Airmaster SoftWare update
John Kirkgaard
PostPosted: Sun Apr 21, 2024 7:57 am    Post subject: Airmaster SoftWare update Reply with quote
I was trying to alter the preset rpm by using Airmasters setting program.
I did not give the wanted result, and in turn I asked Airmaster support.
The support guy sent me a new software update for the controller.
But.... Installing that resulting in immediately frying my controller. It got bricked, as they say. Completely damaged.
Asking Airmaster how that could happen their only answer: buy a new
controller - .
After receiving the new controller I opened the old one up and found two burned components inside. (and a terrible smell)
Well had no other choices, but to others: take care installing new software
from Airmaster.
I have had my propeller and controller for many years, so despite the
plane has just been completed and started flying a couple of years ago
there is no warranty (fair enough). However I am wondering how many people, building experimental aircraft, do manage to get the propeller installed and test flown within the warranty period.
DuaneFamly
PostPosted: Sun Apr 21, 2024 9:01 am    Post subject: Airmaster SoftWare update Reply with quote
I find it incredulous that Airmaster, a leader in the experimental market, would provide an untested piece of software to their customers that wound up frying the controller. Did they not fully test this software prior to sending it out? I really do not want to start thinking that they are purposefully sending out this software in order to sell replacement controllers. Has anyone else had this issue? Could this be making owners reluctant to update their software because they don't want to take any chances? And why wouldn't Airmaster stand behind their products and repair or replace the controller they damaged?
Mike Duane N377EA
Europa XS Conventional Gear
Chandler, Arizona, USA
On Sunday, April 21, 2024 at 08:58:33 AM MST, John Kirkgaard <john.kirkegaard(at)gmail.com> wrote:
--> Europa-List message posted by: "John Kirkgaard" <john.kirkegaard(at)gmail.com (john.kirkegaard(at)gmail.com)>
controller - .
from Airmaster.
http://forums.matronics.com/viewtopic.php?p=513485#513485
http://forums.mat - NEW MATRONICS LIST WIKI -
http://wiki.matronics.com
htt=======
Mike Duane
trevord
PostPosted: Sun Apr 21, 2024 1:52 pm    Post subject: Airmaster SoftWare update Reply with quote
Hello John,
Having had great support from Airmaster, I find it astonishing that airmaster would make this mistake; they are very cautious and always looking to safety first.
Are you sure that in doing the update you did not make a mistake like powering the device on a bench and reversing the polarity ?
I say this because I have actually done this myself frying two Uavionics devices and a Kanardia Alitimeter, it is so easy done and only takes a second of not thinking and the electronics is landfill.
Trevor
Sent from my Galaxy
-------- Original message --------
From: John Kirkgaard <john.kirkegaard(at)gmail.com>
Date: 22/04/24 4:05 am (GMT+12:00)
Subject: Europa-List: Airmaster SoftWare update
--> Europa-List message posted by: "John Kirkgaard" <john.kirkegaard(at)gmail.com>
controller - .
from Airmaster.
_-============================================================
_-=          - The Europa-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-=   --> http://www.matronics.com/Navigator?Europa-List
_-=
_-=               - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-=   --> http://forums.matronics.com
_-=
_-=              - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-=   --> http://wiki.matronics.com
_-=             - List Contribution Web Site -
_-=  Thank you for your generous support!
_-=                              -Matt Dralle, List Admin.
_-=   --> https://matronics.com/contribution
Trevor
John Kirkgaard
PostPosted: Sun Apr 21, 2024 9:36 pm    Post subject: Re: Airmaster SoftWare update Reply with quote
Trevor,
The controller was not removed from the instrument panel. All cables were
still in place during the update. Everything seemed to work well, until the
update was completed and the power was switched on. The 3 red lights and
a smell of burned components.
John Kirkgaard
PostPosted: Sun Apr 21, 2024 9:46 pm    Post subject: Re: Airmaster SoftWare update Reply with quote
DuaneFamly,
I'm absolutely sure that the update-software is not made faulty by intention.
In Europe we have a extremely good support by Airmasters representative.
Unfortunately he has been on a long (well deserved) vacation, and I had to
rely on support from Airmaster in N.Z. And to be frank, getting help from
there is like contacting an Indian call center.
Looking back, I should have been more patient and waited for the normally
excellent support from Dirk.
John Wighton
PostPosted: Mon Apr 22, 2024 8:12 am    Post subject: Re: Airmaster SoftWare update Reply with quote
I have had a fair bit of contact with Dirk, he did once warn me against trying old er spec controllers with newer prop actuation motors. But the software update should never fry the board on an AC200.
Airmaster should create a compatibility table as an annex to the installation manual. The purpose of a firmware update should also be included in the table.
For others thinking of changing the settings on their controller, this does not require any new software. Once connected to a PC running the setup software, the parameters for t/o, climb and cruise can be adjusted, then loaded very easily.
John Wighton
Europa XS trigear G-IPOD
John Kirkgaard
PostPosted: Mon Apr 22, 2024 8:54 am    Post subject: Re: Airmaster SoftWare update Reply with quote
John,
My set-up software seemed to run fine. I had, however the issue, that de-
spite uploading the new settings (and then confirmed by downloading the new settings for check), during flight I could not achieve the new settings.
It was not a big problem, but asked Airmaster if they new what could be the reason for that.
Well the rest is history...
budyerly@msn.com
PostPosted: Mon Apr 22, 2024 4:42 pm    Post subject: Airmaster SoftWare update Reply with quote
John and other Airmaster Owners,
In my nearly 20 years as an Airmaster Dealer, I have changed many a controller programing, and troubleshot systems and installations on many planes. Nearly all of these were fairly simple to solve. However, on one occasion I did simply swap out a controller (I still have the original and it works fine.) It was discovered the belt driven alternator had a bad field causing massive EMP which affected the Hall Effect transducer in the brush block (tach pickup). This was a bugger to troubleshoot. I knew it was the aux alternator as the prop worked perfectly with the alternator field wire disconnected.
As far as changing RPM settings with the program, it is an issue usually with the difference in RPM shown on the Tach and that driven by the prop controller. In all my years, I find tachs are notoriously off. I typically take my prop tachometer (optical device which counts the blades and converts to prop RPM.) I calculate the gearbox ratio and show that the RPM at the prop is correct (confirming the programming), and the tach was off typically within limits but at 5500 RPM a 2% error is obviously 110 RPM. (An error that is OK for slow turning engines but not the Rotax.) I spent time with the clients researching the tach operational tolerances. I found the Airmaster tach pickup was more accurate than most tachometers, EIS or Engine Information Systems, and even certified tachs. But I was happy to help the customer fix his tach RPM error issue through the AC200 programming app rather than trying to adjust a tach (especially an EFIS equipped with an engine monitor tach) issue. I was more interested in getting them flying safely with no fear of overrevving the engine.
On another aircraft, we had the wrong gearbox ratio programmed, as the client had the 912S in mind when the prop was purchased but settled on a 912 UL with the lower gear ratio.
I also found on a few occasions that customers that didn't take the tried-and-true prop blade and diameter recommendations ( I was one of them) and the owner found many problems occur getting the prop to perform properly.  The owner blamed the settings, but on analysis I found the blade was too large of an area for the engine power. Case in point, the 912UL cannot take a prop any longer than 62 inches, a modest width and the tip must be narrow (a tapered blade Warp Drive works well) unless really geared down. The wide chord blade may be great for high altitude but at sea level you can't even get 5400 for takeoff power with the 80-horse engine. Then at altitude the power loss doesn't provide enough power and torque to even get the desired cruise RPM. I purchased a propeller design program and spent inordinate amounts of time refining my blade choices for the Rotax to match the blade to the power and torque range of the Rotax 912, 912S and 914 engine versions. This is not a fun drill as the customer is always right, and since he is adamant on the blade choice, he gets to pay the dumb tax later when changing blades.
John to your particular electrical issue:
If you were able to install the USB to Serial cable and hook to your laptop successfully and make the RPM change it is possible during your hookup and removal of cables (especially in tight areas) a circuit board may be damaged. Circuit boards can be brittle although the AC200 has very robust connections, I can see how it will happen. For those who have never had an issue, here is what the inside of an AC200 looks like:
[img]cid:3f2455a6-672e-48fb-867f-4d40b648d6b6[/img]
One can see the pin connectors are quite robust but again, they are soldered, and a solder joint can break, or some part of the joint or board flake.
My concern with locking plugs is the Molex style connectors can be a pain to lock in and unlock. I no longer just plug in a Molex until I can see if I can release it easily but still remain secure when clicked in. Heat shrink is normally placed on the end of a Molex connector and unfortunately the heat shrink wraps under the push to release lever and can prevent full depression of the lever and may prevent an unlanch for removal. I trim the heat shrink to assure the hook side opens with clearance to spare. If a plug gets stuck, I suggest to the client to bend the hook side to assure it clears the latch and it should allow the plug to slide out easily rather than trying to trim the heat shrink in place. In trying to remove the larger connections sometimes torque is applied to the molex and the results can be terminal. I have also seen the power plug leaned on heavily and the ground and or power connection solder joint causing a broken board or failed joint. In my autopsy of this AC200, a small chunk of solder was found and it shorted on the board. (Even though the board is vertical, and one would think the solder would simply fall to the bottom. He was unlucky as it caused a short of course. However, most of the time a fried controller was a power connected to the ground and vice versa. OOPS. As my friend Gary would say... I'm going to pay the dumb tax for that." We've all been there.
Although I have never had this issue like yours, for servicing I make all my panels easily removable and put the panel on the bench (sometimes I remove the AC200 from the panel and do the update process on the bench).  I hook up my USB serial converter to my laptop, turn on the computer, call up the program and power up the AC200 and I've never had an issue. The software comes up (once I figure the com port on older non- automatic external USB connection programs) I change the item on the screen and then close the program and power down the AC200.
It would be nearly impossible for a digital to serial conversion cable and processor to fry anything in a working propeller. So, I am sure it is not the cable. As for other issues. If the prop was working before, I am stumped and blaming you, Airmaster or anyone else is inappropriate with what information I have read on your issue.
There are other means of frying electronics though.
I have witnessed a fellow EAA member doing a show and tell at a meeting of what happens when the battery is connected backwards. It can be exciting when the mechanical master contact closes.
The only other AC 200 fried here in the States was due to an aftermarket voltage regulator that shot A/C current direct to the panel. (A unique home-made device.) As expected, those electrical components without reverse polarity diode protection died a quick death and some were slow and very difficult to troubleshoot. I did hear of one guy (no firsthand knowledge) that had a couple of jumper wires connected to the prop contacts trying to troubleshoot the hub not responding (he didn't realize the brushes were still in contact) and he found with 12 volts applied to the prop and the still connected brush block, cables and AC 200 controller, I can only say what he said : I knew I fried it as it smoked and stunk to high heaven. He paid the dumb tax of a new brushblock, cable, AC200 and he even changed out the switch.
Check if Dirk has a loaner AC200 at his shop (if you are working with him). Relay to him the prop program you are working with, which motor is in the hub. If you don't know, look in your logbook. so he can see if his spares will work for you.
I have a complete test rig I made for those adamant that their install is correct. It is shown below. It has a circuit breaker, AC200, switches ,and can be hooked to a cigarette lighter socket via ring or spade connectors to connect a small gel cell battery. This is great for ground test and many times to go fly on a test basis.
[img]data:image/png;base64,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
 Filesize:  2.49 MB
 Viewed:  8614 Time(s)
