to me how 50 "poprivets" into a sheet of alum slightly thicker than a beer can is going to0 keep me in place at 40 G's. It didn't work with Jon.
I REALLY shouldn't write stuff at 1:30 AM but I'm0 thick skinned so fire away!! LOW&SLOW 0 John
doug kandle
PostPosted: Thu Aug 03, 2006 6:26 am    Post subject: Re: 701 seat belt attach Reply with quote
I don't watch this thread all of the time and so I am not familiar with the incident with Jon. Could you say what basically happened or point me to the thread with that discussion.
nfivesl(at)yahoo.com
PostPosted: Thu Aug 03, 2006 6:44 am    Post subject: 701 seat belt attach Reply with quote
John:
As usual you bring up a very good point. I talked to
Jon Croke at Oshkosh and saw his scars. Thanks for
the post. I'm attaching a portion of a scan from my
601XL drawings showing the 601XL seat belt attachment.
Here is a picture of mine installed since I followed
the drawings while building.
http://www.cooknwithgas.com/3_02_06_ELT.jpg
As you can see in the photo it is not used and I
attached mine further back using AN3 bolts into a 3/4"
thick longeron.
I did this for peace of mind. Thanks again,
Scott Laughlin
working on Engine Cowl
 Filesize:  69.99 KB
 Viewed:  587 Time(s)
NYTerminat(at)aol.com
PostPosted: Thu Aug 03, 2006 6:50 am    Post subject: 701 seat belt attach Reply with quote
Was it the shoulder or seat tunnel attachment that let0 go?
In a message dated 8/3/2006 10:46:41 A.M. Eastern Daylight Time,0 nfivesl(at)yahoo.com writes:
John:
As usual you bring up a very good point. I talked0 to
the0 post. I'm attaching a portion of a scan from my
601XL drawings0 showing the 601XL seat belt attachment.
Here is a picture of mine0 installed since I followed
the drawings while building. 0
As you can see in the0 photo it is not used and I
attached mine further back using AN3 bolts into0 a 3/4"
thick longeron.
I did this for peace of mind. 0 Thanks again,
Scott Laughlin
working0 on Engine Cowl
--- John Bolding0 <jnbolding1(at)teleshare.net> wrote:
I have no clue if the06010 is the same design as I
don't have those drawings (somebody help me0 here)
[/quote]
doug kandle
PostPosted: Thu Aug 03, 2006 7:09 am    Post subject: Re: 701 seat belt attach Reply with quote
We had a tragic accident at an airport here that shows just how difficult it is to know how to attach the seat belts. A Long EZ went off the runway and broke off the main gear. The pilot died because as the gear came off it yanked down on the shoulder harness (which was apparently attached to or near the gear). He appeared OK but died as they were loading him into the ambulance. This just goes to show that you don't want the belts attached to the strongest part of the plane, if it is at all possible for that part to be separated from your seat.
I have some worry about the attachment on the side if the 701. If the gear were to be hit very hard (like by a ditch on a forced landing), then they might twist off. In that case if they don't break free, they would wind up the side of the 701 (which is exactly where the seat belt is attached). I just hope that the design has the gear retaining bolts breaking before the airframe deforms significantly.
tya2(at)4-fly.net
PostPosted: Thu Aug 03, 2006 8:23 am    Post subject: 701 seat belt attach Reply with quote
Dear List,
The issue with seat belt attachment points and their strength is not just
a homebuilt aircraft problem, it exists with real commercial aircraft as
well. Last week 5 people were seriously injured then their seat belt
attachment points failed in a Dash 8 turboprop aircraft flying over
Manitoba Canada. The Canadian Transportation Safety Board is
investigating. The seat belt attachment points failed in turbulence and
not in a CRASH!!.
Remember we don't have a 40 g body.
Rocky
1995 CH2000
armyret(at)mchsi.com
PostPosted: Thu Aug 03, 2006 11:30 am    Post subject: 701 seat belt attach Reply with quote
John- I can't speak to the 701 seat belt0 situation, but I can from first hand speak to the 601XL seat belt. A year0 ago, I nosed into a concrete runway in my 601XL, crushed nose wheel, bent back0 up into the cabin floor, prop shattered, etc etc. I didn't have a scratch0 as the seat belt held as it was designed to do. Last month I bounced a C-172 on0 a grass strip and bent the rear fuselage enough that I lost all control of0 rudder and elevator.(Cables loosened), End result, broken nose wheel, totaled0 the Cessna. I was thrown into the right side window, breaking it and my0 nose, head etc. The only difference in these two incidents were the Cessna0 didn't have a shoulder belt and the 601XL did. The seat belt on the Cessna0 held or I would have been a stat for the NTSB. I've got much faith in0 the 601XL seat belt system. As I re-build, I noticed that the 601XL0 seatbelt attachment points were not harmed, not even bent.
Al Young
601XL
dougsnash(at)yahoo.com
PostPosted: Sun Aug 06, 2006 6:35 am    Post subject: 701 seat belt attach Reply with quote
I discussed Jon's seat belt bracket issues with the
CAN-ZAC boys at Oshkosh. They have looked at Jon's
plane and specifically looked at the seat belt issue.
They told me that the top shoulder belt attachment is
designed to allow some give (crumple zone). On Jon's
plane this function served well. They did suggest
beefing up the attachment point a bit on the tunnel
since this is what let go on Jon's plane.
I'm thinking an 040 doubler on the inside of the
tunnel might be the answer. I'm not to that point and
will be discussing further with CAN-ZAC when I start
to get close.
Doug MacDonald
CH-701 Scratch Builder
NW ONtario, Canada
n4546v(at)mindspring.com
PostPosted: Sun Aug 06, 2006 7:18 am    Post subject: 701 seat belt attach Reply with quote
Lister Chuck Dietrich identified this concern, came up with a fix, and
installed it on his 701 before he flew. He has posted about it and I'm sure
it's in the archives. I'm sure he'd comment again if asked.
Randy L. Thwing, Las Vegas do not archive
to get close.
Doug MacDonald
NW ONtario, Canada
cffd(at)pgrb.com
PostPosted: Sun Aug 06, 2006 8:54 am    Post subject: 701 seat belt attach Reply with quote
Doug,
Here is what I wrote.
When I built my 701, I did not feel comfortable with the aluminum seat belt
attachment that was riveted to the tunnel. In fact, somewhere 4 or 5 years
ago, on this forum, I read where the bolt between the seat belt and the
aluminum attachment pulled a slot through the attachment. So I made my
attachment from 0.40" 4130 steel instead of 0.40" 6061 aluminum. I then
used the 0.40" 6061 as a doubler on the inside of the tunnel to give more
thickness to keep the rivets from pulling through. I did not ask ZAC about
this, but I feel that this is a stronger anchor which actually gets pulled
by both the lap and shoulder straps.
Chuck D.
N701TX
mgraves(at)usmo.com
PostPosted: Mon Aug 07, 2006 2:18 am    Post subject: 701 seat belt attach Reply with quote
Here is a picture of the 701 plane crash that Chuck D. refers to........N4386W
And a picture of the seat belt attachment showing it pulled through.
It was not Chuck's or my plane. I believe the plane was in Colorado at the
time
Monty Graves
At 11:53 AM 8/6/2006 -0500, you wrote:
Doug,
Chuck D.
N701TX
 Filesize:  22.98 KB
 Viewed:  605 Time(s)
 Filesize:  149.04 KB
 Viewed:  595 Time(s)
rwehba(at)cebridge.net
PostPosted: Mon Aug 07, 2006 3:05 am    Post subject: 701 seat belt attach Reply with quote
did it hit a hole and flip??
cffd(at)pgrb.com
PostPosted: Mon Aug 07, 2006 7:54 am    Post subject: 701 seat belt attach Reply with quote
NSTB report:
Meshko Zenair / CH-701, Subaru / EA 81 150TTB1
The pilot had just taken off and was climbing at 80 percent power (5,000
rpm) when he noticed the EGT rising "into redline 1,625 degrees F." He
leveled off, reduced power to 4,800 rpm, and reduced propeller pitch. EGT
stopped rising and came down slightly, but was still above redline. All
other engine indications were normal. EGT continued to rise and the engine
started losing power and was "running rough." The pilot tried to land at a
nearby airport, but was forced to make a landing in an open field. He said
he flared at the the last moment and hit the ground sharply. The nose wheel
broke off when it struck a tire track and the airplane nosed over. The
pilot, who also built the airplane, suspected detonation caused the rise in
EGT.
mgraves(at)usmo.com
PostPosted: Mon Aug 07, 2006 8:11 am    Post subject: 701 seat belt attach Reply with quote
I forget what happened. Its in the archives
Looks more like he tried to land going across the rows instead of with
them. Looks like the nose wheel completely separated from the
aircraft. Then the nose and prop dug in and flipped....... Not sure what
kind of stubble that is, but a sure way to do some serious damage is land
in corn stubble across the rows.......
The plane was painted in Frontier Airline colors. I believe the pilot was
a pilot for them with high time hrs... just not in the 701........
Monty
JERICKSON03E(at)aol.com
PostPosted: Mon Aug 07, 2006 9:48 am    Post subject: 701 seat belt attach Reply with quote
In a message dated 8/7/2006 5:20:27 AM Central Daylight Time, mgraves(at)usmo.com writes:
time
It seems to be an early design, the belt attachment fitting thickness on early prints is .040.
Current prints call for .063 thickness. Just for info.
entecrj(at)sbcglobal.net
PostPosted: Mon Aug 07, 2006 11:00 am    Post subject: 701 seat belt attach Reply with quote
them. Looks like the nose wheel completely separated from the aircraft.
Then the nose and prop dug in and flipped....... Not sure what kind of
stubble that is, but a sure way to do some serious damage is land in
Monty
Thats wheat stubble in the picture, wheat stubble rows are fairly shallow,
but you can't rule out ruts from combine and grain cart tires.
R. Johnson
cffd(at)pgrb.com
PostPosted: Mon Aug 07, 2006 12:18 pm    Post subject: 701 seat belt attach Reply with quote
The 200 pound Subaru probably did not help the nose gear and the ability to
flare.
NSTB report:
wheel
in
[quote] EGT.
ggower_99(at)yahoo.com
PostPosted: Mon Aug 07, 2006 11:18 pm    Post subject: 701 seat belt attach Reply with quote
I am no expert in accidents but have made a couple of search and rescue missions and have talked to local experts a lot. This gives me some hints where to look.
I think this pilot got "get-down-itis" and just pointed to nose to the ground. Maybe he tried or thinked to level for flare when the front wheel was about an inch from the ground.
Look at the wing tips they just smashed to the ground, not a low speed stall, because both wing tips are damaged very similar, The plane was flown to the ground, also the distance where front wheel and the prop hub touched the ground is only a few inches from the nose of the inverted plane.
Good thing that was the old and lighter 701 and (I think) was not going fast (40 mph or less maybe), but he just hit the ground at an angle (?)!. He was lucky to survive (he is commenting the accident, another hint Smile...
Just my point of view, probably completly wrong. Please Do not archive.
Saludos
Gary Gower.
Flying from Chapala, Mexico.
Chuck Deiterich <cffd(at)pgrb.com> wrote:[quote] --> Zenith-List message posted by: "Chuck Deiterich"
NSTB report:
EGT.
