manufactured dsub ground block
podo
PostPosted: Sun Jul 02, 2023 3:28 pm    Post subject: manufactured dsub ground block Reply with quote
I've searched high (and low) for this type of gadget but come up empty. It's the pcb with the shorted dsub pins that I can't find. Can someone suggest a part #?
 Filesize:  261.59 KB
 Viewed:  2795 Time(s)
Eric Page
PostPosted: Sun Jul 02, 2023 3:53 pm    Post subject: Re: manufactured dsub ground block Reply with quote
Mr. Nuckolls may chime in to confirm or deny this, but I believe that was a product that he produced in the past, but no longer. A currently available substitute is the 1/4" quick-connect forest-of-tabs, which has the benefit of passing the ground stud through to the engine side of the firewall. Those are available in various sizes at B&C Specialty Products:
https://bandc.com/product-category/electrical-supplies/grounding-supplies-battery-cables/
Connect to them using PIDG FastOn crimped terminals:
https://bandc.com/product/faston-terminal/
Apply the terminals with this tool:
https://bandc.com/product/pidg-style-crimp-tool/
email(at)jaredyates.com
PostPosted: Sun Jul 02, 2023 6:26 pm    Post subject: manufactured dsub ground block Reply with quote
This is what I used. I started with a solder cup dsub connector, snipped a piece of 14-gauge romex scrap, and soldered it from cup to cup. One side is grounds and one side is 5v. The Dynon system has a single 5v output that I had to use in several places. A plastic back shell protects the contacts.
On Sun, Jul 2, 2023, 19:33 podo <okonemore(at)comcast.net (okonemore(at)comcast.net)> wrote:
--> AeroElectric-List message posted by: "podo" <okonemore(at)comcast.net (okonemore(at)comcast.net)>
http://forums.matronics.com/viewtopic.php?p=511025#511025
http://forums.matronics.com//files/manufacture_dsub_ground_block_195.png
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
 Filesize:  2.44 MB
 Viewed:  2781 Time(s)
