JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Mon Jun 05, 2023 3:08 pm Post subject: Leaking cylinder head valve cover |
I'm given to understand by someone who has a very slightly leaking valve cover that he's tried after-market O-rings, which didn't seem to make much improvement. He even tried Hylomar Blue around the outside edge of the O-ring, before replacing and tightening the cover, to avoid Hylomar getting into the oil system. However the leak soon reappeared.
My suggestion was to buy a piece of slightly thicker O-ring material, cut it to the required length, glue the ends together, fit this new O-ring into the groove with the join at the top, then see whether that stops the oil leak.
Has anyone already done this and exactly what thickness and type of make-your-own O-ring was obtained and from where?
Matt Dovey
Joined: 13 May 2017 Posts: 48 Location: st albans, england
Posted: Tue Jun 06, 2023 10:35 am Post subject: Re: Leaking cylinder head valve cover |
If its a Rotax, why not buy a rocker cover O ring from Rotax!! It will take the guess work out of it.
trevord
Posted: Tue Jun 06, 2023 10:46 am Post subject: Leaking cylinder head valve cover |
If you do the valve collet upgrade, the kit includes new rocker cover o-ring seals ..
Regards Trevor
Sent from my Galaxy
-------- Original message --------
Date: 7/06/23 6:39 am (GMT+12:00)
Subject: Europa-List: Re: Leaking cylinder head valve cover
--> Europa-List message posted by: "Matt Dovey" <mattdovey(at)hotmail.co.uk>
http://forums.matronics.com/viewtopic.php?p=510920#510920
_-============================================================
_-= - The Europa-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Europa-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> https://matronics.com/contribution
_________________ Trevor |
JonathanMilbank
Posted: Tue Jun 06, 2023 11:47 pm Post subject: Re: Leaking cylinder head valve cover |
Neither the Rotax factory supplied O-rings (via a UK agent) nor the after market items which are supposedly slightly thicker have stopped the very slight leak.
Matt Dovey
Posted: Sat Jun 10, 2023 1:47 am Post subject: Re: Leaking cylinder head valve cover |
It would seem that the O ring is not the problem. Must be damage to the head or rocker cover
JonathanMilbank
Posted: Sat Jun 10, 2023 8:15 am Post subject: Re: Leaking cylinder head valve cover |
Cover checked in an engineering workshop and found to be flat i.e. not distorted. Head contact surface for O-ring not scratched or cracked. It would be difficult to distort the head, I think, without losing compression. Thanks for the suggestion.
Rick Moss
Posted: Mon Jun 12, 2023 1:19 am Post subject: Re: Leaking cylinder head valve cover |
If you swap 2 rocker covers around, does the leak move with it or stay on the same cylinder?
JonathanMilbank
Posted: Mon Jun 12, 2023 8:07 am Post subject: Re: Leaking cylinder head valve cover |
Difficult to say! Having used "sticky stuff" carefully applied outside of the O-ring of another cover to avoid contaminating the oil and not remembering which cover it was, we're reluctant to open another can of worms. We'll just experiment with different sealants (Hylomar Blue didn't work) until we find something which does the trick. The leak is miniscule anyway.
Area-51
Posted: Tue Jun 13, 2023 10:49 pm Post subject: Re: Leaking cylinder head valve cover |
181's 80hp had weeping forward covers upon purchase... both covers were removed and o'rings inspected for condition and seating height; all were sufficient... both covers were assessed for warping with none identified... both head surfaces were inspected for burring, scratches and other damage; none identified... both covers and o'rings reinstalled with a smear of OEM factory assembly grey engine sealant and left to cure.... just pulled the cowls after 50hrs for service; both front covers weeping as before... pulled the worst one for another inspection, refit and reseal... will check situation again after next 5hrs...
Possible causes... High crankcase pressures and component warping at temperature; possible but unlikely... Component Porosity; possible; replace faulty component and monitor for further 5hrs operational time... Heat expansion of the retaining bolt; possible; remove all covers, remachine o'ring channel for thicker o'ring, ensure 0.040" o'ring height above cover face, refit retaining bolt with Loctite, ensure 0.020" expansion gap between cover and head, inspect retaining bolt tension and visual for leaks after first operational hour.
peterz(at)zutrasoft.com Guest
Posted: Wed Jun 14, 2023 1:57 am Post subject: Leaking cylinder head valve cover |
Try some hylomar blue. Great stuff.
PeteZ
| Quote: | On Jun 14, 2023, at 2:55 AM, Area-51 <goldsteinindustrial(at)gmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=510962#510962
SPURPURA
Posted: Wed Jun 14, 2023 4:43 am Post subject: Re: Leaking cylinder head valve cover |
I’ve had that problem before. I installed the o ring as usual then clean off the oil from the face and valve cover. Apply the same sealant used for the gearbox onto the cover and o ring and let cure for an hour before installing. Worked for me.
_________________ N951EU - Tri-gear & 912ULS, N77EU- Mono & 914
I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY. |
timothyferriss
Posted: Tue Feb 06, 2024 7:18 pm Post subject: Re: Leaking cylinder head valve cover |
Forums or online communities dedicated to DIY automotive repairs may have members who have experience slice master with similar issues and can provide specific recommendations based on their experiments
