Duncan McFadyean
Posted: Sun Jun 18, 2023 1:56 am Post subject: The Obsidian Files - Chapter 1 - Pigs In Space & Other S |
How about looking more closely at the detail surrounding the door closure and frame?
Areas of relatively high and low pressure on the surface of the fuselage around the periphery of the door closure are in practice interconnected by a "tube" (i.e. the door rebate) with slots (i.e. the door-to-fuselage gap). Air must be being sucked in at some places along this slot and blown out at others, with resulting potential to wreck the downstream attachment(?).
Personally, I've found outer doorseals (that effectively block the slot) to be beneficial.
Duncan Mcf.
Quote: | On 19 May 2023 at 12:46 Area-51 <goldsteinindustrial(at)gmail.com> wrote:
Everything begins at Zeroâ¦
So now that we have dealt with the preamble and have some familiarity with what all the rainbow images and basic terminology used is about it should be a good moment to introduce our science pig, sorry plug⦠I call it Pig because that is what it is; a happy jovial highly intelligent pig that does not mind being pushed and prodded around the yard.
Pig-01 is used as a Baseline measure that all upstream tests can be referred back to and compared against. It is a Clean Skin 3D model, meaning there are no extra bits added or protruding from the basic aerodynamic shape; it is as slippery as a Europa Classic can possibly be without further modification. And contrary to the mention of two Pigs in the Preamble there can only be space for one Pig in this story of shock and awe.
The model lends itself to set criteria of variance in order to identify our Primary Baseline. This criterion consists of the following:
⢠Wings â 6DOF
⢠Horizontal Stab â 6DOF
⢠Fuselage Fixed
With only three pieces making up our pig the third piece being the fuselage is fixed at 0deg attitude; the lower surface line of the hatches set to the horizontal of the XY plane with the longitudinal axis being in the XZ direction. This allows complete augmentation of both Wing Incidence and Pitch of the Horizontal Stab. Height of both pieces can also be altered relative to the fixed fuselage.
Dihedral of the main wing is set at 4deg.
In order to Zero the model Incidence of the Main Wing is set at 0deg for the primary round of CFD analysis, using the wingâs chord line at the longitudinal centreline of the fuselage as the identifier.
Alpha is also set at 0deg.
Now that we have set our model parameters we can go about creating the Solution Domain parameters.
The Solution Domain is a large area measuring some 20mx20mx20m around the model. This area is required to mitigate any interference that may occur should the free stream fluid impact the outer perimeter wall and feedback against the model during solution, resulting in false readings⦠this is a big area and when we turn this into a 3D mathematical mesh our mesh sizing will also affect the time the solution requires to solve along with the resolution and clarity of results. So we need to firstly ask what is it that we want to know, and how critical do we need the answer to be⦠If its just for guidance and we are searching for direction to develop a concept in then we can use a very loose âlarge cellâ mesh⦠however if we require more definitive answers we would opt for a finer mesh and go do some gardening or shopping for an hour or two⦠or just go to bed and come back to the machine the next morning with a hot cup of coffee in hand and sit down to read the note on !
the screen âMeshing Failedâ⦠Fortunately that has not happened for a while, but it does happenâ¦
So we are at the point of what is it that we want to know? Well how about some Lift and Drag numbers? Letâs look at the way the fluid Velocity is flowing around the model; is there any Turbulence or Cavitation evident? Where are the Pressure curves happening? What level of Acoustic Power is being emitted? ... These aspects are the primary criteria used in most of all the contrast studies⦠We are primarily looking for Divergence and Convergence of data in order to identify areas of aerodynamic efficiency.
How great it is to be able to play with âwhat ifsâ?! ⦠And not kill ourselves doing it!
With that out of the way we can chuck it all out across the table and record our ground zero baseline, which on this occasion, based upon the above, is:
Velocity (m/s) Alpha (deg) Inc (deg) Drag (kg) Lift (kg)
38.50 0 0 18 78
51.44 0 0 32 137
77.16 0 0 76 312
102.88 0 0 137 544
128.61 0 0 215 887
154.33 0 0 324 1331
205.77 0 0 658 2677
Yes that really is 400kt TAS at 0âAMSL 15C Dorothyâ¦
Next we will look at a few of these above results with the wing incidence adjustedâ¦
38.50 0 1 18 128
51.44 0 1 32 209
77.16 0 1 76 512
51.44 0 2 36 330
77.16 0 2 80 729
What can we assume and theorise from these above results?
The Europaâs aerofoil generates Lift! ⦠It actually generates more lift than required at certain velocitiesâ¦
What else can we assume from these numbers?
With a Rotax 912UL/ULS we can aerodynamically Vmax at 200kt â 230kt
With a Rotax 916is we can aerodynamically Vmax somewhere between 250kt â 300kt
With a Rotax 914 we can aerodynamically Vmax somewhere between 230kt â 250kt
Not too shabby⦠But what is happening to the air while it skirts over the modelâs skin? Is there a lot of turbulence? Is there a lot of noise? Well⦠Yes and Noâ¦
At first Velocity prints were looked at across all the velocity vectors, and it was surprising to observe very little alteration in the velocity pattern over the model. Other than the velocity band increasing in magnitude, at Alpha 0 or 1 or 2 the patterns remained fairly unaltered.
Then Acoustic Power prints were looked at in the same manner as with Velocity, and it revealed a slightly different picture.
At 38.50m/s (75kt) to 51.44m/s (100kt) there is very little audible noise being generated by our Pig; 35db â 55db max respectfully. In other words, this Pig is silent while flying through the skyâ¦
With increases in velocity our pig starts to murmur a bit, and as velocity increases our pig is squealing at the top of its capacity at 110db at 400kt⦠747 on T/O equivalent⦠its Loudâ¦
The other thing that was picked up by the Acoustic prints was Cavitation over the Boundary Layer; as velocity increases so does cavitation. This being the cause of the rise in db power; and more will be written about this later, but for now all we need to know is that cavitation equalâs noiseâ¦
So what have we discovered so far in this primary study that we can take into stuff going on further down the wire?
Well, it appears we know that:
⢠The Europaâs wing generates too much Lift to aerodynamically fly the Model beyond say 230kt; unless we want to keep climbing up to FL25 where the air is thin enough to absorb the extra Lift.
⢠In order to attain the above data, aerodynamically, we need to reduce the wingâs incidence on our Model to 2 or less degrees.
⢠As velocity of the Model increases so too does the Acoustic Power being emitted.
⢠The Europaâs aerofoil profile is able to reach 400kt at Alpha-0 and remain efficient.
It is probably a good moment to review our model with the wing incidence set as per factory and compare some results. These results have been mashed through the Solver with an Alpha of -3deg and the Horizontal Stab adjusted to be parallel of the wingâs Incidence; So we are simulating pitching the nose of the Model slightly down on step⦠The results received were:
51.44 -3 factory 42 129
102.88 -3 factory 175 518
128.61 -3 factory 280 837
205.77 -3 factory 842 2469
With these above numbers, with a 912ULS, aerodynamically, we are just able to reach 200kt; still not too shabbyâ¦
The Europaâs form is very slippery, but the CFD studies are revealing areas around the Empennage aft of the cabin where cavitation begins and continues aft; so we are seeing the effects of boundary layer separation that is taking place just above the modelâs skin⦠The Velocity prints are not detecting this as they are focused upon a very shallow layer, where as the Acoustic Power prints reveal the affects more of what is going on around the selected layer band; so this is why we can use them to tell another story other than just noise, and more so read them as an indication of what may be the cause of the noise; which, in this environment, can only be cavitation.
Cavitation also is evident with the wing. At 0deg Incidence the cavitation is minimal and is seen along the last inch of the upper trailing edge and along the last 2 or so inches of the lower trailing edge. Longitudinal cavitation streaks are also evident on the lower surface of the wing at Alpha-0. As Velocity increases these areas of cavitation extend further in from the trailing edge of the wing and increase in amplitude. However this study is not focused upon the wing so we will leave this story for another episode.
As far as actual noise is concerned even at 150kt the Acoustic Power being generated by this above cavitation is only at 70db max⦠So we are still, from 100m or so away, flying silently. At 200kt things are just starting to become detectible over the murmur of daytime nature.
So what about this cavitation and how might it be mitigated? At this point no definitive idea, however looking at the shape of the empennage, being slightly concave, changing it to a slightly convex shape may return favourable numbers. Looking toward the Liberty XL may provide some direction. Regarding cavitation around areas of the wing, this tends to diminish as Alpha is increased. Again this is another bedtime story to be told another nightâ¦
This concludes this session upon flying pigs and baseline setting, and the subject is now open to forum for people to add or comment upon.
http://forums.matronics.com/viewtopic.php?p=510821#510821
http://forums.matronics.com//files/clean_plug_standard_912.jpg
http://forums.matronics.com//files/clean_plug_belly_167.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic_belly__5_x_89__38__alpha_0_109.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic__5_x_89__38__alpha_0_272.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic_belly__5_x_89__51__alpha_0_349.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic__5_x_89__51__alpha_0_179.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic_belly__5_x_89__76__alpha_0_511.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic_belly__5_x_89__76__alpha_0_165.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic__5_x_89__76__alpha_0_201.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic_belly__5_x_89__102__alpha_0_541.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic_belly__5_x_89__102__alpha_0_187.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic__5_x_89__102__alpha_0_525.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic_belly__5_x_89__127__alpha_0_158.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic__5_x_89__127__alpha_0_114.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic_belly__5_x_89__153__alpha_0_146.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic__5_x_89__153__alpha_0_172.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic_belly__5_x_89__204__alpha_0_115.jpg
http://forums.matronics.com//files/clean_plug_incidence__acoustic_belly__5_x_89__204__alpha_0_207.jpg
Area-51
Posted: Sun Jun 18, 2023 11:45 pm Post subject: Re: The Obsidian Files - Chapter 1 - Pigs In Space & Ot |
The doors are subject to a Low Pressure area overhead the center canopy section and therefore will tend to be pulled upward regardless of panel gaps. The affect these gap sizes have upon overall parasite drag can be measured and assessed and other than reduction of acoustic noise the impact upon drag and structural distortion will likely be minimal.
