				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| viperdoc(at)mindspring.co Guest
				|  Posted: Wed Jan 18, 2006 4:21 pm    Post subject: More Decompression Sickening sickness. |   |
				| Bian wrote, it is the rate of ascent that influences the incidence of Decompression Sickness (DCS).
Although true to an extent I have to disagree. Certainly a rapid decompression at or above FL 250 has an increased risk of developing DCS. It is the gradual lose of cabin pressure over time that has an increased incidence also. As are repeated exposures to altitude to name a few.
 The predisposing factors to the developement of DCS are as follows from taken directly from the textbook  Fundementals of Aerospace Medicine , pp 137-140.
 "Altitude Attained
 No reliable evidence exists for the occurence of DCS with altitude exposures of less the 5486 m unless there was a recent (within 24 hours) previous exposure to compressed gas breathing (eg., scuba diving). With increasing altitude, the incidence of decompression sickness increases, as does the ratio of severe to mild cases. Exposures to altitudes of 7925 to 14,478 m for times from approximately 30 minutes to 3 hours will result in a 1.5% incidence of decompression sickness. The severity of the cases will increase with increasing altitude.
 In a review of 145 cases of altitude-induced decompression sickness necessitating treatment, Davis and colleagues reported that 13% of the cases occurred with altitude exposres of 7620 m or below and 79% occurred with exposures of 9144 m or greater.
 Duration of Exposure
 At all altitudes above 5486 m, the longer the duration of exposure, the greater the incidence of decompression sickness.
 Temperature
 No correlation exists between the frequency of decompression sicness thd the ambient tempperature in the range of 21.1 to 24.3 deg.C. At an ambient temperature of     -23.3 deg C, however, the incidence of decompression sickness is twice that at 21.1 deg.C, with a larger ratio of serious cases to mild cases.
 Previous Exposure to Altitude
 A second exposure to an altitude greater han 5486 m following an exposure to such an altitude in the preceeding 3 hours will greatly increase the chance of DCS occurring, even if the first exposure was asymptomatic. A recurrence of symptoms is almost certain if the first exposure is symptomatic.
 A 2-hour exposure to an altitude of  7622 m followed in 18 hours by a rapid decompression from 2439 m to 6707 m will result in detectable Doppler bubble signals over the pulmonary artery. In addition, the incidence of DCS following the rapid decompression will be twice that following the intial altitude exposure.
 Repeated daily exposure to altitude have been reported as increasing susceptibility. Interestingly the incidence of DCS in  inside observers undergoing two to three altitude exposures per week accompanying students in altitude chamber training was three times greater than the incidence in students.
 Flying Following Diving
 If an individual breathes a gas at pressures greater than sea level before altitude exposure, his susceptibility to DCS will significantly increase. Altitude DCS has occured at altitudes as low as 1372 m several hours following scuba diving. Any exposure to compressed gas breathing occurring within 24 hours of altitude exposure will increase the chance of altitude DCS.
 AGE
 A striking increase in the incidence of DCS occures with increasing age. This increase occures with an increase incidence between the 19 to 25 year old  and 40 to45 year old age groups. The mechanism is not understood but may result from changes in circulation due to aging.
 SEX
 A great deal of conroversy exist regarding the posible differences in susceptibility to DCS between men and women. The scientific resolution of this question has been hampered by emotionl and political factors and unfortunately no valid studies have been done.
 Exercise
 The association between physical exertion and DCS has been well established. The effect of exercise on the incidence of decompression sickness is equivalent to increasing the exposure altitude from 915 m to 1524 m.
 Injury
 No convincing evidence exist to associate previous injury with DCS. Based on theoretical considerations, however, is is now thought that an acute injury to a joint has increased susceptibilty to the "bends" because of perfusional changes associated with the injury and/or healing mechanisms.
 Body Build
 For a long time, a basic tenet of diving and aerospace medicine has been that obesity increases the susceptiblity to DCS. Although it seems prudent to continue to accept this principle because of other known adverse effects of obesity, no scientific validation exists.
 Other Factors
 No definitive results have come from investigations of possible correlations between DCS and such factors as physical fitness, hypoxia , diet, and fluid intake."
 And those are the predisposing factors to DCS as textually stated to date. If you are planning on flying your unpressurized spam can at altitudes > Fl 180 and you are fat, between the ages of 19 to 25 or 40 to 45, its cold as hell outside, you have had a previous flight to FL 180 or greater in the past 3 hours, have exercised heavily, been scuba diving in the past 24 hours, injured a joint receintly, and been at altitude for 30 min or longer...You are risk for DCS. Guess some days Shit just happens. Like I tell my personal injury lawyer friends (used quite loosely), "Life is Hazardous to your health"! But if you are in that catagory above an ugly too, you are just SOL. Make your reservation at Pensacola or Brooks now for personal recompression chamber ride.
 Draw your own conclusions.
 Doc
 Roger "Doc" Kemp
 viperdoc(at)mindspring.com (viperdoc(at)mindspring.com)
 Aint no sound like a Radial
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| brian
				|  Posted: Wed Jan 18, 2006 5:39 pm    Post subject: More Decompression Sickening sickness. |   |
				| Roger Kemp wrote:
  	  | Quote: |  	  | Bian wrote, it is the rate of ascent that influences the incidence of Decompression Sickness (DCS).
 Uh, it certainly has an effect when ascending from diving. Why would it
 be different when flying?
  	  | Quote: |  	  | Certainly a rapid decompression at or above FL 250 has an increased risk of developing
 a few.
 I don't have the stats so I can't argue with you other than to say that
 the primary problem is dissolved N2. With time at a lower ambient
 pressure and partial pressure of N2 the body will reach a new
 equilibrium and decompression sickness becomes far less likely.
 But you are going to have to test with subjects that live at a higher
 altitude most of the time. In the US you can find people living near
 8000' much of the time. They could be a statistically valid sample. You
 can also find people regularly living above 12,000' in the Andes. I
 wonder if we could get a grant for this.
  	  | Quote: |  	  | The predisposing factors to the developement of DCS are as follows from taken directly from the textbook  _Fundementals of Aerospace Medicine_ ,
 pp 137-140.
 _"_*Altitude Attained*
 OK, 5486M is actually 18000 feet. At least we know what units they were
 using when they did the initial studies. 7925M is 26,000'. 14,478M is
 47,500'. That is above the limit for pressure breathing O2. They sure as
 heck aren't talking about sustained time up there.
 So they are talking about ambient pressure altitude of 26,000' and
 above. I don't think this qualifies as much of a threat to any of us in
 our CJs and Yak-52s, even nuts like me who like to fly high and suck on O2.
  	  | Quote: |  	  | In a review of 145 cases of altitude-induced decompression sickness necessitating treatment, Davis and colleagues reported that 13% of the
 You know, probably the greatest exposure to this low-pressure
 environment comes form hypobaric chamber rides. I would bet that they
 get a lot of info from there.
  	  | Quote: |  	  | Repeated daily exposure to altitude have been reported as increasing susceptibility. Interestingly the incidence of DCS in  inside observers
 Ah, I see they beat me to it.
  	  | Quote: |  	  | *Flying Following Diving* If an individual breathes a gas at pressures greater than sea level
 of altitude DCS.
 Yeah. This is why I don't take divers flying until the next day.
  	  | Quote: |  	  | *AGE* A striking increase in the incidence of DCS occures with increasing age.
 Shoot.
  	  | Quote: |  	  | *SEX* A great deal of conroversy exist regarding the posible differences in
 I volunteer! I will go have repeated sex with women in the hypobaric
 chamber to see if it increases my or their susceptibility to DCS! Yes! I
 am prepared to make this supreme sacrifice in the name of science!
 This is a way for RPA to provide a service to our fellow airmen (and
 women)! How many of you will volunteer with me to collect the necessary
 data?
  	  | Quote: |  	  | *Exercise* The association between physical exertion and DCS has been well
 1524 m.
 *Injury*
 mechanisms.
 *Body Build*
 *Other Factors*
 Shit just happens.
 That is a lot of shit dude!
  	  | Quote: |  	  | Like I tell my personal injury lawyer friends (used quite loosely), "Life is Hazardous to your health"! But if you are in
 I bet the ugly part makes it more difficult to get partners for testing
 for increased incidence of DCS when having sex at altitude. This is
 likely to result in a lower incidence of DCS in ugly men and women.
  	  | Quote: |  	  | Make your reservation at Pensacola or Brooks now for personal recompression chamber ride.
 It has been a long time since I have gotten a chamber ride. Do you know
 if they have a chamber at Beale (given the U-2 wing there I bet they
 have one) and, if so, whether they give civilians a ride?
 Brian Lloyd                         2243 Cattle Dr.
 brian-yak at lloyd dot com          Folsom, CA 95630
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 - Antoine de Saint-Exupery
 Brian Lloyd
		| Back to top |  |
				|  Posted: Wed Jan 18, 2006 7:01 pm    Post subject: More Decompression Sickening sickness. |   |
				| Brian wrote,
  	  | Quote: |  	  | It has been a long time since I have gotten a chamber ride. Do you know if they have a chamber at Beale (given the U-2 wing there I bet they
 Brian,
 My last chamber ride was at Tyndall, in Panama City, Fl.
 The last I knew Beale still had a hyperbaric chamber for support.
 They do fly civilians in the AF hypobaric chambers by appointment.
 Tomorrow, I will check with Brooks to see where a chamber is close to you.
 Doc
		| Back to top |  |
		| vorchaser(at)hotmail.com Guest
				|  Posted: Thu Jan 19, 2006 8:46 am    Post subject: More Decompression Sickening sickness. |   |
				| Before I joined the AF, I wanted to get my High Altitude sign-off in a
P-Navajo.  So, to get the physiological training, I went down to Peterson
 AFB, paid 25 bucks and they let me go thru the entire course, just like I
 have to do now every five years.  I remember that they only ran the civilian
 course once a quarter.
 Smash
  	  | Quote: |  	  | From: "Roger Kemp" <viperdoc(at)mindspring.com> Reply-To: yak-list(at)matronics.com
 CC: viperdoc(at)mindspring.com
 Subject: Re: More Decompression Sickening sickness.
 Date: Wed, 18 Jan 2006 21:00:14 -0600
 Brian wrote,
 Brian,
 Doc
 Express yourself instantly with MSN Messenger! Download today - it's FREE!
 http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
		| Back to top |  |
				|  Posted: Thu Jan 19, 2006 9:20 am    Post subject: More Decompression Sickening sickness. |   |
				| Smash,
Thanks. Have not had a chance to work on setting up the chamber rides yet.
 To many "O' by the ways" today!
 Doc
  	  | Quote: |  	  | [Original Message] From: Sarah Tobin <vorchaser(at)hotmail.com>
 To: <yak-list(at)matronics.com>
 Date: 1/19/2006 10:46:32 AM
 civilian
  	  | Quote: |  	  | > > if they have a chamber at Beale (given the U-2 wing there I bet they > > have one) and, if so, whether they give civilians a ride?
 >Brian,
 you.
  	  | Quote: |  	  | >Doc >
 FREE!
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
