wiring schematic RV-10 IFR purpose HB-YKP
werner schneider
PostPosted: Tue Jun 06, 2023 8:01 am    Post subject: wiring schematic RV-10 IFR purpose HB-YKP Reply with quote
Hello Listeners,
I just wonder if that email was missed.
It's a dual alternator single battery triple feed essential bus setup
for my IFR RV-10.
So far I got one person (thanks John) comments but would appreciate any
further comment.
Thanks a lot
Werner
On 01.06.2023 00:14, werner schneider wrote:
Dear all,
here my 1st attempt, the load analysis is mostly based on manufacturer loads yet and I did not yet fill all the columns. Distribution is based on the mission IFR, however it has more on the essential bus then needed, due to the limitation of 20 slots on the main fuse board.
I have a different approach for the Aux alternator as I had already the SB1B controller, so by standard the Aux alternator would be switched on together with the main alternator.
one thing I'm not 100% certain if the Aux alternator switch/bus-sense is on the right bus, as I would need to have the alternate feed switch on in case I would switch of the main bus or the Aux alternator would shut down (maybe the bat bus is the right location?)
Thanks for review an comments/questions.
Cheers Werner
http://forums.matronics.com/viewtopic.php?p=510896#510896
http://forums.matronics.com//files/my_electrical_load_analysis_488.pdf
http://forums.matronics.com//files/z101b_hb_ypk_148.pdf
Ceengland
PostPosted: Tue Jun 06, 2023 10:24 am    Post subject: wiring schematic RV-10 IFR purpose HB-YKP Reply with quote
If you're following the Z101 that you attached, the aux alternator
controller should be on the Essential Bus and the bus control should be
as drawn.
On the issue of load distribution across buses, you can extend a 'bus'
by simply adding another fuse block and tying the input posts together.
If 20 isn't enough, just add another 6, or 10, or 12, or whatever slots
with another block and tie their inputs together.
Hope that's helpful,
On 6/6/2023 11:00 AM, Werner Schneider wrote:
<glastar(at)gmx.net>
Hello Listeners,
for my IFR RV-10.
further comment.
Thanks a lot
Werner
> Dear all,
> main fuse board.
> Cheers Werner
www.avast.com
werner schneider
PostPosted: Tue Jun 06, 2023 11:48 am    Post subject: wiring schematic RV-10 IFR purpose HB-YKP Reply with quote
Thanks Charlie,
I thought about adding but then, is there a drawback to have a tad more
(about 4) on the essential (as I have aux generator) so the battery only
operation is a very very low probability and I still could switch a few
things off manualy if needed.
Cheers Werner
On 06.06.2023 19:27, Charlie England wrote:
<ceengland7(at)gmail.com>
be as drawn.
together. If 20 isn't enough, just add another 6, or 10, or 12, or
whatever slots with another block and tie their inputs together.
> Hello Listeners,
> for my IFR RV-10.
> further comment.
> Thanks a lot
> Werner
>> Dear all,
>> main fuse board.
>> location?)
>> Cheers Werner
Ceengland
PostPosted: Tue Jun 06, 2023 12:34 pm    Post subject: wiring schematic RV-10 IFR purpose HB-YKP Reply with quote
As long as the aux generator can 'tote the load', then it shouldn't be
an issue. But if it can't, I'd probably think twice before loading up
the essential bus that much, for simple human factors reasons. Stress
would be higher from losing the primary alt, so adding to the work load
to remember to load shed sounds like a less than good idea. Wink
Something else to consider is that I've never had a homebuilt that
survived 1st configuration (meaning as-bought, for me) for very long,
and I'm pretty sure that there are things I'll change on my
project-RV7's wiring that's 'complete'. When you fly for 6 months and
realize that there's one more electrical gadget you'd like to add, from
where will it get power?
I like 'spares'. I've got a spare (used) microwave stashed in the
hangar, to pull out for temporary use if the built-in in the house dies
(and it's been used that way). Spare tools in various locations in the
hangar and in the walk-in area under the house. I have backups for so
many things, my spouse says she thinks I probably have a spare wife
stashed under the house for when she's gone.
So... I have spare slots in my fuse blocks in the current flying RV6
(which I rewired) and the RV7 project.
Thanks Charlie,
Cheers Werner
> be as drawn.
> Charlie
>> Hello Listeners,
>> for my IFR RV-10.
>> further comment.
>> Thanks a lot
>> Werner
>>> Dear all,
>>> main fuse board.
>>> location?)
>>> Cheers Werner
www.avast.com
werner schneider
PostPosted: Tue Jun 06, 2023 2:17 pm    Post subject: wiring schematic RV-10 IFR purpose HB-YKP Reply with quote
Thanks Charlie,
I will reconsider and thinking about 2 10 blockes at the position of the
20 block. the aux should, from the calculation, be more then ok to keep
the current essential load but again I will reconsider the split Smile
one question about the alternate feed, battery and main contactor are in
the tail behind baggage bulkhead, do I consider right to have the
alternate feed relay at the same place so the hot wire between Battery
and Relay is as short as possible?
Thanks for the feedback
Werner
load to remember to load shed sounds like a less than good idea. Wink
from where will it get power?
dies (and it's been used that way). Spare tools in various locations
in the hangar and in the walk-in area under the house. I have backups
for so many things, my spouse says she thinks I probably have a spare
wife stashed under the house for when she's gone.
> Thanks Charlie,
> Cheers Werner
>> be as drawn.
>> Charlie
>>> Hello Listeners,
>>> for my IFR RV-10.
>>> any
>>> further comment.
>>> Thanks a lot
>>> Werner
>>>> Dear all,
>>>> main fuse board.
>>>> location?)
>>>> Cheers Werner
werner schneider
PostPosted: Tue Jun 06, 2023 3:10 pm    Post subject: wiring schematic RV-10 IFR purpose HB-YKP Reply with quote
Charlie here Revision B,
aux Load on Essential down to 20A, 5 SPare slots on Main Bus, 2 on
Essential, a bit to redo and order another Busmann block for Bat bus.
Cheers Werner
> Thanks Charlie,
> Cheers Werner
>> be as drawn.
>> Charlie
>>> Hello Listeners,
>>> for my IFR RV-10.
>>> any
>>> further comment.
>>> Thanks a lot
>>> Werner
>>>> Dear all,
>>>> main fuse board.
>>>> location?)
>>>> Cheers Werner
HB-YPK-B.dwg.pdf
 Filename:  HB-YPK-B.dwg.pdf
 Filesize:  175.97 KB
 Downloaded:  895 Time(s)
my_electrical-load-analysis-B.pdf
 Filename:  my_electrical-load-analysis-B.pdf
 Filesize:  21.55 KB
 Downloaded:  864 Time(s)
timothyferriss
PostPosted: Thu Oct 03, 2024 1:37 am    Post subject: Re: wiring schematic RV-10 IFR purpose HB-YKP Reply with quote
Your project sounds well thought out, and it’s great Papa's Pizzeria to see you engaging with the community for feedback.
