Recommendations VP Prop
Paul Hawkins
PostPosted: Sun Oct 27, 2024 2:29 am    Post subject: Recommendations VP Prop Reply with quote
Hi chaps
I’m looking for recommendations for a VP prop for my trike XS Europa, I need help on this one I would appreciate your response.
Burrilla
PostPosted: Sun Oct 27, 2024 2:41 am    Post subject: Recommendations VP Prop Reply with quote
I’m very pleased with my Airmaster.
Very Robust
Very well made.
Good Performance improvements over my fixed pitch warp drive.
Maintains RPM set
2000 hours between overhauls and with 100hour maintenance intervals.
Support is good and we have the European agent as Europa Owner.
It’s the heaviest of the VP props at 26lb
It’s expensive.
Wouldn’t change it.
Alan Burrill
G-OBJTSent from my iPad
On 27 Oct 2024, at 10:30, Paul Hawkins <pwhawkinsbuilders(at)hotmail.com> wrote:
 Hi chaps
wdaniell.longport(at)gmai
PostPosted: Sun Oct 27, 2024 2:49 am    Post subject: Recommendations VP Prop Reply with quote
I have an airmaster which has worked well and with good service... surprisingly quick considering the factory is in nz.
William Daniell
+1 786 878 0246
On Sun, Oct 27, 2024, 12:30 Paul Hawkins <pwhawkinsbuilders(at)hotmail.com (pwhawkinsbuilders(at)hotmail.com)> wrote:
Hi chaps
raimo.toivio(at)rwm.fi
PostPosted: Sun Oct 27, 2024 4:52 am    Post subject: Recommendations VP Prop Reply with quote
I do agree, Alan!
Perfectly happy with it since 2008 and through 800 hours.
First coil change when used well over 600 hours (old ones were still usable).
Dirk van Oyen - Europa Pilot [Mono OO-145) and Airmaster Expert from Belgium, flew to my place and completed also The Dynamical Balancing with his pro equipment.
It was good (value < 0,2 IPS by chance), but now it´s smooth like my iX50M, value next to 0,00 IPS [inches per second].
I have Warp Drive Blades and have been happy with them.
During the coming decade (!) however they must be upgraded to the next level, which are...any recommendations?
allekirjoitus2 Cheers, Raimo Toivio
[img]cid:part1.hXUT9UvX.lAGkof0M(at)rwm.fi[/img]
Europa XS Monowheel OH-XRT #417 2007
Antonov AN-2 TDSRM AirCamper HA-MDO 1987
37800 Akaa
FINLAND
p. +358 3 3753 777
m. +358 40 590 1450
www.rwm.fi
raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)
Alan Burrill kirjoitti 27.10.2024 klo 12.40:
Very Robust
Very well made.
Maintains RPM set
It’s expensive.
Wouldn’t change it.
Alan Burrill
G-OBJT Sent from my iPad
On 27 Oct 2024, at 10:30, Paul Hawkins <pwhawkinsbuilders(at)hotmail.com> (pwhawkinsbuilders(at)hotmail.com) wrote:
 Hi chaps
 Filesize:  51.52 KB
 Viewed:  8276 Time(s)
peterz(at)zutrasoft.com
PostPosted: Sun Oct 27, 2024 9:07 am    Post subject: Recommendations VP Prop Reply with quote
Re: E-prop: I cannot recommend highly enough, and it’s extremely light all in weight and simplicity are unmatched attributes.
PeteZ
On Oct 27, 2024, at 12:32 PM, Bud Yerly <budyerly(at)msn.com> wrote:
 Paul,
In my over 20 years dealing with the Airmaster (and Europa) I think my website has all the information you need on choosing a constant speed propeller.  (Keep in mind this is not a variable pitch only propeller, it is a constant speed propeller.)
The Europa with a 914 and Airmaster AP 330 three blade or AP420 two blade transforms the aircraft into a good economical 10,000+ ft cruiser. The 64 inch propeller length is considered maximum for the Europa due to ground clearance. I would not go any longer.
On the 912S (100 HP) Rotax, it is excellent for shorter takeoff and gives you the best for optimum low altitude cruise in the normally aspirated Rotax.  With a fuel leaning kit (HacMan), fuel efficiency improves at cruise at 7500 feet and you can pick up a bit of speed also. Your country regulations must be adhered to concerning modifications to an engine.
Attached is my now very old and hated by the prop blade manufacturers information pdf on choosing the right blade for constant speed propeller operations on the Rotax. Nothing good happens after 67 to 68 inches on a Rotax even with a constant speed hub, but people keep trying. It is a short read and goes into why this is true. In all honesty, blade manufacturer performance is negated as the "performance is in the hub". Changing the pitch with speed is the key to performance. I'm including the installation manual from Airmaster as well for your review.
The Airmaster is more expensive than some of our European competitor prop builders but when it comes to ease of installation, builder maintenance, reliability and quick turn around on parts, the Airmaster has never left me stuck out. It is amazingly reliable. Service the hub once a year, change the brushes around 300-500 hours and look at your blades for damage as on any propeller. Yes, you have to maintain an aircraft. No engine, prop, or electronic do dad works forever as humidity, age and lack of use or attention often shows up. The controller is almost bullet proof, but switches can get corroded if kept near the salt water or the plane has sat in a humid environment for months on end without use. Simply clean your brush ring, click and wiggle switches that may corrode and if necessary, call a dealer or Airmaster direct with your issue and you will find troubleshooting is very simple on any electric constant speed.  The hub is strong and reliable, and the motor and switches in the hub are better than those 20 years ago. Airmaster is constantly improving their product.
Final thoughts:
The two blade AP420 is lighter at 19 pounds, and the three blade AP330 is smoother at 26 pounds. Speed difference is negligible ranging from 0-5 Knots depending on altitude, RPM, and engine. The trigear cowl removal is easier with the two blade on the Europa. If you have a Rotax belt drive alternator, use the mini-slip ring through the prop shaft. Note that there can be some interference from these alternators windings but there is an easy work around for those noisy field windings on these Denso type alternators. There is no problem with the Rotax / Ducati alternator or interference with the propeller.
I like to fly and look myself at equipment before I buy. I talk to owners, but still do my own research. I suggest you do the same. You will be hard pressed to find a disappointed Airmaster owner. A rule of thumb is if the plane looks nasty and is not well kept, the owner may not be taking best care of his airplane, but somehow the Airmaster soldiers on even when neglected.
In the UK, your nearest dealer is Dirk Oyen in Belgium. He will set you up with a demo and or there are many UK owners with the Airmaster. He is very hands on and well versed in the Airmaster operations and any maintenance. Contact for Dirk: Hemelrijk 61, Heusen-Zolder, Limburg 3550, Belgium. Email: dirk.oyen1(at)telenet.be (dirk.oyen1(at)telenet.be) , Phone: +32 477 25 80 28
Best Regards,
Bud Yerly
Custom Flight Creations
US Airmaster Dealer
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Paul Hawkins <pwhawkinsbuilders(at)hotmail.com>
Sent: Sunday, October 27, 2024 6:28 AM
To: europa-list(at)matronics.com <europa-list(at)matronics.com>
Subject: Recommendations VP Prop
Hi chaps
<What Airmaster propeller blade is best for my aircraft final.pdf>
<AP3-4 -5 series Operator's Manual V5-1A.pdf>
Paul Hawkins
PostPosted: Fri Nov 08, 2024 7:27 am    Post subject: Recommendations VP Prop Reply with quote
Hi chaps
Many thanks for your responses and recommendations for a replacement prop much appreciated and a special thanks to Bob, when he posts always reminds me every day is a school day.
cheers Paul
From: Paul Hawkins <pwhawkinsbuilders(at)hotmail.com>
Sent: 27 October 2024 10:28
Hi chaps
