I -Pad Mini position and mount in a XS Mono
rparigoris
PostPosted: Wed Sep 04, 2024 5:13 pm    Post subject: I -Pad Mini position and mount in a XS Mono Reply with quote
Hi Group
Would appreciate if you could share a pic or 2 where might be an appropriate location for an I-Pad Mini in an XS Mono and what sort of holder and mount may be appropriate. Just sitting in bird tonight seems like an 18" Gooseneck if attached to the front of Instrument Module tray all the way on the inboard side where the Instrument Module begins to go vertical? Thinking this may be an appropriate mount?: https://tinyurl.com/mry8rr6t Thx. Ron P.
rparigoris
PostPosted: Wed Sep 04, 2024 5:14 pm    Post subject: Re: I -Pad Mini position and mount in a XS Mono Reply with quote
Forgot to mention, want the ability for passenger to be able to use I-Pad Mini. Ron P.
trevord
PostPosted: Wed Sep 04, 2024 5:45 pm    Post subject: Re: I -Pad Mini position and mount in a XS Mono Reply with quote
Hello Ron,
I mounted my I pad using a slightly more expensive but excellent mount that airline pilots use in big jets.
The connection to the Europa is on the edge of the tray, bolted on, with support behind to make sure it stays solid.
Whilst I have not flow the Europa as yet, it is very secure and allows almost any orientation both for pilot and passenger, if they want to watch an in flight movie.
This is the company for the Ipad case https://pivotcase.com/
This allows the ipad to be slipped on and off easily.
The actual mounting arm is generic
Trevor
WARNING - do NOT buy a cheap USB power outlet for the aircraft - I had MAJOR issues until I tracked this down.. I purchased an aviation standard one that does not make a row on the Trig radio ...
 Filesize:  1.42 MB
 Viewed:  10994 Time(s)
Trevor
peterz(at)zutrasoft.com
PostPosted: Wed Sep 04, 2024 6:59 pm    Post subject: I -Pad Mini position and mount in a XS Mono Reply with quote
Made my own… works a treat.
PeteZ
C-GNPZ
http://forums.matronics.com/viewtopic.php?p=513813#513813
 Filesize:  134.26 KB
 Viewed:  10978 Time(s)
 Filesize:  122.29 KB
 Filesize:  129.51 KB
 Filesize:  135.97 KB
 Filesize:  190.7 KB
jimlawnn(at)hotmail.com
PostPosted: Thu Sep 05, 2024 2:30 am    Post subject: I -Pad Mini position and mount in a XS Mono Reply with quote
PeteZ
C-GNPZ
<image0.jpeg>
<image1.jpeg>
<image2.jpeg>
<image3.jpeg>
<image4.jpeg>
> --> Europa-List message posted by: "rparigoris" <rparigor(at)hotmail.com>
rparigoris
PostPosted: Fri Sep 20, 2024 7:48 am    Post subject: Re: I -Pad Mini position and mount in a XS Mono Reply with quote
Hi Group
Thanks to replies on forum and by E-Mail. Think we are going to mount holder to the left side of the shelf on the Instrument Module.
Thx. Ron
