tmathieu(at)MSN.COM Guest
Posted: Wed Aug 02, 2006 1:04 pm Post subject: Message regarding autopilot |
I have an old Bendix autopilot on my 500 Shrike. It has been giving us trouble while trying to hold the heading bug or in the Nav function. Anyone have a suggestion as to who might be best qualified to troubleshoot this system. Also, if you were going to upgrade, which system would you go with and what should I expect to spend on such a system. Any help would be tremendously appreciated.
Sincerely,
Tommy Mathieu
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
dowens(at)aerialviewpoint Guest
CloudCraft(at)aol.com Guest
Posted: Wed Aug 02, 2006 1:26 pm Post subject: Message regarding autopilot |
In a message dated 02-Aug-06 14:06:43 Pacific Daylight Time, tmathieu(at)MSN.COM writes:
| Quote: | | I have an old Bendix autopilot on my 500 Shrike. It has been giving us trouble while trying to hold the heading bug or in the Nav function. Anyone have a suggestion as to who might be best qualified to troubleshoot this system. Also, if you were going to upgrade, which system would you go with and what should I expect to spend on such0a system. Any help would be tremendously appreciated. |
Tommy,
You didn't say which old Bendix A/P you have -- is it an M4 series?
If so, make sure your "TURN" command knob is in the center detent. It's a very subtle detent and if it's out, it cancels HDG mode or NAV mode.
See the "TURN" knob below.
Next, check your ROLL trim. On some A/P control heads, if this is pulled out, it can cancel or interfere with HDG mode. This also has a detent, so see if you can find it and start engaging HDG or NAV mode from that point.
If either of those checks don't get you0happy, take the airplane to Autopilots Central in Tulsa, OK. That may be far away from you, but I don't know of anyone left who understands0the Bendix/Motorola M4s.
There are some trim pots than can be adjusted for ROLL or NAV track and that's best done in flight with the autopilot technician turning set screws while you keep the airplane safe.
It may be that you need a circuit board replaced. Autopilot Central should have them, or, can trouble shoot components if need be.
It may be that you need the autopilot replaced and I trust if that's so, several TCFG members will check in with their recommendations on modern systems.
Good luck!
Wing Commander Gordon
21.59 KB |
578 Time(s) |
kamala(at)MSN.COM Guest
Posted: Wed Aug 02, 2006 1:43 pm Post subject: Message regarding autopilot |
tm, re auto pilot refer to century flight systems in mineral wells tx.
system 2000 works real well. mason
| Quote: | From: "Tommy Mathieu" <tmathieu(at)msn.com>
Reply-To: commander-list(at)matronics.com
To: <commander-list(at)matronics.com>
Subject: Message regarding autopilot
Date: Wed, 2 Aug 2006 16:02:42 -0500
Sincerely,
Tommy Mathieu
<< image001.jpg >>
hcourier(at)cox.net Guest
Posted: Wed Aug 02, 2006 1:48 pm Post subject: Message regarding autopilot |
Hi Tommy,
I have an old Bendix M4 in the Aero Commander I fly and0 it was not working about a year ago. I knew a man in Ferandina Beach, FL0 who did avionics and I asked him about it. He said, "I've been working on0 the M4 since 1961 when they came out and have many parts around". So I0 sent him the controller and black box. He fixed it and it works great0 now. It's very steady and except for a few minor quirks (nothing0 bothersome) it's great. He has all the test equipment for it too.
He's not doing as much avionics work as he use to but he0 might work on it if your are not in a hurry. I've got another Bendix at0 his shop...so mine comes first,...ha! ha!
Send me your email address and I'll give you his particulars, address, phone number, etc. I don't know if he's looking for0 a lot of business these days. He's doing more corporate flying now than he0 use to.
Ray Mansfield
hcourier(at)cox.net (hcourier(at)cox.net)
----- Original Message0 -----
| Quote: | From:0 Tommy Mathieu (tmathieu(at)MSN.COM)0
To: commander-list(at)matronics.com (commander-list(at)matronics.com)0
Sent: Wednesday, August 02, 2006 4:020 PM
Subject: Message0 regarding autopilot
I have an old Bendix0 autopilot on my 500 Shrike. It has been giving us trouble while trying to hold0 the heading bug or in the Nav function. Anyone have a suggestion as to who0 might be best qualified to troubleshoot this system. Also, if you were going0 to upgrade, which system would you go with and what should I expect to spend0 on such a system. Any help would be tremendously0 appreciated.
Sincerely,
Tommy0 Mathieu
dfalik(at)sbcglobal.net Guest
Posted: Wed Aug 02, 2006 7:28 pm Post subject: Message regarding autopilot |
When I purchased my 500 Shrike I had an S-tec 60-2 installed and it was a used one. It cost around 12,500 once it was said and done.
Posted: Thu Aug 03, 2006 4:41 am Post subject: Message regarding autopilot |
Thank you all so much for the input. We have an appointment set up with Autopilot Central in Tulsa. I also copied the instructions you gave for troubleshooting the system. I cannot thank you all enough. It is greatly appreciated!
Sincerely,
Tommy Mathieu
Posted: Thu Aug 03, 2006 8:50 am Post subject: Message regarding autopilot |
They have worked well for us, and will use them0 again... Good Luck!
David Owens
Aerial0 Viewpoint
N14AV
AC-500A-Colemill
amg3636(at)hotmail.com Guest
Posted: Thu Aug 03, 2006 4:24 pm Post subject: Message regarding autopilot |
For what it is worth,
The avionics guy at my airport has some old autopilot parts. Don't know what
brand or details. Heres contact info.Sandhills Avionics , Jeff Kraudelt,
910-947-1760.or Sandhills(at)PlaneWerks.com
Roland Gilliam
[quote]From: Ray Mansfield <hcourier(at)cox.net>
Subject: Re: Message regarding autopilot
Date: Wed, 02 Aug 2006 16:50:27 -0500
Hi Tommy,
I have an old Bendix M4 in the Aero Commander I fly and it was not
working about a year ago. I knew a man in Ferandina Beach, FL who did
avionics and I asked him about it. He said, "I've been working on the M4
since 1961 when they came out and have many parts around". So I sent him
the controller and black box. He fixed it and it works great now. It's
very steady and except for a few minor quirks (nothing bothersome) it's
He's not doing as much avionics work as he use to but he might work on
it if your are not in a hurry. I've got another Bendix at his shop...so
phone number, etc. I don't know if he's looking for a lot of business
these days. He's doing more corporate flying now than he use to.
Ray Mansfield
hcourier(at)cox.net
moe(at)rosspistons.com Guest
Posted: Fri Aug 04, 2006 7:06 am Post subject: Message regarding autopilot |
Gents:
Regarding the M1 Autopilots.
Jack Chappell (Phone 951.371.7513) should have quite a few parts for the M1
and some servo testers that he got from me a while back. I also have the
complete shop manuel with fold out diagrams ect. that I bought from Mark
Thompson a while back. I beleive that I paid $ 250.00 for it. If anyone
needs it I will sell it to you for a GREATLY reduced price.
Moe
N680RR
680F(p)
BillLeff1(at)aol.com Guest
Posted: Wed Aug 09, 2006 8:00 pm Post subject: Message regarding autopilot |
Avionics Inc. at LUK Cincinnati does great M-4 work. He has been working on0 them for years and does not just suggest "replace it.
In my opinion I would not replace an M-4 with any of these new autopilots0 unless I could not fix it.
I would love to have one in my 560F but I can not get the paperwork!
Bill Leff
Skyhawkc-172
Posted: Fri Aug 11, 2006 9:22 am Post subject: Message regarding autopilot |
Any thoughts on a Britten B4 autpilot, we have one that is currently inoperative.
Thanks guys...
Brent Mueller - N224HA
| Quote: | -------------- Original message --------------
Avionics Inc. at LUK Cincinnati does great M-4 work. He has been working on them for years and does not just suggest "replace it.
In my opinion I would not replace an M-4 with any of these new autopilots unless I could not fix it.
Bill Leff
br549phil(at)mindspring.c Guest
Posted: Sun Aug 13, 2006 8:13 pm Post subject: Message regarding autopilot |
Hi Bill,
I still have an L2 which works a bit. What do you have in yours?
I'd like to replace it.
Phil Stubbs
Posted: Mon Aug 21, 2006 9:41 pm Post subject: Message regarding autopilot |
I had a Collins AP-102E. Nobody can fix it. There is one test set in the world! and it is in Asia!!
I am currently installing a Century III witch is approved for the 560F
Bill Leff
Posted: Tue Aug 22, 2006 11:40 am Post subject: Message regarding autopilot |
Hi Bill,
Just found out the Chelton AP-3c is STCd for the 560F. I'm exploring that but was wondering if you got your CIII from salvage 560F or what?
Phil Stubbs
tylor.hall(at)sbcglobal.n Guest
Posted: Tue Aug 22, 2006 12:27 pm Post subject: Message regarding autopilot |
Phil,I just looked on the Chelton web site and no Aero Commanders were listed.
What models have they added?
Any thing on a 680E?
Tylor Hall
On Aug 22, 2006, at 1:39 PM, "" <br549phil(at)mindspring.com (br549phil(at)mindspring.com)> wrote:
[quote] Hi Bill,
Phil Stubbs
Posted: Wed Aug 23, 2006 9:26 pm Post subject: Message regarding autopilot |
I got most of the parts from a Shrike that it was removed from. I have all the paperwork and drawings. It is available from Century.
