dlm34077(at)gmail.com Guest
Posted: Tue Feb 13, 2024 10:13 am Post subject: parachute |
Just a tiny bit for those RV10 pilots considering a parachute similar to the Cirrus. I talked to a member of our EAA chapter, and he recently had his parachute recertified. First, the parachute takes about two weeks to replace and recertify the Cirrus for flight. During that time the aircraft is grounded. I asked about the cost. The entirely new parachute and rocket motor starts the countdown clock of 10 years when it is manufactured. The cost was $22K and change. I checked the initial cost and recurring cost for the RV10 version. The initial cost is 16K and a required exchange is $6-8K but that was their guess since no current product is anywhere near expiration. Another consideration is that aircraft is totaled after the lever is pulled; of course one would assume that the airframe was already toast when the handle is pulled. This also assumes that the aircraft is safely within the flight envelope for a successful save.
Tim Olson
Posted: Tue Feb 13, 2024 11:22 am Post subject: parachute |
It may be more cost effective to buy 4 personal parachutes and then make
everyone wear them
for every flight.
On 2/13/2024 12:13 PM, dlm wrote:
| Quote: | Just a tiny bit for those RV10 pilots considering a parachute similar
Vol88
Posted: Wed Feb 14, 2024 7:53 am Post subject: parachute |
This is an interesting topic, and one that I expect will get more coverage as RV-10s continue to compete with SR22s.
I’m building an RV-10 and currently fly a Cirrus SR20, as well as three spam cans, in a flying club. I appreciate having the chute available in the Cirrus when I’m carrying non-pilot passengers.
I’m not one to get into the parachute wars, but I would love to have a chute in my RV-10. I decided against it due to the weight and space tradeoff, as well as the exterior straps. I’m not flying yet, but if my intended mission turns out to be just two people and a dog, I may retrofit it.
I understand that some proportion of Cirruses have been returned to service after deploying the chute. We have to get our ten-year repack this fall and I understand that the quote is far less than our reserve fund – something under $15K. The cost depends on the year and the firing mechanism. Some mechanisms need to be upgraded; some years require more substantial bodywork after replacement.
The V-speed for our Cirrus chute deployment is 130 knots, but there have been successful saves at considerably higher speeds than that. From the COPA website: “Four CAPS deployments occurred successfully at higher speeds, 168, 171, 187, and 190 knots indicated airspeed, and one deployment failed at an airspeed estimated at over 300 knots airspeed.”
Tom
From: <owner-rv10-list-server(at)matronics.com> on behalf of dlm <dlm34077(at)gmail.com>
Reply-To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Date: Tuesday, February 13, 2024 at 12:22
Subject: RV10-List: parachute
Just a tiny bit for those RV10 pilots considering a parachute similar to the Cirrus. I talked to a member of our EAA chapter, and he recently had his parachute recertified. First, the parachute takes about two weeks to replace and recertify the Cirrus for flight. During that time the aircraft is grounded. I asked about the cost. The entirely new parachute and rocket motor starts the countdownclock of 10 years when it is manufactured. The cost was $22K and change. I checked the initialcost and recurring cost for the RV10 version. The initial cost is 16K and a required exchangeis $6-8K but that was their guess since no current product is anywhere near expiration. Another consideration is that aircraft istotaled after the lever is pulled; of course one would assume that the airframe was alreadytoast when the handle is pulled. This also assumes that the aircraft is safely within the flight envelopefor a successful save.
m.r.92129(at)gmail.com Guest
Posted: Wed Feb 14, 2024 8:29 am Post subject: parachute |
I am installing a parachute in my RV-10. Details are on the RV-10 Wiki. The BRS kit manual is incomplete and several of the instructions dimply don’t work for the RV-10 (given bracket position are not possible due to interference with stiffeners, holes collide with ribs, bolts go into nothing), so small modifications are needed basically at every step. Should be easier now with the hints.
/Martin
| Quote: | On Feb 14, 2024, at 7:52 AM, Thomas Mason <tom(at)twmason.com (tom(at)twmason.com)> wrote:
Tom
From: <owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)> on behalf of dlm <dlm34077(at)gmail.com (dlm34077(at)gmail.com)>Reply-To: "rv10-list(at)matronics.com (rv10-list(at)matronics.com)" <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>Date: Tuesday, February 13, 2024 at 12:22To: "rv10-list(at)matronics.com (rv10-list(at)matronics.com)" <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>Subject: parachute
digidocs
Posted: Wed Feb 14, 2024 10:27 am Post subject: parachute |
Hi Martin,
This is great information, thank you for taking the time to post it. It sounds like there are a number of "small" issues with the installation--what would you say is your overall impression of BRS from a support, engineering, and product quality perspective?
David
On Wed, Feb 14, 2024 at 10:31 AM Martin Renschler <m.r.92129(at)gmail.com (m.r.92129(at)gmail.com)> wrote:
| Quote: | I am installing a parachute in my RV-10. Details are on the RV-10 Wiki. The BRS kit manual is incomplete and several of the instructions dimply don’t work for the RV-10 (given bracket position are not possible due to interference with stiffeners, holes collide with ribs, bolts go into nothing), so small modifications are needed basically at every step. Should be easier now with the hints.
/Martin
Tom
Subject: parachute
Posted: Wed Feb 14, 2024 10:45 am Post subject: parachute |
Hi David,
I spoke to them at Oshkosh and they were very interested in the feedback. I pointed them to the Wiki that others and I contribute to,
https://rv10.org/index.php?title=Parachute
https://rv10.org/index.php?title=BRS_Installation_Hints/
but haven’t heard anything back other than them asking if I wanted to be an aftermarket installer for BRS, haha.
One thing I mentioned for example was that all bolts are fully threaded meaning you have shear load on the thread in the holes. Kind of unusual in aviation. You wonder what kind of team put this kit together.
/Martin
| Quote: | On Feb 14, 2024, at 10:25 AM, David Carr <junk(at)dcarr.org (junk(at)dcarr.org)> wrote:
Hi Martin,
David
/Martin
Tom
