jluckey(at)pacbell.net Guest
Posted: Fri Nov 03, 2023 8:41 am Post subject: Progressive Toggle Switch is Hard to Find |
Listers,
I'm considering using a Carling S700-2-10 2-pole progressive transfer toggle switch but cannot find it at any of my usual suppliers. Is this switch going obsolete?
I see it on B&Cs website but I'm hesitant to use it in a new design if they are so difficult to find.
Perhaps I'm just not looking in the right places. Any thoughts?
TIA,
-Jeff
email(at)jaredyates.com Guest
Posted: Fri Nov 03, 2023 10:34 am Post subject: Progressive Toggle Switch is Hard to Find |
I got a couple from Stein I believe, but never was able to find them at the non-aviation sources. I attributed this less to the switch being obsolete, and more to me just not being able to get the right part number to google for.
On Fri, Nov 3, 2023 at 12:46 PM Jeff Luckey <jluckey(at)pacbell.net (jluckey(at)pacbell.net)> wrote:
| Quote: | Listers,
TIA,
-Jeff
prestonkavanagh
Joined: 27 Nov 2018 Posts: 17 Location: Tarpon Springs
Posted: Fri Nov 03, 2023 10:36 am Post subject: Progressive Toggle Switch is Hard to Find |
I like to buy Carling switches at Grainger's - they have multiple stores in Tampa, saving the shipping charges. For the rocker switch you name: https://www.grainger.com/search?searchQuery=Carling%20S700-2-10
FOr a general purpose switch finder, the best is at Digikey, but the one at Grainger's is not bad. See https://www.grainger.com/category/electrical/industrial-controls-automation-and-machine-safety/manual-and-foot-switches/toggle-switches
The progressive that's hard to find is off-on1-on1&2. It's out there, just hard to find.
YMMV
_________________ PBK3
PA-12, BD-4, RV6a, gliders, Rutan canards |
Eric Page
Posted: Fri Nov 03, 2023 2:56 pm Post subject: Re: Progressive Toggle Switch is Hard to Find |
Jeff, what do you want to control with the S700-2-10, and how do you want it to work?
The S700 switches are Carling G-Series parts. The Carling catalog does not list ON-ON-ON or ON-ON-(ON) with progressive function as standard configurations. Furthermore, the -2-10 and -2-50 cannot be configured through Carling's online configuration tool, as the only available progressive option includes an OFF position (like the -2-11 and -2-51).
The ON-ON-ON function is only available as a 2-circuit (DPDT) non-progressive switch. Given the lack of detail on B&C's website, the -2-10 may actually be a Carling 2GH51-73 and not progressive. It's anyone's guess what the -2-50 actually is, as there's no option for an ON-ON-(ON) configuration of any kind.
I believe the -2-10 may be (if it's progressive) -- and -2-50 almost certainly is -- a special-order custom configuration that B&C requested from Carling. If that's the case and you need the ON-ON-ON function of the -2-10, then B&C is your only option, but I would ask them for confirmation of progressive function before you order.
I put together a cross-reference of the B&C / Carling switches some time ago for my own use, which I'll attach here. Use it at your own risk; I recommend confirming part numbers with the Carling configuration tool before ordering from sources other than B&C.
| B&C S700 to Carling G-Series Switch Cross-Reference Spreadsheet |
 Download |
| Filename: |
B&C S700 Switch Cross-Reference.pdf |
19.34 KB |
| Downloaded: |
724 Time(s) |
