What did you do with your europa this week 05/03/25
Area-51
PostPosted: Thu Feb 06, 2025 3:57 am    Post subject: What did you do with your europa this week 05/03/25 Reply with quote
This week another 3D printer was added; it was a portable device powered by mercedes for a bit. Then it migrated onto a benchtop where it started printing panel templates. It was wonderful, saved a few hundred dollars straight away by identifying some holes that had shifted during CAD work.
The UMA manifold gauge purchased off fleabay got sent across to the other side of the island to see if the wizard there can repair it.
Several drives out to the airfield happened but no flying; just coffee hamburgers more coffee and some refuelling snd then some more coffee
After some draft design quality checks some more tuning of the IFR instrument panel design was dished out; fixing up the inaccurate holes and giving the centre section some additional refinement. Not totally sold yet on the grab rail addition around the centre stack, but it will be useful during rough op's. Maybe someone has a better idea...
Some more printing on the way and another trial fitting session ahead before getting into the backend chassis mounting and electrical routing.
Thinking of adding another AV-30 for the right seat flyer; or maybe a G5... still not decided either way...
Stack without grab rail. Rough skies buttons dials and touch screen. Happy days...
 Filesize:  185.21 KB
 Viewed:  14951 Time(s)
Stack with grab rail
 Filesize:  197.46 KB
Close up of grab rail around stack
 Filesize:  124.45 KB
Quick draft prints to 1.50mm thickness. Quick and cheap design reviews no available.
 Filesize:  205.35 KB
A big box of joy 400x300x300 build volume capacity
 Filesize:  83.37 KB
Area-51
PostPosted: Thu Feb 06, 2025 7:47 am    Post subject: Re: What did you do with your europa this week 05/03/25 Reply with quote
Grab rails resolved. Now just some additional toggle switches for the 912iS install left to find a spot.
A slight amendment to the centre stack rail and a couple of rails for the AV30's added.
 Filesize:  152.83 KB
 Viewed:  14909 Time(s)
