Lamar voltage regulator and overvoltage relay questions
N1921R
PostPosted: Sun May 05, 2024 5:47 pm    Post subject: Lamar voltage regulator and overvoltage relay questions Reply with quote
Someone on VAF asked and made me curious.
Aircraft has:
    Electrosystems 60A alternator PN ALX8421RS
    Lamar voltage regulator B-00267-2
    Lamar overvoltage relay B-00339-1
Owner suspects regulator is bad.
I wonder:
    What is this overvoltage relay and how is it wired.
    Can a Ford regulator VR166 be used in combination with this overvoltage relay? (Lamar regulator B-00267-2 is only available used and is expensive.)
BTW I’m aware of Bob Nuckolls’ regulator swap test method. http://www.aeroelectric.com/Pictures/Regulators/Ford_Test_Reg.jpg
John Bright, RV-6A N1921R, working on FWF.
Single battery, alternator on main bus, Monkworkz generator on engine/essential bus.
My links here
PostPosted: Mon May 06, 2024 5:48 am    Post subject: Re: Lamar voltage regulator and overvoltage relay questions Reply with quote
Found this via google search:
https://www.bonanza.org/globalassets/aircraft/service-instructions/si-1062---electrical-power---installation-of-an-overvoltage-relay-for-the-60-amp-alternator-system.pdf
So evidently the relay opens the circuit to the voltage regulator if the electrical system voltage is too high.
 Filesize:  39.89 KB
 Viewed:  10399 Time(s)
Joe Gores
N1921R
PostPosted: Mon May 06, 2024 9:01 am    Post subject: Re: Lamar voltage regulator and overvoltage relay questions Reply with quote
Thanks Joe,
It seems to me:
    The OP can use a "Ford" VR166 voltage regulator.
    The overvoltage field interrupter relay is from a former time before overvoltage crowbars.
The subject VAF thread is at: https://vansairforce.net/threads/alternator-field-voltage.226640/
My links here
