Fuel System Manager
Goto page Previous  1, 2, 3, 4  Next
wsimpso1
PostPosted: Fri Feb 27, 2026 6:47 am    Post subject: Re: Fuel System Manager Reply with quote
I have several points that I feel must be made. Maybe I am talking to Pete, maybe I am talking to other folks.
Please, please, please prevent your system from turning into a Greek Tragedy. Pay attention to what Bob Nuckolls has been preaching, page 17-14 of The AeroElectric Connection:
“First Law: “Things break”
Second Law: “Systems shall be designed so that when things break, no immediate hazard is created”
Third Law: “Things needed for comfortable termination of flight requires backup or special consideration to insure operation and availability”
Forth Law: “Upgrading the quality, reliability, longevity, or capability of a part shall be because you’re tired of replacing it or want some new feature, not because it damned near got you killed”
We are talking Experimentals. Usually that means every individual airplane you see is unique. The differences may be small but they can matter. This counts in RV-7’s where there are thousands, so it certainly counts in the Viper Jet where Wikipedia indicates seven (7!) have flown. More complete Apollo systems flew to the Moon and every one of them was an individual. I strongly suspect that Pete’s Viper jet is not a one of a line of well proven birds, but is different in a bunch of ways from the seven that have already flown.
Pete’s Viper Jet is not being built to the plans and with the intended and only modestly demonstrated fuel transfer system. Pete is changing the design. He does not have the computer nor the valves specified, and that also means he is most likely changing the plumbing and wiring to accommodate the new pieces. Given this collection of design changes, I seriously wonder how many other changes are being made… The different pieces may or may not be completely interchangeable. You should have a plan up front, criteria to check, a decision process, then check the criteria comparing new to old, and stick to the decision process. If you need a different valve or bigger tubes or less restrictive connections, so be it.
In the valves, your going in assumption might be that the original design was OK. Was it? With only seven ever flown, I do wonder just how well it worked. I really do not expect any info on how well it aged. Has anybody commented on the main drawing down in some flight modes? How many emergencies have been declared?
I would want to know the pressure drop across the valves vs flow rates through them. Find out what the intended valve did and what the new one does. The manufacturers or the internet or maybe the Wayback Machine can all be checked to get headloss vs flow rates in these parts. The specified 150 psi valve might have been schemed out to lose only a couple psi at your max burn rate, but a 3000 psi valve might not be so free flowing - and work just fine for its intended use. If the new valve is more restrictive, you may find the system can not keep up. I think it is better to make sure your jet pump and solenoid valve and plumbing will keep the main full while you are still on paper.
Back to whole system design. You are changing that too. Different computer, different wiring, different plumbing. Maybe no big deal, maybe the original system was just fine - until something broke or wore out or caught some crud on the finger screen the others did not. Seven flown with a different design gives little comfort… Typical design guidance in homebuilts is system must flow 150% of max climb flows. This gives margin for reality. In your case it allows for climb, and then cycling draw from the selected wing tank to top up the main. Maybe you want more than 150% max flow from the transfer system. Whatever you decide is needed, make sure you have it.
Then we get to system reliability. There are a lot more T-51’s out there and many have had what I would call “fatal flaws” in electric system design. Single thread (no redundancy) schemes and cascading failures (one failure causes other failures) have been seen. I expect that this airplane has some poison waiting for you somewhere. I advise you to get critical on everything electrical. Well crafted primary and backup systems for flow of electrons and fuel are terrific for turning potential catastrophe’s into a comfortable trip to an airport with an FBO and nice topic for the EAA chapter meeting.
At least do your Failure Mode Analysis to spot the things that can go wrong and where you should be scheming out the backups. Then you will be able to look at it as an FMEA and see which backups make sense and where you think you have acceptably low consequences and probabilities. Even a simple review would have prevented at least one (perhaps two) T-51 engine cutoff accidents, where the landing gear electro-hydraulic pump issue cascaded to electric loss… Luckily no injuries in these accidents, but major damage to beautiful hand crafted airplanes. We can do better... And I hate to read an NTSB report about your bird.
Billski
911pete
PostPosted: Fri Feb 27, 2026 7:39 am    Post subject: Re: Fuel System Manager Reply with quote
Billski
Thank you for your comments/concerns.
As I said earlier I’m a builder and I’m building this as designed. The description of the operation of the fuel transfer computer in the original post is from a document that Viperjet supplied. I didn’t make it up. The plumbing hasn’t been changed. The jet pump is the one specified by Viperjet, the fuel level sensors are as specified, the system switches are as specified. The high pressure solenoid is as specified. The only thing not as specified is the controller and the low pressure solenoids. I’m still trying to get the specified solenoids. They are Duke’s part number 5825-00-1 if you have any suggestions/solutions for this part of the problem.
Now what can go wrong. Remember this is a fuel transfer system. It doesn’t need to supply 150% of max power fuel flow. The main 80 gallon tank does that. It is also built as designed. Pretty simple, just a tank with a shutoff valve then a boost pump and fuel filter into the fuel inlet on the engine. About 18” long path of 1 inch (-16) fuel line and fittings. You could take off and safely fly with empty wing tanks, but it would be a short flight 25-30 minutes. So if the fuel transfer system fails inop the wing tank fuel is trapped and you land. If the fuel transfer system fails operational you vent fuel and have some extra time until the wings are empty. You still land in that case.
Pete
wsimpso1
PostPosted: Fri Feb 27, 2026 4:57 pm    Post subject: Re: Fuel System Manager Reply with quote
Two things wrong with the last statement:
Changing parts means it is potentially a new design.
With only seven of these ever having been flown, the original design is not necessarily a proven design.
It is your butt in the seat. You have a relatively high risk bird, a potentially riskier fuel system than as designed, and you are making like it is all OK because a small number have flown. Yeah, but this is your version of the bird and your butt in the seat during a forced landing. Please take the perspective that changing the valve might do something bad and that the designers might have stuck you with some single thread designs in the rest of the bird when some carefully chosen redundancy would be relatively easy to look for and include.
My concern over the valves was their headloss. The valve supplier lists Cv as 0.86, which means at 1 psi across the valve, it will flow 0.86 gpm of 60F water. Kerosine is about 1.5 times as viscous as water, drop it to 30 degrees and it roughly doubles again. You cited 2 gpm in non-takeoff modes. To refill the tank quickly, you probably want at least double that, so 4 gpm from the wing tank. That then becomes 1.5*2*4/0.86 = 14 psi of head loss in valve. If you want quicker refill of the main tank, you will have even more headloss for that jet pump to overcome.
You add up the head loss at 4 gpm of the plumbing, the valve, any filters, and compare that to the jet pump pressure at that flow. Maybe it is OK, maybe you need a less restrictive valve... I strongly suggest you check the Cv or headloss from the previously specified valve.
As for the rest of the system, I do suggest that you get into chapter 17 of AeroElectric Connection and then take a serious look at your electrics. Consequences of an off airport landing or dark cockpit need to be considered in your failure mode planning.
Billski
Eric Page
PostPosted: Sat Feb 28, 2026 9:33 pm    Post subject: Re: Fuel System Manager Reply with quote
911pete wrote:
The HPFS can stay open in Auto. It just needs to be closed in the off position.
In that case, Joe's schematic has you covered. His design should be easy to wire "in the air" using a chassis-mount relay like this one...
https://www.digikey.com/short/bh10z8v9
...which has the advantage of being easy to replace if it ever fails.
911pete wrote:
I’m using the Garmin G3X with a GAD27. [ . . . ] Either of these units can be configured for the warning to be active high or low.
OK, I've made it active low. If you change your mind about avionics it will be compatible with anything on the market.
The schematic, wiring diagram and functional description are attached to this post. All parts are through-hole, so assembly will be easy. The bill of materials is here:
https://www.digikey.com/en/mylists/list/CFEKJK5A1K
For anyone else who's following this thread: please critique my schematic. The more eyes on it the better; let's find my mistakes at zero altitude and zero airspeed.
NOTE: I assumed that the fluid detection sensors have open contacts in the absence of fluid and closed contacts in the presence of fluid, that the "C" (common, white) wire of the sensors will be connected to 24V and the "NO" (normally open, brown) wire will be used to signal downstream circuits. So, if fuel is detected then 24V will be present on the brown wire, and if fuel is not detected then the brown wire will be open circuit.
When everyone's happy, I'll turn this into a circuit board layout.
Low Fuel Warning Module (Rev A).pdf
 Filename:  Low Fuel Warning Module (Rev A).pdf
 Filesize:  102.58 KB
 Downloaded:  323 Time(s)
PostPosted: Mon Mar 02, 2026 11:34 am    Post subject: Re: Fuel System Manager Reply with quote
I am not necessarily recommending dual relay control of wing tank valves.
But I have attached a dual relay option.
If automatic pumping from one tank is lost due to relay failure, then automatic
pumping can continue from the other tank. But relays rarely fail.
A disadvantage of two relays is more complexity.
Kudos to Eric for designing a low fuel flashing warning light.
 Filesize:  11.5 KB
 Viewed:  4681612 Time(s)
Joe Gores
911pete
PostPosted: Mon Mar 02, 2026 1:31 pm    Post subject: Re: Fuel System Manager Reply with quote
Joe
If I want to prevent overfilling/venting the tank in manual (middle position) could we get 24v from the upper level sensor to the middle pole of the upper part of the selector switch.
Pete
911pete
PostPosted: Mon Mar 02, 2026 2:18 pm    Post subject: Re: Fuel System Manager Reply with quote
In order to provide power to the solenoids in the middle position I’m thinking another relay would be needed since the sensor can’t provide enough power(amps) to directly control the low pressure solenoids.
Pete
PostPosted: Mon Mar 02, 2026 3:12 pm    Post subject: Re: Fuel System Manager Reply with quote
Pete,
It seems that you want do away with the manual mode and make the center
switch position automatic just like the top position.
Why not just use a 2 position switch, OFF and AUTOMATIC?
Another option is to install a third level switch. Put it into the main tank vent.
If fuel ever gets that high, either from operator error or from equipment
malfunction, then it would turn on the red flashing alarm light.
It would be easy to add that feature to Eric's circuit board.
Joe Gores
911pete
PostPosted: Mon Mar 02, 2026 4:00 pm    Post subject: Re: Fuel System Manager Reply with quote
No I like it the way it is. One reason to be able to stop it is when taxing in if you shut down when the fuel is somewhere between the sensors the main tank won’t be full. Then you have to climb up on top to fill it by hand. Using manual on the ground allows you to “top off” the main tank. By stopping it with the high level sensor you don’t risk dumping fuel in the ground.
Pete
PostPosted: Tue Mar 03, 2026 10:43 am    Post subject: Re: Fuel System Manager Reply with quote
I added a momentary push button switch to the circuit (circled in red).
You will have to decide if this added feature is worth the risk of the switch
failing and causing the valves to short cycle on and off.
During descent to landing, the wing tank valves will open and close every 10
minutes to keep the main tank full. It is my understanding that you want the
main tank to be near full at end of flight so that it is ready for the next takeoff.
Pressing the momentary switch will interrupt the automatic cycling and cause
the main tank to start refilling immediately. If timed correctly,
the main fuel tank will be near full and ready for the next takeoff.
 Filesize:  22.16 KB
 Viewed:  4681495 Time(s)
Joe Gores
911pete
PostPosted: Tue Mar 03, 2026 11:47 am    Post subject: Re: Fuel System Manager Reply with quote
That’s a nice elegant solution.
Pete
PostPosted: Tue Mar 03, 2026 5:56 pm    Post subject: Re: Fuel System Manager Reply with quote
After thinking about it, one could accomplish the same thing without installing a
momentary push button switch by pulling the circuit breaker for the fuel level
switches and then resetting it, assuming there is a pullable breaker and not fuses.
Joe Gores
Eric Page
PostPosted: Wed Mar 04, 2026 6:16 am    Post subject: Re: Fuel System Manager Reply with quote
user9253 wrote:
After thinking about it, one could accomplish the same thing without installing a momentary push button switch by pulling the circuit breaker for the fuel level switches and then resetting it, assuming there is a pullable breaker and not fuses.
If you go this way, it's best to use a switch/breaker that's designed for repeated manual on/off cycles, like the Klixon 7270 / 7271, or the Tyco W31 / W33. Read the reviews on Aircraft Spruce before you choose; some don't appear to last very long.
Eric Page
PostPosted: Wed Mar 04, 2026 6:50 am    Post subject: Re: Fuel System Manager Reply with quote
For those following this thread, an update: Several emails have been exchanged between Pete, Joe and myself. I've finished a circuit board layout (see attached image; dimensions in inches), which I'm going to build up and test before offering to Pete. Assuming it works, I'll post an update here when that's done, with design files and links for anyone who might need this in the future.
 Filesize:  193.46 KB
 Viewed:  4681412 Time(s)
PostPosted: Fri Mar 06, 2026 11:13 am    Post subject: Re: Fuel System Manager Reply with quote
How will the switches be labeled for the wing tank solenoid valves?
Attached is one possibility.
 Filesize:  100.33 KB
 Viewed:  4681298 Time(s)
Joe Gores
911pete
PostPosted: Fri Mar 06, 2026 12:30 pm    Post subject: Re: Fuel System Manager Reply with quote
On another Viperjet they are labeled OFF/MAN/AUTO
PostPosted: Sat Mar 07, 2026 6:38 am    Post subject: Re: Fuel System Manager Reply with quote
The builder or experienced pilot will know how the switches work.
A new pilot might think,
"If the switch is off, then no electricity is going to the valve, so it must be open."
or
"OK, I put the switch in manual. Now how do I open and close the valve manually?
Joe Gores
911pete
PostPosted: Sat Mar 07, 2026 6:48 am    Post subject: Re: Fuel System Manager Reply with quote
The “Heading” above the switches is “Fuel Transfer”, but I see your point
wsimpso1
PostPosted: Sun Mar 08, 2026 11:40 am    Post subject: Re: Fuel System Manager Reply with quote
As the holder of an MSE(IOE) - Yeah some folks would call it imaginary engineering - I feel compelled to point out that all control labeling should talk to what function is being achieved. You do not want the pilot to need expert knowledge in switchology and wiring and failure modes. You want the pilot to look at the switches and know function they will get by moving the switch.
In this case, I suspect you want to tell the pilot that this is FUEL TRANSFER, then the left side function is on the left side and labeled LEFT, the right side...
Then between the switches, I would have OFF meaning no flow from that tank, AUTO meaning it manages flow Automatically, and MANUAL meaning you turn it on and off yourself. Probably park the flow to OFF with the switch down...
Then below the switches, you might have a warning about what happens when electricity is lost to these solenoids like "Power Loss Defaults to OFF" or similar.
That takes us back to failure mode management. If the fuse or circuit breaker for one of these solenoids fails, which position do you want the valve in then? Perhaps you want a solenoid that only requires power to change state so it stays where it is when electricity becomes unavailable to the solenoid. Think hard about a system that defaults to free flow - it will do that when you are shut off too and just pour fuel on the ramp...
There are many ways to have redundant power for your solenoids. The easiest is just to have two independent power buses and run one solenoid of one and the other off the other. That may be good enough for you, or you might go further - have a three-position switch to select which bus is powering the solenoids or even two switches to determine which bus is powering which solenoid.
I have two transfer pumps, each is available to both buses on one DPDT switch. Each leg is fused. This allows me to power either pump from either bus or even both pumps simultaneously from either bus. It also prevents attempting to cross power a whole bus through one fuse and switch.
Seriously, you do not want any one thing that breaks to turn your bird into a high speed glider.
Billski
911pete
PostPosted: Sun Mar 08, 2026 7:02 pm    Post subject: Re: Fuel System Manager Reply with quote
Here is picture of another Viperjet panel that shows what I posted earlier
I have flown many planes in the AF as well as the airlines. Warnings below a switch is something I don't think I've ever seen. This type of information is normally in the aircraft manual.
In previous posts I explained what happens in the event of loss of electrical power. There is no way for the fuel to overflow on the ramp if the engine is shutdown as the jet pump, the heart of the fuel transfer system, needs high pressure fuel from the running engine to move any fuel from the wings to the main tank.
Pete
 Filesize:  186.16 KB
 Viewed:  4680915 Time(s)
Page 3 of 4
