DB9 Cover
jluckey(at)pacbell.net
PostPosted: Tue Nov 28, 2023 10:02 pm    Post subject: DB9 Cover Reply with quote
I'm looking for a snap-on thin plastic shell that would clamp over a mated pair of DB9 connectors ( 1 male plugged into a female). Not a backshell but something that is easy to clip on and would protect the other wires in the loom from the metal edges of the connectors. It does not have to provide strain relief for the wires going into the connectors.
I've seen the plastic back shells that snap over each connector - I want something like that, but that clips over the mated pair.
Anyone ever seen something like this? Not even sure how to Google for this...
-Jeff
stuart(at)stuarthutchison
PostPosted: Tue Nov 28, 2023 10:54 pm    Post subject: DB9 Cover Reply with quote
Seems like a good candidate for 3D printing Jeff.
-Jeff
smime.p7s
 Filename:  smime.p7s
 Filesize:  1.39 KB
 Downloaded:  754 Time(s)
BobD
PostPosted: Wed Nov 29, 2023 12:14 am    Post subject: Re: DB9 Cover Reply with quote
Jeff, I'm not sure which part of the world you live in, but if the UK, I remember from Dragons Den a few years ago, someone came up with something similar to that you are looking for. It was called the chocbox, and made him quite a few quid as I recall. If you Google that, name, you will probably find what you are looking for.
Cheers
BobD
Bob Dawson
Europa XS TG || 912 ULS || G-NHRJ || Dynon Skyview || PilotAware || SmartAss3
fly4grins(at)gmail.com
PostPosted: Wed Nov 29, 2023 10:20 am    Post subject: DB9 Cover Reply with quote
pair of DB9 connectors ( 1 male plugged into a female).=C2- Not a backshe
in the loom from the metal edges of the connectors.=C2- It does not have
That might be a great spot for fusing silicone tape.  Not as sexy as a special
purpose shell, but likely as effective and a better seal.
Just a thought-
Ceengland
PostPosted: Wed Nov 29, 2023 11:33 am    Post subject: DB9 Cover Reply with quote
On Wed, Nov 29, 2023 at 12:05 AM Jeff Luckey <jluckey(at)pacbell.net (jluckey(at)pacbell.net)> wrote:
-Jeff
Others have good suggestions, but my solution would be much more 'shade tree'. I'd use the regular covers on each side (sounds like you're doing that already), zip-tie the holes together, and wrap the flanges with a couple of turns of silicone repair tape (or even regular electrical tape).
email(at)jaredyates.com
PostPosted: Wed Nov 29, 2023 12:43 pm    Post subject: DB9 Cover Reply with quote
Or perhaps a wrap of self-fusing tape?
On Wed, Nov 29, 2023, 01:59 Stuart Hutchison <stuart(at)stuarthutchison.com.au (stuart(at)stuarthutchison.com.au)> wrote:
On 29 Nov 2023, at 5:02 pm, Jeff Luckey <jluckey(at)pacbell.net (jluckey(at)pacbell.net)> wrote:
-Jeff
cluros(at)gmail.com
PostPosted: Wed Nov 29, 2023 12:52 pm    Post subject: DB9 Cover Reply with quote
https://www.aircraftspruce.ca/catalog/appages/rescuetape.php?clickkey=9168
On Wed, 29 Nov 2023, 12:47 Jared Yates, <email(at)jaredyates.com (email(at)jaredyates.com)> wrote:
-Jeff
PostPosted: Wed Nov 29, 2023 2:40 pm    Post subject: DB9 Cover Reply with quote
BobD - the ChocBlock is the right idea but is designed to a hold terminal block.
Stuart - You suggested some 3D printing - I had the same thought as I was writing the original message...but I don't have a printer and I'd rather buy COTS than have to roll my own. (The hardest part of that would be the 3D CAD, since I don't do 3D CAD;)
All others - valid suggestions, some of which I had considered.
Thanks to all,
-Jeff
On Wednesday, November 29, 2023 at 12:58:13 PM PST, Sebastien <cluros(at)gmail.com> wrote:
-Jeff
wdaniell.longport(at)gmai
PostPosted: Thu Nov 30, 2023 4:56 am    Post subject: DB9 Cover Reply with quote
I do what someone else does….zip tie through the screw holes.
On Wed, Nov 29, 2023 at 17:43 Jeff Luckey <jluckey(at)pacbell.net (jluckey(at)pacbell.net)> wrote:
Thanks to all,
-Jeff
On Wednesday, November 29, 2023 at 12:58:13 PM PST, Sebastien <cluros(at)gmail.com (cluros(at)gmail.com)> wrote:
-Jeff
mike(at)vision499.com
PostPosted: Thu Nov 30, 2023 9:09 am    Post subject: DB9 Cover Reply with quote
I also recall something where you snip the tags off to make it smaller and seal the whole thing with shrink tube
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of William Daniell
Sent: November 30, 2023 4:56 AM
Subject: Re: DB9 Cover
Thanks to all,
-Jeff
-Jeff
PostPosted: Thu Nov 30, 2023 2:14 pm    Post subject: DB9 Cover Reply with quote
What conditions suggest a need for extra
enclosure? Have you considered any of the
contemporary automotive connectors?
A particularly promising line of products
is manufactured by Deutsch. I've posted
and excerpt of their catalog at
https://tinyurl.com/yoynwxtk
These connectors off a full range
of pins in both open barrel and
quad-crimp styles . . . even gold
plated! Amazon offers some of these
devices.
These connectors are scuba-dive/sand-
storm ready right out of the box.
Deutsch the only game in town either.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
PostPosted: Thu Nov 30, 2023 2:20 pm    Post subject: DB9 Cover Reply with quote
devices.
https://tinyurl.com/Jready2
(o o)
Voyager
PostPosted: Thu Nov 30, 2023 2:23 pm    Post subject: DB9 Cover Reply with quote
Yes, Deutsch connectors are good stuff, but pricey. I still use Weatherpack as they are available at reasonable prices for the real stuff. Much of the “Deutsch” product sold on Amazon are Chinese knock-offs. If they price is much lower than places like Mouser and DigiKey, it is Chinese junk.
Weatherpack are old technology and a fair bit bulkier than Deutsch, but they are rugged and reliable and less expensive than Deutsch for places where size isn’t a paramount consideration and you don’t need more than 6 pins. I look at Weatherpack as being like standard density dsub and Deutsch being high density dsub equivalents.
Matt
On Nov 30, 2023, at 5:16 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
devices.
  (o o)
Voyager
PostPosted: Thu Nov 30, 2023 2:42 pm    Post subject: DB9 Cover Reply with quote
This appears to be a decent source (just placed my first order with them so can’t be sure yet) for genuine Deutsch, Weatherpack and Metripack and they sell single connector kits which are nice to ensure you get all of the right parts. Ordering all parts a la carts can get confusing. https://www.customconnectorkits.com/
I’ve ordered my prior Weatherpack connectors and tools from https://www.diyautotune.com/shop/wiring-components/weather-pack-kits/ and have had good experience with them. Their main limitation is they only sell up to 20 AWG contacts and I needed some 22-24 contacts for my Ray Allen trim wires. Custom Connector carries the smaller size Weatherpack contacts and kits.
Matt
On Nov 30, 2023, at 5:24 PM, Matthew S. Whiting <m.whiting(at)frontier.com> wrote:
Matt
devices.
  (o o)
Eric Page
PostPosted: Fri Dec 01, 2023 6:34 pm    Post subject: Re: DB9 Cover Reply with quote
There's a good alternative to Deutsch connectors. Amphenol make exact duplicates of the entire range of Deutsch parts. Every component is entirely interchangeable with the equivalent Deutsch parts and they sell for significantly less than Deutsch. The Amphenol versions are available in multiple housing colors and keying options to prevent misconnecting similar connectors in the same harness, and Amphenol offer many more accessory items like shrink boots and mounting brackets than Deutsch.
The Amphenol connectors' series designations are similar to Deutsch (links to manufacturer product pages):
Deutsch DTM = Amphenol ATM (Size 20 contacts, 7.5A ea.)
Deutsch DT = Amphenol AT (Size 16 contacts, 13A ea.)
Deutsch DTP = Amphenol ATP (Size 12 contacts, 25A ea.)
Look at the bottom of each Amphenol product page for downloadable PDF brochures that explain all of the available components and how they work.
Below are links to Digi-Key part lists with all of the required components to form a basic plug/receptacle pair for each Amphenol series. Click "+" to the left of each part to see alternatives. Watch pin/socket part numbers carefully; there are different contacts for different wire AWG (the "Contacts" brochures are a good guide).
Amphenol ATM
Amphenol AT
Amphenol ATP
For each connector pair, you need the following parts:
-Plug housing
-Plug wedgelock
-Female socket contacts
-Receptacle housing
-Receptacle wedgelock
-Male pin contacts
-2x sealing plugs (for each unused position)
Assuming that you use machined contacts, then for crimping tools the Iwiss brand are good quality at low prices. The IWD-12, IWD-16 (or IWD-1620) and IWD-20 are the tools to look for. Iwiss also sell the tools under their iCrimp brand. The tool part numbers correlate to the contact sizes above (the -16 and -1620 both crimp size 16 contacts; the -16 handles 14-18AWG while the -1620 handles 16-20AWG). All four are readily available on Amazon or eBay under both brand names.
Or, if you prefer genuine Amphenol tooling (which looks like it might be made under contract by Iwiss), those are the AUTK-12, AUTK-16 and AUTK-20.
-Eric
