Hopperdhh(at)aol.com Guest
Posted: Fri Jul 28, 2006 9:21 am Post subject: Rear Prop Gov. Questions |
I searched the archives, but couldn't find answers to these questions.
I am thinking of putting an IO-360-A1A engine in my RV-7A. It has been flying with an IO-360-A1D6 which has a front mounted governor.
Could someone on the list please tell me approximately what the thickness of the rear mounted prop governor adapter pad is on an IO-360-A1A? I have an old one that measures about 2 1/16 inches. Is there a thinner one available? The dimension I need is from the accessory case to the prop governor itself.
Also, will the McCauley governor off the left front of my IO-360-A1D6 work on the rear of the -A1A? As far as I can tell there is about 3 percent difference in the drive ratio -- 0.866 vs 0.895. I would assume that the governor could be adjusted for this difference. Is there some other reason why it won't work?
Dan Hopper
RV-7A
Posted: Mon Jul 31, 2006 10:31 am Post subject: Rear Prop Gov. Questions |
I posted this last week, but didn't get answers.
Maybe someone on the list could point me to a picture of a rear mounted=2 prop governor so I could get a feel for how much room there is. Probably=2 an O-6 would be the same.
Dan
I searched the archives, but couldn't find answers to these=2 questions.
I am thinking of putting an IO-6-AA engine in my RV-7A. It=2 has been flying with an IO-6-AD6 which has a front mounted governor.
Could someone on the list please tell me approximately what the thickness=2 of the rear mounted prop governor adapter pad is on an IO-6-AA? I have=2 an old one that measures about 2 /6 inches. Is there a thinner one=2 available? The dimension I need is from the accessory case to the prop=2 governor itself.
Also, will the McCauley governor off the left front of my IO-6-AD6 work=2 on the rear of the -AA? There is about percent difference in the drive=2 ratio -- .866 vs .895. I would assume that the governor could be=2 adjusted for this difference. Is there some other reason why it won't=2 work?
Dan Hopper
RV-7A
Dale Ensing
Posted: Mon Jul 31, 2006 4:15 pm Post subject: Rear Prop Gov. Questions |
Dan,
I'll try to get a decent picture tomorrow of my rear mounted govenor.0 However, my set up is a Woodward govenor on a O-360 in a 6A. But, if you think0 it well help I'll send the picture.
Dale Ensing
| Quote: | Maybe someone on the list could point me to a picture of a rear mounted0 prop governor so I could get a feel for how much room there is. Probably0 an O-360 would be the same.
Dan
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Posted: Tue Aug 01, 2006 3:51 am Post subject: Rear Prop Gov. Questions |
Hi Dan-
| Quote: | I posted this last week, but didn't get answers.
Funny how that goes sometimes, with all the talent on this list!
prop
| Quote: | governor so I could get a feel for how much room there is. Probably an
It appears on page 2-4 of parts catalog PC-406-1.
I've an RV-8 with an IO-360-A1B6D with a Czech gov on the back so there is
no direct correlation to your installation. My pad is about 7/8 thick and
I have about 4 1/8 between the rearmost part of the gov (the end of the
cable attach bolt) and the firewall.
I do believe that all the gov's except Woodward have the same (AN)
footprint.
According to what I get out of the parts catalog, the correct adaptor for
your installation would be #75545 if the case has studs and #78594 if your
installation uses cap screws. Perhaps there is a part number on the
adaptor you have? I wouldn't be at all surprised if you've got all you
need already!
Sorry I couldn't be of more direct assistance-
glen matejcek
aerobubba(at)earthlink.net
Posted: Tue Aug 01, 2006 4:16 am Post subject: Rear Prop Gov. Questions |
Dale,
I think that other replies may have answered my question -- at least0 about the adapter.
Dan
In a message dated 7/31/2006 8:17:36 P.M. Eastern Daylight Time,0 densing(at)carolina.rr.com writes:
Dan,
I'll try to get a decent picture tomorrow of my rear mounted0 govenor. However, my set up is a Woodward govenor on a O-360 in a 6A. But, if0 you think it well help I'll send the picture.
Dale Ensing
| Quote: | Maybe0 someone on the list could point me to a picture of a rear mounted prop0 governor so I could get a feel for how much room there is. Probably an0 O-360 would be the same.
Dan
| [/quote]
chaztuna(at)adelphia.net Guest
Posted: Wed Aug 02, 2006 6:04 am Post subject: Rear Prop Gov. Questions |
Dan Hopper
RV-7A |
Dan,
My adapter & Woodward governor assembly is 8.75" total length from the gasket surface of the accessory cover. I hope this helps. I suspect that your governor will work "as is". If an issue surfaces after the conversion, the unit can be modified by any competent prop shop.
Charlie Kuss
Posted: Wed Aug 02, 2006 6:21 am Post subject: Rear Prop Gov. Questions |
Charlie,
What plane and engine do you have?
Dan
In a message dated 8/2/2006 10:06:31 A.M. Eastern Daylight Time,0 chaztuna(at)adelphia.net writes:
I searched the0 archives, but couldn't find answers to these questions.
I am0 thinking of putting an IO-360-A1A engine in my RV-7A. It has been0 flying with an IO-360-A1D6 which has a front mounted0 governor.
Could someone on the list please tell me0 approximately what the thickness of the rear mounted prop governor adapter0 pad is on an IO-360-A1A? I have an old one that measures about 2 1/160 inches. Is there a thinner one available? The dimension I need0 is from the accessory case to the prop governor itself.
Also,0 will the McCauley governor off the left front of my IO-360-A1D6 work on0the0 rear of the -A1A? As far as I can tell there is about 3 percent0 difference in the drive ratio -- 0.866 vs 0.895. I would assume that0 the governor could be adjusted for this difference. Is there some0 other reason why it won't work?
Dan0 Hopper
RV-7A |
Dan,
My adapter & Woodward0 governor assembly is 8.75" total length from the gasket surface of the0 accessory cover. I hope this helps. I suspect that your governor will work "as0 is". If an issue surfaces after the conversion, the unit can be modified by0 any competent prop shop.
Charlie Kuss
[/quote]
Posted: Wed Aug 02, 2006 6:49 am Post subject: Rear Prop Gov. Questions |
Dan
I'm building an 8A. I'm using a parallel valve 360. The governor is out of an old Apache, but has been converted for use with my current setup.
Charlie
Charlie,
Dan
In a message dated 8/2/2006 10:06:31 A.M. Eastern Daylight Time, chaztuna(at)adelphia.net writes:
Dan Hopper
RV-7A |
Dan,
Charlie Kuss
Posted: Wed Aug 02, 2006 1:48 pm Post subject: Rear Prop Gov. Questions |
Thanks Charlie and others for the info.
Here are a few more questions I have:
As far as I can tell from my measurements with the engine not assembled0 yet, it looks like the end of the governor will come back about even with the0 firewall. Does anyone else with a -7A know if this is OK? In other0 words, it is OK for the governor to extend into the recess a little? Will0 it clear the sides of the recess enough to allow for engine movement?
Also, would someone please explain the metal plate that sometimes gets0 thrown away with the gasket. I need to come up with one of these, I0 guess. Exactly where does it go, and what purpose does it serve?
Dan Hopper
RV-7A
In a message dated 8/2/2006 10:53:21 A.M. Eastern Daylight Time,0 chaztuna(at)adelphia.net writes:
Dan
I'm building an 8A. I'm using a parallel valve 360. 0 The governor is out of an old Apache, but has been converted for use with0my0 current setup.
Charlie
Charlie,
What plane and engine do you0 have?
do not0 archive
Dan
| [/quote]
Posted: Thu Aug 03, 2006 3:41 am Post subject: Rear Prop Gov. Questions |
Hi Dan-
| Quote: | Also, would someone please explain the metal plate that sometimes gets
thrown away with the gasket. I need to come up with one of these, I guess.
The metal plate goes between two gaskets, and the trio is then placed
between the gov and the case. It seems that there is an oil passage that
is too close to the edge of the mating surfaces, and without the plate the
gasket material can blow out and port all you oil overboard. IIRC, there
is at least one such scenario in the archives. And, yes, it's quite easy
to chuck the plate with the gaskets. You may wonder how I know that...
glen matejcek
Posted: Thu Aug 03, 2006 3:59 am Post subject: Rear Prop Gov. Questions |
My jihostroj governor doesn't even come close to the recess.....
If my engine vibrates enough for it to touch - even once - I got significantly larger problems.......
[quote]--
Posted: Thu Aug 03, 2006 4:17 am Post subject: Rear Prop Gov. Questions |
I don't recall getting a 'plate' with my Jihostroj governor.
Details please! How thick, what shape, what material, specific to governor brand, where in what manual is it referred to, anyone got pictures.....?
Ralph Capen
Posted: Thu Aug 03, 2006 4:54 am Post subject: Rear Prop Gov. Questions |
| Quote: | --> RV-List message posted by: "glen matejcek" <aerobubba(at)earthlink.net>
Hi Dan-
between the gov and the case. |
Glen,
You have me confused by the use of the word "case" above. I was under the impression that these items were located between the governor and the adapter. Am I wrong? Do they go between the adapter and the accessory case?
Charlie Kuss
Posted: Thu Aug 03, 2006 8:33 am Post subject: Rear Prop Gov. Questions |
Glen,
I too need some clarification. I have a governor, an adaptor, and an0 accessory case. At which joint does the metal plate go? Apparently0 the metal plate must have a rough surface or serrations, etc., that hold the0 gaskets better. Is this true?
I'll look over the parts and see if I can tell where the oil passageway is0 that is close to the edge.
Something that I had never thought about is that the prop pressure must run0 well above engine oil pressure -- perhaps 150 PSI? That means that the0 front main bearing is being lubricated by this pressure too, since there are no0 seals between the prop feed and the 2 bearing surfaces on the front main0 bearing.
Dan Hopper
RV-7A
In a message dated 8/3/2006 7:43:36 A.M. Eastern Daylight Time,0 aerobubba(at)earthlink.net writes:
-->0 RV-List message posted by: "glen matejcek"0 <aerobubba(at)earthlink.net>
Hi Dan-
| Quote: | Also, would someone0 please explain the metal plate that sometimes gets
thrown away with0 the gasket. I need to come up with one of these, I guess.
Exactly0 where does it go, and what purpose does it serve?
The metal plate goes0 between two gaskets, and the trio is then placed
between the gov and the0 case. It seems that there is an oil passage that
is too close to0the0 edge of the mating surfaces, and without the plate the
gasket material0can0 blow out and port all you oil overboard. IIRC, there
is at least0one0 such scenario in the archives. And, yes, it's quite easy
to chuck the0 plate with the gaskets. You may wonder how I know that...
glen0 ==================================================es0 Day0 0 0
-->0 ================================================== - NEW MATRONICS LIST WIKI -
_-=0 sp;0 0 ->0 =========================p;0 - List Contribution Web Site0 0 0 ==================================================
[/quote]
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Sat Aug 05, 2006 1:38 pm Post subject: Rear Prop Gov. Questions |
I can attest to the dumping oil overboard scenario having just
experienced it on my trip to Oshkosh. The Lyc in my Navion has a similar
adapter for the prop governor with a thin plate sandwiched by two
paper-thin gaskets. One of the gaskets let go (at the high pressure
port) and it was pumping a quart out every 2 hours. It turned out to be
one of the cheapest to fix problems I've had but it was unnerving and
could have been worse. Be careful if you have that setup. Use the
manuals to be sure you get it right.
Greg Young
then placed between the gov and the case. It seems that
there is an oil passage that is too close to the edge of the
mating surfaces, and without the plate the gasket material
can blow out and port all you oil overboard. IIRC, there is
quite easy to chuck the plate with the gaskets. You may
